Your Land Cruiser's 12V battery is essential to start the hybrid system and power key accessories. Whether you're checking its health, planning to recharge it, or need to know when replacement is necessary, here's what the manual tells you.
(Reference: Owner's Manual, pg. 546-548)
CRITICAL HYDROGEN HAZARD
When recharging, the 12-volt battery produces hydrogen gas which is flammable and explosive. Therefore, observe the following precautions before recharging.
(Source: Page 546)
Using the Right Replacement Battery
Use a 12-volt battery designed for this vehicle. Using the wrong battery can cause hydrogen gas to enter the passenger compartment, creating a fire or explosion hazard.
(Source: Page 548)
Battery Fluid Level
Check the battery fluid level before using the vehicle. Low fluid increases the risk of battery failure or explosion.
(Source: Page 548)
RECHARGING OPERATION
Never recharge the 12-volt battery while the hybrid system is operating. Also, be sure all accessories are turned off.
(Source: Page 548)
WASHER FLUID WARNING
Do not add washer fluid when the hybrid system is hot or running as washer fluid contains alcohol and may catch fire if spilled on the engine, etc.
(Source: Page 546)
The 12-volt battery in your Land Cruiser is located in the left side of the luggage compartment. This location provides good accessibility for routine checks and replacement while keeping the high-voltage hybrid battery protected from water exposure during service.
Prerequisites
Step 1: Remove the Battery Cover
Open the left luggage compartment and locate the 12-volt battery. Remove the plastic protective cover to access the battery terminal connections.
Step 2: Inspect Terminal Condition
Make sure that the 12-volt battery terminals are not corroded and that there are no loose connections, cracks, or loose clamps. Check for:
Step 3: Check Battery Condition by Indicator Color
Your battery has a color-coded indicator window on the top. Check the 12-volt battery condition by indicator color:
If your battery indicator shows RED and you need to recharge:
After your battery has been recharged or a new battery has been installed, be aware of these behaviors:
Smart Key System:
Unlocking the doors using the smart key system may not be possible immediately after reconnecting the 12-volt battery. If this happens, use the wireless remote control or the mechanical key to lock/unlock the doors. This typically resolves within a few hours.
Hybrid System Startup:
The hybrid system may not start on the first attempt after the 12-volt battery has recharged but will start normally after the second attempt. This is not a malfunction (it's the vehicle reinitializing its systems).
Power Switch Memory:
The power switch mode is memorized by the vehicle. When the 12-volt battery is reconnected, the system will return to the mode it was in before the 12-volt battery was discharged. Before disconnecting the 12-volt battery, turn the power switch off.
If your battery indicator shows CLEAR, or if your battery fails the charging test, you'll need a replacement. Here are the specifications for your replacement battery:
Regulatory Compliance:
Use a 12-volt battery that conforms to European regulations.
Capacity and Performance:
Battery Type:
After Replacing:
After exchanging the battery, firmly attach the following items to the exhaust hole of the 12-volt battery:
Important Note:
When the 12-volt battery is depleted or its terminals are removed, information stored in the ECU (Engine Control Unit) is cleared. Have the vehicle inspected at your Toyota dealer before removing battery terminals or after the battery has been deeply discharged. Some systems may require initialization.
The community has identified several practices that help extend battery life and prevent common issues in the J250 Land Cruiser:
Pro Tips from J250 Community
Regularly clean battery terminals
Use a wire brush to clean any white or blue corrosion buildup on terminals. Corrosion reduces electrical connection quality and can prevent reliable starting. Clean terminals should be shiny metal.
Maintain secure cable connections
Ensure battery cables are securely attached to terminals. Loose connections cause voltage drops and starting problems that can trigger "Drive Start Malfunction" error messages.
Install a battery tender for extended storage
The Land Cruiser has a dedicated hot post in the engine fuse box with a connector plate for battery tenders. This makes long-term storage easier and prevents deep discharge that damages hybrid systems.
Keep a portable jump box in your vehicle
Low 12V battery is the primary cause of "Drive Start Malfunction" errors. A portable jump box is more reliable than roadside assistance for emergency recovery.
Drive your hybrid regularly if parked for extended periods
Operating the hybrid system at least once monthly keeps the 12V battery charged and systems functional. The 12-volt battery will discharge gradually even when the vehicle is not in use.
Maintain smooth, steady driving habits
Avoid extreme acceleration and hard braking, which stress the battery system. Smooth driving preserves battery health longer.
