2024+ Land Cruiser - Coolant Checks (Engine and Power Control Unit)
Keeping coolant levels right matters for your hybrid system's performance. Whether you're doing routine maintenance or troubleshooting unexpected drops, here's what you need to know.
(Reference: Owner's Manual, pg. 543-544, 632)
Engine Coolant, Power Control Unit, Checking Levels, Capacity, Specifications​
When the hybrid system is hot
Do not remove the engine/power control unit coolant reservoir caps. The cooling system may be under pressure and may spray hot coolant if the cap is removed, causing serious injuries, such as burns.
When the engine is hot
Do not touch the engine radiator, condenser or intercooler radiator as they may be hot and cause serious injuries, such as burns.
When adding coolant
Coolant is neither plain water nor straight antifreeze. The correct mixture of water and antifreeze must be used to provide proper lubrication, corrosion protection and cooling. Be sure to read the antifreeze or coolant label.
If you spill coolant
Be sure to wash it off with water to prevent it from damaging parts or paint.
Source: Owner's Manual pages 543-544
Checking Engine Coolant Level​
Your coolant level is fine if it's between the "F"/"FULL" and "L"/"LOW" lines on the engine coolant reservoir when the hybrid system is cold.
  1. Park on a level surface
  2. Turn off the hybrid system and wait at least 5 minutes for it to cool completely
  3. Open the hood and locate the engine coolant reservoir (transparent plastic container on driver's side)
  4. Check the level against the FULL and LOW lines on the side of the reservoir
  5. If the level is on or below the LOW line, add coolant up to the FULL line
  6. Replace the cap securely
  7. Do not overfill
Checking Power Control Unit Coolant Level​
The 2024+ Land Cruiser has a separate coolant system for the power control unit (part of the hybrid battery cooling system). This system has its own reservoir with FULL and LOW level indicators.
  1. Locate the power control unit coolant reservoir (mounted separately in the engine bay)
  2. Check the level against the FULL and LOW lines
  3. If the level is on or below the LOW line, add the same Toyota Super Long Life Coolant to the FULL line
  4. This system is equally important as engine cooling for hybrid performance
Coolant Specifications​
Recommended Coolant Type:
Use either of the following:
  • Toyota Super Long Life Coolant
  • Similar high-quality ethylene glycol-based non-silicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology
Critical Note: Do not use plain water alone.
Coolant Capacity:
SystemCapacityConfiguration
Engine Coolant12.2 qt (11.5 L, 10.1 Imp.qt.)Vehicles without rear air conditioning
Engine Coolant14.3 qt (13.5 L, 11.9 Imp.qt.)Vehicles with rear air conditioning
Power Control Unit2.5 qt (2.4 L, 2.1 Imp.qt.)All 2024+ models
Regional Mixture Specifications:
United States:
Toyota Super Long Life Coolant is a mixture of 50% coolant and 50% deionized water. Minimum temperature: -31°F (-35°C)
Canada: Toyota Super Long Life Coolant is a mixture of 55% coolant and 45% deionized water. Minimum temperature: -44°F (-42°C)
Need specifics on coolant for your model? Your dealer can help with those details.
Source: Owner's Manual pages 543-544, 632
What to Do If Coolant Level Drops Quickly​
If you notice the coolant level drops within a short time after refilling:
  1. Visual Inspection:Check the following areas for leaks:
    • Radiators (engine, condenser, intercooler)
    • Hoses and hose connections
    • Engine coolant reservoir cap and drain cock
    • Power control unit coolant reservoir cap
    • Water pump
  2. Clear Debris: Check the engine radiator, condenser, and intercooler radiator for dirt, leaves, or other foreign objects. If any of these parts are extremely dirty, have your vehicle inspected by your Toyota dealer.
  3. Professional Diagnosis: If you cannot locate a leak after visual inspection, have your Toyota dealer test the coolant cap and check for leaks in the cooling system.
