Choosing the right transmission fluid is critical for your Land Cruiser - use the wrong type and you risk serious transmission damage. Here's what you need to know about your J250's ATF requirements.
(Reference: Owner's Manual, pages 226 & 633)
NOTICE: Automatic transmission fluid type
Using transmission fluid other than the above type may cause abnormal noise or vibration, or damage the transmission of your vehicle.
Source: Owner's Manual page 633
Source: Owner's Manual page 633, Vehicle Specifications Section
Specification Details
Fluid Type - Toyota Genuine ATF WS
This is a TOYOTA-SPECIFIC requirement. ATF WS is not interchangeable with other transmission fluids:
Fluid Capacity - 13.2 Quarts (12.5 Liters)
The 13.2 quart (12.5 liter, 11.0 imperial quart) figure is a reference specification:
Your 2024+ Land Cruiser has a protective system that monitors transmission fluid temperature. It's important to understand how this works - it can help you avoid serious transmission damage.
How the Protection System Works
If the tires spin continually when the vehicle becomes stuck in mud, dirt or snow, or if the accelerator pedal is depressed and released repeatedly while driving, the automatic transmission temperature may become too high and the automatic transmission may be damaged.
To avoid damaging the automatic transmission, the system may temporarily lock the gear. If the automatic transmission temperature falls, the gear locking is canceled and the automatic transmission is returned to normal operation.
Source: Owner's Manual page 226
Temperature Warning Message
If the automatic transmission fluid temperature is high, the following message will display on your multi-information display:
"Transmission Oil Temp. High Stop in a Safe Place and See Owner's Manual"
When this warning appears:
Driving Safety - Slippery Road Surfaces
WARNING: When driving on slippery road surfaces
Do not accelerate or shift gears suddenly. Sudden changes in engine braking may cause the vehicle to spin or skid, resulting in an accident.
The 2024+ Land Cruiser J250 uses an 8-speed automatic transmission paired with the 2.4L turbocharged i-FORCE MAX hybrid powertrain. This combination generates 326 hp and 465 lb-ft of torque, placing significant demands on the transmission system.
Toyota Genuine ATF WS is engineered specifically for:
The Critical Warning is Not a Suggestion
Using non-approved transmission fluid is one of the fastest ways to damage an automatic transmission and void your warranty. The NOTICE in your owner's manual is a warranty and reliability statement.
The J250 Land Cruiser's transmission will show specific symptoms if non-approved fluid is used:
For fluid replacement and maintenance supplies:
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual (OM60Y03U). Always follow your official owner's manual for warranty compliance and safety. This guide is a reference only. For fluid replacement, contact your authorized Toyota dealer. The 2024+ Land Cruiser is a hybrid-only vehicle in North America with the 2.4L turbocharged i-FORCE MAX engine.
Automatic Transmission Fluid, ATF Type, Toyota Genuine ATF WS, Transmission Specifications
Critical Safety Notice
Automatic Transmission Fluid Specifications
| Specification | Requirement |
| Fluid Type | Toyota Genuine ATF WS |
| Fluid Capacity (Reference) | 13.2 quarts (12.5 liters, 11.0 Imperial quarts) |
- Using Dexron or other ATF types will damage the transmission
- This specification is printed in your vehicle's owner's manual as the requirement
- The fluid type is critical to transmission warranty coverage
- This is the total fluid capacity of your transmission
- For actual fluid replacement, contact your Toyota dealer
- Overfilling or underfilling affects transmission performance and cooling efficiency
Transmission Temperature Protection System
- Immediately stop the vehicle in a safe place
- Shift the shift lever to P (Park)
- Wait until the warning message clears
- If the warning message goes off, you may start the vehicle again
- If the warning message does not go off, contact your Toyota dealer
Why ATF WS Matters for Your J250
- Hybrid powertrains: The transmission manages both gas engine and electric motor power delivery
- Turbo compatibility: Higher oil film strength for the extra pressure from turbocharging
- Temperature stability: Maintains viscosity across the wide temperature range of a hybrid system
- Shift quality: Ensures smooth, precise shifts in the 8-speed transmission
What Makes ATF WS Different
- Approved for: Toyota automatic transmissions including hybrid variants
- NOT approved for: Dexron-based fluids, competing brand ATFs, or older Toyota specifications
- Density: Lighter viscosity than older ATF specifications, optimized for fuel economy
- Additive package: Friction modifiers and anti-wear agents specific to Toyota's transmission designs
Symptoms of Using Wrong Fluid
- Early symptom: Rough shifts, jerky engagement
- Progressive symptoms: Whining or grinding noises during acceleration
- Critical failure: Complete transmission failure requiring costly replacement
Recommended Products
- Toyota Genuine ATF WS Transmission Fluid
- Transmission fluid drain pan
- Transmission fluid pump or funnel tool
- Automatic transmission specifications: Page 633
- Transmission temperature protection: Page 226
- Transmission temperature warning: Page 226
- Slippery road safety: Page 226