Park in shade or covered areas when possible
Extreme heat accelerates battery degradation. The ideal temperature range for hybrid battery efficiency is 59-95°F. During hot weather, parking in shade assists the vehicle's cooling system.
Repeatedly discharging the battery to very low levels
Deep discharge cycles reduce battery lifespan and increase risk of starting failures. Avoid leaving headlights or accessories running when the engine is off.
Covering or blocking the 12V battery ventilation filters
The 12V battery has ventilation filters located in the rear quarter area (near cup holders, on the interior plastic). Covering these vents traps heat and can cause battery damage or failure. Clogged filters reduce cooling efficiency.
Using fast-charging stations for regular charging
Fast charging stresses hybrid batteries. Use only 120V or 240V home charging for regular maintenance. Reserve fast charging for emergencies.
Repeatedly charging to 100% capacity
Constant full charges reduce overall battery lifespan. Experts recommend maintaining charge levels between 20-80% for longevity.
Helpful Context
12V Battery Lifespan: The 12V battery in your Land Cruiser has an average lifespan of 3-5 years under normal conditions. Regular maintenance extends this range.
Charging Rate Limit: The owner's manual specifies a maximum 5-amp charging rate for the 70Ah battery. This limit prevents battery damage and is enforced by proper chargers.
Low Battery Warning Signs: If you notice flickering dash lights and controls when entering the vehicle, your 12V battery is low. Attempting to start the vehicle at this point can trigger system error messages that require diagnostics.
Best Charge Range: For extended battery health, maintain charge levels between 20% and 80%. Avoid letting charge drop below 20% or fully charging to 100% repeatedly.
Temperature Sensitivity: Extreme heat is particularly detrimental to hybrid batteries. The J250's cooling system is designed to keep the 12V battery in the 59-95°F ideal range.
For detailed diagrams and official information, refer to these pages in your 2024+ Land Cruiser owner's manual:
Additional Research Sources:
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the enthusiast community and authoritative automotive sources. Always follow your official owner's manual for warranty compliance and safety procedures. This is a reference guide only. For warranty-related work or if you're unsure about any procedure, consult your Toyota dealer.
Official Manual Information
(Source: Page 546)
(Source: Page 548)
Battery Fluid Level
(Source: Page 548)
(Source: Page 548)
(Source: Page 546)
Battery Location
Checking Battery Condition
Prerequisites
- Park vehicle on a level surface
- Ensure engine is cool
- Have clean cloth or brush available
- Allow 5 minutes after engine shutdown for battery to stabilize
- White or blue corrosion buildup on terminals (terminals should be shiny metal)
- Loose cable connections (terminals should be snug)
- Cracks in the plastic battery case
- Loose or damaged hold-down clamp (labeled "B" on the battery)
| Indicator Color | Meaning | Action Required |
| Blue | Good condition | No action needed |
| Red | Charging is necessary | Have the vehicle inspected by your Toyota dealer |
| Clear | Replacement is necessary | Contact your Toyota dealer for replacement |
Before Recharging the Battery (Page 546)
- If recharging with the 12-volt battery installed on the vehicle, be sure to disconnect the ground cable.
- Make sure the power switch on the charger is off when connecting and disconnecting the charger cables to the 12-volt battery.
After Recharging or Reconnecting (Pages 546, 619)
Smart Key System:
Battery Replacement Specifications (Page 619)
- Case Size: Same as the previous one (LN3)
- 20-Hour Rate Capacity (20HR): Equivalent to 70Ah or greater
- Performance Rating (CCA): Equivalent to 600A or greater
Battery Type:
- Use a ventilation type calcium battery
- Use a 12-volt battery with a handle. If a 12-volt battery without a handle is used, removal is more difficult.
After Replacing:
- Use the exhaust hose that was attached to the 12-volt battery before replacing and confirm proper attachment.
Important Note:
Land Cruiser 12V Battery Maintenance, Care Tips, Hybrid Battery Management
Helpful Context
- Page 546: Battery location, recharging precautions, and safety warnings
- Page 548: Battery checking procedures and indicator color reference
- Page 619: Battery discharge information, ECU clearing, and replacement specifications
- Primary procedure: Pages 546-548
- Specifications and ECU information: Page 619
- Land Cruiser Forum - J250 battery maintenance, storage, and troubleshooting
- Kelley Blue Book - Hybrid battery health and temperature management
- Toyota of Bellevue - J250 hybrid system maintenance
