2024+ Land Cruiser - Acoustic Vehicle Alerting System
Your hybrid Land Cruiser operates silently in EV mode. That means pedestrians might not hear you approaching (which is exactly why AVAS exists). Here's how the system works and what every hybrid owner should know. (Reference: Owner's Manual, pg. 72)
AVAS Operation, Hybrid Alert System, EV Mode, Pedestrian Safety​
What Is AVAS and Why Your Hybrid Has It​
The Acoustic Vehicle Alerting System (AVAS) is a hybrid-specific safety feature found on all 2024+ Land Cruiser J250 models. Because the i-FORCE MAX hybrid powertrain can operate silently in Electric Vehicle (EV) mode, pedestrians and cyclists nearby may not hear the vehicle approaching. The AVAS compensates for this safety gap by emitting an audible warning sound when the vehicle is operating at low speeds in EV mode.
This system does one critical thing: alert people nearby when you're moving silently. Understanding how AVAS works keeps everyone safe.
How the Acoustic Vehicle Alerting System Works​
Operating Conditions:
The AVAS activates whenever the gasoline engine is stopped and the vehicle is moving under electric power. When this occurs, a sound, which changes in accordance with the driving speed, will be played in order to warn people nearby of the vehicle's approach (Page 72).
Speed-Dependent Operation:
The system automatically adjusts the alert sound based on vehicle speed. As you accelerate, the sound changes to reflect your speed. Once you exceed approximately 22 mph (35 km/h), the electric motor alone can no longer power the vehicle efficiently, the gasoline engine engages, and the AVAS sound stops. At highway speeds, the engine noise itself provides pedestrian awareness.
Audio Coverage:
This sound may be heard inside the vehicle (Page 72), meaning you'll be aware the system is operating even from within the cabin. This helps confirm proper system function during normal driving.
Important Safety Note About Parking​
There may be no engine sound or vibration even though the vehicle is able to move with the "READY" indicator illuminated. For safety, make sure to shift the shift lever to P and apply the parking brake when parked.
(Page 72)
When the Acoustic Vehicle Alerting System May Be Difficult to Hear​
The AVAS relies on sound transmission to alert pedestrians, making it vulnerable to environmental conditions. According to the manual, in the following cases, the Acoustic Vehicle Alerting System may be difficult for surrounding people to hear:
  • In very noisy areas - Heavy traffic, construction zones, or other loud environments may mask the AVAS tone
  • In the wind or the rain - Adverse weather conditions can reduce sound propagation to nearby pedestrians
  • When the system is malfunctioning - If the AVAS fails to function properly
Be particularly attentive when driving in these conditions, as pedestrians may not receive the auditory warning the system normally provides.
If the AVAS Malfunction Alert Appears​
Malfunction Indicator:
If the message "Acoustic Vehicle Alerting System Malfunction Visit your Dealer" appears on your multi-information display, the system has detected a fault. The system may be malfunctioning. Have the vehicle inspected by your Toyota dealer. (Page 72)
Action Required:
Do not attempt to diagnose or repair the AVAS yourself. Schedule service with a Toyota dealer to have the system inspected and restored to proper function.
Real-World Tips and Context​
Why AVAS Matters for Hybrid Owners​
The J250 Land Cruiser is sold exclusively as a hybrid in the North America market. Every owner will regularly drive in EV mode, particularly during low-speed urban driving. The AVAS system is essential for pedestrian safety in these scenarios. Unlike traditional vehicles where engine noise automatically alerts people to the vehicle's presence, hybrids require explicit audio alerts.
Regulatory Context​
The Acoustic Vehicle Alerting System is not unique to Toyota or the Land Cruiser. All hybrid and fully electric vehicles are required by U.S. Federal Motor Vehicle Safety Standards (FMVSS 141A) to provide minimum sound levels (typically 62-76 decibels) to alert pedestrians. The AVAS on your J250 meets these federal requirements, ensuring compliance with safety standards designed to protect vulnerable road users.
The AVAS is a global safety mandate, with similar requirements in:
  • European Union (Regulation 540/2014)
  • Japan (TRIAS regulation)
  • Many other countries with EV/hybrid safety standards
This means your J250's AVAS implementation follows internationally recognized safety standards and has been engineered to meet multiple regulatory frameworks.
Multi-Layer Safety Approach​
The 2024+ Land Cruiser combines AVAS with advanced Pre-Collision System with Pedestrian Detection, forward collision warning, and automatic emergency braking. This multi-layered safety approach (AVAS sound + active collision avoidance) addresses the pedestrian safety concerns associated with quiet vehicles.
Practical Awareness for Hybrid Owners​
Test the System: During your first few hybrid drives, listen for the AVAS tone in parking lots and low-speed areas. Familiarizing yourself with the sound helps you understand what pedestrians should be hearing.
Know the Transition Point: The system cuts out around 22 mph (35 km/h). This is the speed threshold where the engine engages and traditional road noise takes over. Know this transition point for your own awareness.
Expect System Silence at Highway Speed: Once on the highway, the engine is fully engaged and the AVAS stops. This is normal. The engine provides the auditory cue instead.
Respect Weather-Based Limitations: In heavy rain, strong wind, or noisy environments, assume your AVAS may not be reaching distant pedestrians. Exercise extra caution when backing up or making low-speed maneuvers in these conditions.
  • Page 72 - Hybrid system sounds and vibrations, Acoustic Vehicle Alerting System
  • Federal Motor Vehicle Safety Standards (FMVSS 141A) - NHTSA
  • STMicroelectronics AVAS Technical Reference
  • Wikipedia - Electric Vehicle Warning Sounds
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from federal safety standards and technical references. Always follow your official owner's manual for warranty compliance and specific vehicle operating procedures. This is a reference guide only and does not substitute for official Toyota documentation.
The Acoustic Vehicle Alerting System is a safety feature designed to protect pedestrians. Proper understanding of when and how the system operates helps you be a safer driver and protects those sharing the road with your vehicle.