Source: Owner's Manual page 544
Pro Tips from the Community​
Flush the cooling system every 30,000 miles or 24 months
Maintains proper coolant dilution ratios and prevents rust and corrosion of engine components. Procedure: Drain the radiator and both engine block drains, refill with distilled water, warm up the vehicle, drain the water again. Repeat 2-3 times until water runs clear.
Always check coolant level when engine is completely cold
A warm engine shows more coolant in the expansion tank than a cold engine. Checking when warm gives false "full" readings. Wait at least 5 minutes after shutting down before checking.
Maintain proper coolant dilution ratio
Incorrect water-to-coolant ratio (below 50% in USA, 55% in Canada) causes rust and component damage. Always use pre-mixed Toyota Super Long Life Coolant or carefully mix to exact specifications.
Monitor coolant levels monthly on new vehicles
Some 2024 LC250 models show minor coolant loss during break-in period (verified as normal by dealers). Check levels at fill-ups during first 30,000 miles; report persistent loss to dealer.
Source: Land Cruiser enthusiast community forums (TLACruiser, IH8MUD, Land Cruiser Club)
Mixing different coolant types
Old-style silicate coolants (green) and OAT formulas (orange/pink) are not compatible with Toyota Super Long Life Coolant (HOAT - pink/red). Mixing causes chemical breakdown and leaves deposits. Only use Toyota Super Long Life Coolant or verified HOAT equivalents; flush system completely if previous coolant type is unknown.
Adding coolant when engine is hot
Hot coolant system is under pressure and can spray when cap removed, causing severe burns. Also, topping off hot creates over-fullness when system cools. Always wait 5+ minutes after engine shutdown before checking or adding coolant.
Ignoring the coolant loss TSB for 2024 LC250
Toyota issued a Technical Service Bulletin for coolant leaks on early 2024 LC250 FE models. Some owners report losing ~1/2 quart per 10,000 miles. If you experience steady coolant loss, bring TSB reference to dealer.
Using wrong pressure testing equipment
Standard coolant pressure test kits don't have an adapter that fits the J250's overflow tank. Using wrong equipment means undetected leaks. If testing for leaks, ensure technician uses CTA Tools part #7103 adapter specifically designed for Toyota overflow tanks.
Neglecting cooling intake/filter blockage
Dirty or blocked cooling intakes prevent proper airflow, causing high fan noise and risking hybrid battery damage (plastic parts become brittle). Check and clean cooling air intake filters during regular maintenance; this is especially critical for hybrid systems.
Source: Land Cruiser enthusiast community (IH8MUD, Land Cruiser Forum, Land Cruiser Club)
Helpful Context​
The J250 has dual coolant systems that work together:
The hybrid power control unit relies on the main coolant system for cooling efficiency. Unlike older mechanical systems, the PCU coolant temperature directly affects battery performance. This is why the manual warns about not removing caps when hot — the pressure is higher than expected.
Early coolant loss on 2024 models is tracked and has known causes:
Some 2024 LC250 vehicles show minor coolant loss in the first 10,000 miles. Community troubleshooting has identified rear heater lines (if equipped) as potential rust points, and low-quality metal fittings throughout the system as another source.
Toyota's recommended 30,000-mile flush interval is critical for longevity:
The HOAT formula in Toyota Super Long Life Coolant begins degrading at higher mileages. The i-FORCE MAX hybrid's dual-system design means both systems need fresh coolant — partial flushes don't fully renew protection.
Plastic components in the cooling system have known brittleness issues:
Multiple owners report plastic fittings and lines becoming brittle at 80,000-120,000 miles, leading to sudden leaks. This is a known material limitation in hybrid designs. Keep a coolant emergency kit in the vehicle.
Source: Long-term owner experience from Land Cruiser enthusiast forums
  • Engine and PCU coolant checking: Pages 543-544
  • Coolant specifications and capacities: Page 632
  • TLACruiser.com - Coolant maintenance guides
  • IH8MUD.com Forum - Toyota and Lexus community
  • Land Cruiser Club - J250 owner discussions
  • Land Cruiser Forum - J250-specific technical discussions
  • RepairPal - Professional maintenance guidance
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
