2024+ Land Cruiser - Customizing the 12.3-inch Digital Display
Want to customize your 2024+ Land Cruiser's digital display? Here's how to take full advantage of those three gauge layout options. (Reference: Owner's Manual, Pages 92-93, 105-111)
Display Customization, Gauge Configuration, Instrument Cluster, Digital Display Settings​
Understanding Your Display Options​
The 2024+ Land Cruiser features a highly customizable 12.3-inch digital instrument cluster that consolidates critical driving information into a configurable display. Unlike traditional analog gauges, this digital system allows you to customize what information appears and how it's presented - from basic speed and fuel data to advanced hybrid-specific monitoring.
Display Type Selection​
Your Land Cruiser offers three different gauge cluster layout options. Each provides the same core information but in visually different configurations.
Type 1/Type 3 Configuration:
The Type 1/Type 3 gauge cluster features a traditional round analog speedometer and tachometer layout with a digital multi-information display between them (Page 92). This layout includes:
  • Multi-information Display (center) - presents variety of vehicle data, displays warning messages if malfunction occurs
  • Outside Temperature (top)
  • Tachometer - displays engine speed in revolutions per minute
  • Speedometer - available in both analog and digital format
  • Shift position and gear position indicator
Type 2 Configuration:
Type 2 provides an alternative gauge layout with side-by-side round gauges (Page 93). The location of displayed items and units of measure may differ depending on the vehicle's intended destination market (metric vs. US specifications).
The Multi-Information Display: Your Central Hub​
The 12.3-inch multi-information display is used to display:
  • Fuel efficiency related information
  • Various types of driving-related information
  • Display settings and other customization options
The display is organized into distinct sections: Content Display Area (Left), Content Display Area (Center), Content Display Area (Right), Driving Support System Information Display Area, and Warning Message Display area (Page 105).
Widget Options​
Widget (Audio System-Linked Display) - Page 93:
Displays the selected audio source or track on the meter. While the content list is displayed (via menu navigation), the widget will NOT display.
Widget (Fuel Economy) - Page 93:
Displays fuel economy information in real-time. While the content list is displayed, the widget will NOT display.
Advanced Gauge Types: Hybrid-Specific Monitoring​
Boost Gauge - Page 111:
Displays boost pressure from the 2.4L turbocharged i-FORCE MAX engine. This display is intended for use as a guideline. Depending on factors such as the road surface condition, temperature and vehicle speed, the display may not show the actual condition of the vehicle.
Electric Boost Gauge - Page 111:
Shows when the hybrid electric motor is actively assisting the engine, providing additional power during acceleration and hill climbing.
SOC (State of Charge) Gauge - Page 111:
Displays the current amount of charge remaining in the hybrid battery (traction battery). This is the most important gauge for understanding hybrid system efficiency.
Customization via Meter Control Switches​
Setting Procedure (Page 111):
  1. Press the OK button on the steering wheel control to display the cursor on the content display area (center)
  2. Use left/right arrow keys to move focus between display areas (Left, Center, Right)
  3. Use up/down arrow keys to scroll through available gauge/widget options
  4. Press right arrow to open the widget menu for specific display areas
  5. Select your desired gauge or widget
  6. Your selection appears in that display area
Available Gauge Selection Options:
  • Boost gauge (turbocharger pressure)
  • Electric Boost Gauge (hybrid motor assist indicator)
  • SOC (State of Charge) gauge (hybrid battery level)
  • Tire inflation pressure
  • Front tire direction display
  • Wheel spin display
  • Traction monitor
  • Blank (No items)
Three-Screen Configuration Strategy​
Pro Tip: Take advantage of the three available screens with different gauge configurations. Set up Screen 1 for daily driving (fuel economy focus), Screen 2 for highway/efficiency monitoring (hybrid battery + boost), and Screen 3 for off-road/performance (traction monitor + wheel spin display). This approach gives you complete visibility depending on your driving scenario. - Community forum discussion, Trust Score: 8/10
Hybrid-Optimized Gauge Configuration​
Recommended Configuration: For hybrid owners, set one screen for fuel economy and engine/transmission oil temperature, another for hybrid battery percentage (SOC) and electric boost gauge, and a third for navigation or tire pressure. This configuration gives complete visibility into both engine and hybrid system performance. - 250landcruiser.com forum, Trust Score: 9/10
Understanding SOC Battery Monitoring​
The Max widget displays the electric motor assist level at the top and the NiMH battery state at the bottom as a bar graph called the State of Charge indicator. This gives real-time feedback on hybrid battery depletion and charge during driving. A well-charged battery (full SOC) allows maximum electric-only operation during city driving and smooth acceleration. A depleted battery means the engine works harder to recharge while also propelling the vehicle, reducing efficiency. - Community testing, Trust Score: 8/10
Critical Widget Limitation (US Models)​
Important Note: On US-spec 250 models, you can ONLY display one widget at a time in any of the three display areas. Many owners expect to show multiple widgets simultaneously (e.g., both fuel economy AND SOC gauge in the center screen), but this isn't possible. Plan your configuration accordingly. - 250landcruiser.com forum, Trust Score: 9/10
Boost & Electric Boost Gauge Synergy​
The boost gauge and electric boost gauge work in tandem. When you see high turbo boost on the left side, the turbocharged engine is producing power at that moment. When you see the electric boost gauge active on the right, the hybrid motor is assisting. Watching both together teaches you how the hybrid system optimizes power delivery. Many owners recommend this paired configuration for understanding their vehicle's operation. - Digital Gauge Cluster discussion, 250landcruiser.com, Trust Score: 8/10
Quick Configuration Examples​
Efficiency-Focused Setup:
Screen 1: Fuel economy widget (center) + SOC gauge (left) + Navigation (right)
Screen 2: Trip statistics + Engine efficiency metrics
Screen 3: Basic gauges + Available customization menu
Performance-Focused Setup:
Screen 1: Boost gauge (center) + Electric Boost Gauge (left) + Tire pressure (right)
Screen 2: SOC battery level + Engine temperature monitoring
Screen 3: Traction monitor + Wheel spin display
Off-Road Enthusiast Setup:
Screen 1: Traction monitor (center) + Wheel spin display (left) + Tire pressure (right)
Screen 2: SOC battery level + Boost gauge + Engine monitoring
Screen 3: Navigation + Trip data
  • Display types and gauge locations: Pages 92-93
  • Multi-information display features: Page 105
  • Advanced gauges and meter control procedures: Page 111
  • Additional customization features: Page 647
  • 250landcruiser.com - J250-specific discussions (Tier 1 - Project Forum)
  • landcruiserforum.com - Multi-generation Land Cruiser community (Tier 2)
  • IH8MUD.com - Off-road enthusiast community (Tier 2)
This guide is derived from the official 2024 Toyota Land Cruiser (J250) Owner's Manual with supplementary information from the J250 enthusiast community. Always follow your official owner's manual for warranty compliance. This is a reference guide only. Display customization is a native vehicle feature; the procedures and gauge options described match official manual specifications. Always verify specific procedures against your vehicle's actual owner's manual.
Thread compiled from Official Owner's Manual Pages 92-93, 105, 111, and 647 with community context and real-world configurations. Last verified: 2026-03-11
