Want to set up driver profiles so your Land Cruiser automatically configures itself when you get in? Or customize features to match your preferences? Here's everything you need to know, from official procedures to real-world tips from the owner community. (Reference: Owner's Manual, pages 191 and 647)
My Settings is Land Cruiser's modern vehicle personalization system that goes beyond simple memory recall. This feature creates individual driver profiles that automatically configure your vehicle's settings when you enter it. No manual adjustments needed.
Settings for up to 3 drivers can be recorded by My Settings. This allows families, shared vehicles, or fleets to maintain distinct preferences for each user. When the vehicle identifies you through an authentication device, it automatically recalls the driving position and personalized settings you previously configured.
Your Land Cruiser uses three independent authentication systems to identify drivers. The system checks these methods in priority order:
Reference: Pages 191, 127, 150, 263
Initial setup for My Settings is managed through the vehicle's multimedia system. The process for assigning electronic keys, setting driver names, performing system initialization, and managing multiple driver profiles is detailed in the MULTIMEDIA OWNER'S MANUAL.
The multimedia manual provides complete instructions for these tasks because the My Settings system is feature-rich and requires step-by-step navigation of the multimedia interface. Before setting up profiles—especially face recognition or linked devices—having the multimedia manual handy saves significant time and frustration.
Reference: Page 191
WARNING
As the hybrid system needs to be operating during customization, ensure that the vehicle is parked in a place with adequate ventilation. In a closed area such as a garage, exhaust gases including harmful carbon monoxide (CO) may collect and enter the vehicle. This may lead to death or a serious health hazard.
NOTICE
To prevent 12-volt battery discharge, ensure that the hybrid system is operating while customizing features.
Reference: Page 647
The multimedia touchscreen provides a menu-driven interface:
The multimedia interface typically offers checkboxes, sliders, and dropdown menus depending on the feature.
Reference: Page 647
The multi-information display (digital gauge cluster between speedometer and tachometer) offers a steering-wheel-controlled alternative:
This method keeps your hands on the wheel and works when the multimedia display isn't available.
Reference: Page 647
Some customizable features are linked to driver profiles. Changes you make to certain vehicle settings may affect your driver profile, and different driver profiles may have different settings for the same features.
This means:
Understanding this distinction prevents confusion about why a setting doesn't stick between drivers.
Reference: Page 647
The Land Cruiser's i-FORCE MAX hybrid powertrain requires the hybrid system to remain in Ready mode during customization. The hybrid system manages power distribution differently than conventional vehicles. If the hybrid system is not running during customization, the 12-volt auxiliary battery will rapidly deplete, potentially preventing engine restart and requiring dealer service.
This requirement applies to both multimedia display and multi-information display customization methods. Always ensure the hybrid system is in Ready mode before entering customization mode.
The manual describes saving settings through the multimedia menu, but community members have discovered a faster alternative: press the "Set" button on the driver's door, then select either "1" or "2" to save settings directly to that driver profile. This can be faster than navigating the multimedia menu system.
Source: 250landcruiser.com, established J250 forum
If you and your spouse share the vehicle but want different settings, you can link both keys to separate driver profiles. Whichever key is present when you enter the vehicle will activate that profile's settings. This works for:
Source: landcruiserforum.com, established enthusiast community
On J250 models, the Driver Monitor Camera system (used for face recognition) has a specific setting that many owners miss: you must navigate to Multimedia System > Customize > Driver Monitor Camera Control > Driver Monitor Function Startup and change it from "Default" to "My Settings." This enables the camera to activate your specific profile when it recognizes your face.
Source: landcruiserforum.com, J250-specific discussion
Many first-time users navigate the multimedia menu and make changes but forget to actually save them to their driver profile. Settings made without saving are not retained. Always complete the save operation (either via the seat button "Set" menu or the multimedia profile save option) before exiting customization mode.
Without saving, you'll need to re-customize features every time you enter the vehicle, defeating the purpose of the My Settings system.
Source: landcruiserforum.com, owner experience
Face recognition doesn't activate immediately the first few times—the vehicle takes multiple entries to "learn" your face and build recognition confidence. During initial setup, be patient and allow the system several cycles to establish proper identification. This is normal behavior, not a malfunction.
Owners who don't understand this sometimes incorrectly assume the system is broken and disable it, missing out on a valuable convenience feature.
Source: crownforums.com, real owner experiences
Some owners get stuck in the vehicle's "Guest Profile" after initial setup, unable to see their customizations. This happens when the vehicle doesn't recognize any authentication method or is in factory reset state. Always ensure you've properly assigned an electronic key or face profile to your name during initial setup.
A stuck guest profile prevents your customizations from saving, creating confusion about whether My Settings is working properly.
Source: landcruiserforum.com, troubleshooting thread
Q: Will customizing features affect my My Settings profile?
A: Some features are linked to driver profiles. When you customize these, the change is saved to the current driver profile. Other features are global settings that apply to all profiles. The Multimedia Owner's Manual notes which features are profile-dependent.
Q: Can I customize features while parked at idle?
A: No. The hybrid system must be in Ready mode (actively powered on). A parked vehicle with the engine off or in Accessory mode will rapidly drain the 12V battery during customization.
Q: What if I make a customization mistake?
A: Most settings can be changed back immediately using the same menu interface. Some features may require Toyota dealer intervention if you need to restore factory defaults.
Q: Do I need the multimedia manual to customize features?
A: The basic customization steps shown above are straightforward. However, the Multimedia Owner's Manual provides detailed explanations of what each feature does and the implications of each setting option.
This guide is derived from the official 2024+ Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative forums. Always follow your official owner's manual for warranty compliance. This is a reference guide only, not a substitute for professional service.
My Settings, Driver Profiles, Vehicle Personalization, Electronic Key, Face Recognition
Understanding My Settings
How Your Vehicle Identifies You
- Face Authentication System (Highest Priority) - If equipped, the driver monitor camera (integrated with Toyota Safety Sense 3.0) identifies your face at door opening. This method overrides other authentication if your face is recognized, preventing settings from mixing if multiple registered drivers enter together.
- Electronic Key / Digital Key (Primary Physical Method) - The smart key system detects your electronic key or digital key when you approach the vehicle. This is the most common identification method.
- Bluetooth Device (Fallback) - The vehicle can identify you via your Bluetooth-paired phone if it was the hands-free device used on your last visit. This method is only used if electronic key or face authentication hasn't already identified you.
Profile Setup and Management
Reference: Page 191
Feature Customization
Critical Safety Precautions
WARNING
NOTICE
Reference: Page 647
Before You Customize: Readiness Checklist
- Vehicle parked in safe location with adequate ventilation
- Parking brake applied
- Transmission in Park (P)
- Hybrid system in Ready mode (listen for powertrain activation; instrument cluster shows READY)
- No one is driving the vehicle
- Adequate time available (customization can take several minutes per feature)
Customization Method 1: Multimedia Display (Touchscreen)
- Select the settings icon on the main menu
- Select "Vehicle customize" on the submenu
- Select the item you want to change from the list
- Follow the on-screen prompts to adjust that feature's settings
Reference: Page 647
Customization Method 2: Multi-Information Display (Steering Wheel Controls)
- Operate the meter control switch to select the settings icon (see pages 101, 111 for exact switch location)
- Operate the meter control switches to select your desired customization item from the menu
- According to the display, select the desired setting using the control switches
- Press the return/back button or exit customize mode button to exit
Reference: Page 647
Important: My Settings and Customization Interaction
This means:
- Profile-Aware Features: Steering wheel adjustment, seat heating/cooling, ambient lighting color — these save to your specific driver profile
- Global Features: DRL brightness, warning beep volume — these apply to all profiles
Reference: Page 647
Why the Hybrid System Must Stay Running
Real-World Tips and Common Mistakes
Pro Tip: Use the Seat Button to Save Driver Settings
Pro Tip: Link Multiple Keys for Multi-Driver Households
- Seat position and memory recall
- Climate preferences
- Infotainment customizations
- Driver Monitor settings
Pro Tip: Driver Monitor Camera My Settings Setup
Common Mistake: Forgetting to Save Settings
Common Mistake: Expecting Immediate Face Recognition
Common Mistake: Guest Profile After Initial Setup
Common Questions
- My Settings system overview: Page 191
- Customization procedures and safety warnings: Page 647
- Face authentication integration: Page 263
- Meter control operation: Pages 101, 111
- 250landcruiser.com — Official J250 Land Cruiser forum
- landcruiserforum.com — Established Land Cruiser enthusiast community
- crownforums.com — Toyota Crown owner forum (shared face recognition technology)
- Toyota multimedia system documentation
