2024+ Land Cruiser - Digital Rear-View Mirror Use
Getting the most from your Land Cruiser's Digital Rear-View Mirror? This comprehensive guide covers using, adjusting, and maintaining this powerful visibility feature (with content from pages 167-172 of your owner's manual).
Digital Mirror Operation, Mirror Modes, Display Settings, Camera System​
WARNING — Before using the Digital Rear-view Mirror
Make sure to adjust the mirror before driving. Change to optical mirror mode and adjust the position of the Digital Rear-view Mirror so that the area behind your vehicle can be viewed properly.
Source: Page 167
WARNING — Range Difference
As the range of the image displayed by the Digital Rear-view Mirror is different from that of the optical mirror, make sure to check this difference before driving.
Source: Page 168
WARNING — When using the Digital Rear-view Mirror in digital mirror mode
If it is difficult to see the displayed image due to light reflected off the Digital Rear-view Mirror, the camera being dirty or covered with water droplets, dust, etc., or if lights of a vehicle behind your vehicle or the displayed image are bothering you, change to optical mirror mode.
Source: Page 168
WARNING — Size Difference and Direct Visual Checks
Always pay attention to the vehicle's surroundings. The size of the vehicles and other objects may look different when in digital mirror mode and optical mirror mode. When backing up, make sure to directly check the safety of the area around your vehicle, especially behind the vehicle. If a vehicle approaches from the rear in the dark, such as at night, the surrounding area may appear dim.
Source: Page 172
NOTICE — To prevent the Digital Rear-view Mirror from malfunctioning
Do not block the vent holes of the mirror. Otherwise, the mirror may be hot, leading to a malfunction or a fire.
Source: Page 172
WARNING — To prevent causes of fire
If the driver continues using the Digital Rear-view Mirror while smoke or odor comes from the mirror, it may result in fire. Stop using the system immediately and contact your Toyota dealer.
Source: Page 172
CAUTION — To prevent the camera from malfunctioning
Observe the following precautions, otherwise the Digital Rear-view Mirror may not operate properly:
  • Do not strike or hit the camera or subject it to a strong impact, as the camera installation position and angle may be changed.
  • Do not remove, disassemble or modify the camera.
  • Do not allow an organic solvent, car wax, window cleaner or glass coating to adhere to the camera. If this happens, wipe it off as soon as possible.
Source: Page 172
System Overview​
The Digital Rear-view Mirror is a system that uses the camera on the rear of the vehicle and displays its image on the display of the Digital Rear-view Mirror. The system allows the driver to see the rear view despite obstructions, such as the head restraints or luggage, ensuring rear visibility. The rear seats are not displayed and privacy of the passengers is enhanced.
You can switch between digital and optical mirror modes by operating the lever.
System Components
The Digital Rear-view Mirror display includes several key components:
  • Camera indicator: Indicates that the camera is operating normally.
  • Icon display area: Displays icons, adjusting gauge, etc.
  • Select/adjust button: Press to change the setting of the item you want to adjust.
  • Menu button: Press to display the icon display area and select the item you want to adjust.
  • Lever: Operate to change between digital mirror mode and optical mirror mode.
  • Digital anti-glare mode indicator: In digital mirror mode, this indicates that the anti-glare function is on.
Operating Modes​
Digital Mirror Mode
Displays an image of the area behind the vehicle. The camera indicator will illuminate in this mode. This mode is most effective for parking and backing scenarios where you want to see the area behind your vehicle clearly.
Optical Mirror Mode
Turns off the display of the Digital Rear-view Mirror, allowing it to be used as an optical mirror. This traditional mirror mode provides consistent reflective viewing regardless of lighting conditions.
Operating the Digital Rear-View Mirror​
Changing Modes
Operate the lever to switch between digital and optical modes. The display toggles between the camera image and standard mirror reflection.
Digital Mirror Mode Operating Conditions
Turn the power switch to ON to use digital mirror mode. When you switch the power from ON to OFF or ACC, the image disappears after several seconds.
Using the Digital Mirror in Various Conditions
If the image is unclear due to light reflected off the Digital Rear-view Mirror:
Change to optical mirror mode to minimize glare and reflections.
When using the Digital Rear-view Mirror in rain:
If the image is unclear due to water on the rear window, operate the rear wiper. This will help clear water droplets from the camera lens.
When the back door is open:
The Digital Rear-view Mirror image may not display properly. Before driving, make sure the back door is closed.
If the display is difficult to see due to reflected light:
Close the sunshade for the moon roof (if equipped) to reduce glare on the display.
Driving in darkness (night driving):
Any of the following conditions may occur when driving in the dark. None of them indicates that a malfunction has occurred:
  • Colors of objects in the displayed image may differ from their actual color
  • Depending on the height of the lights of the vehicle behind, the area around the vehicle may appear white and blurry
  • Automatic image adjustment for brighter surrounding image may cause flickering
If it is difficult to see the displayed image or flickering bothers you, change to optical mirror mode.
Physical considerations:
  • Your mirror may get hot in digital mirror mode (this is normal and not a malfunction).
  • Depending on your physical condition or age, it may take longer than usual to focus on the displayed image. In this case, change to optical mirror mode.
  • Do not let passengers stare at the displayed image when the vehicle is being driven, as doing so may cause motion sickness.
Adjusting the Digital Rear-View Mirror​
Adjusting the Mirror Height
Adjust the mirror height to match your driving posture. Switch to optical mirror mode, then move it up and down until it feels right for your position. Taking time to dial in the perfect height (especially if you're taller or have unique seating needs) really improves how usable the digital mirror becomes.
Display Settings (Digital Mirror Mode)
You can customize display settings and control the automatic anti-glare function.
To access display settings:
  1. Press the menu button
  2. Select the item you want to adjust using the Select/adjust button
  3. Adjust the setting as desired
Automatic Anti-Glare Function:
When the automatic anti-glare function is in ON mode, the indicator illuminates. The function will be set to ON mode each time the power switch is turned to ON. Pressing the button turns the function to OFF mode (the indicator also turns off).
To ensure that the sensors operate properly, do not touch or cover them.
System Malfunction Indicators​
If a symbol appears on your display when using the Digital Rear-view Mirror in digital mirror mode, the system may be malfunctioning. The symbol will disappear in a few seconds. Operate the lever, change to optical mirror mode and have the vehicle inspected by your Toyota dealer.
Maintenance and Cleaning​
Cleaning the Mirror Surface
If the mirror surface is dirty, the image on the display may be difficult to see. Clean the mirror surface gently using a soft dry cloth. Off-road and dirty environments quickly degrade camera lens clarity, so inspect the lens frequently during or after trail work and use a soft, lint-free cloth for gentle cleaning. Avoid abrasive materials that could scratch the coating.
Built-in Camera Washer System
The J250 Land Cruiser includes an integrated rear camera washing system. When you engage reverse gear, you can select the washer icon on screen to spray washer fluid on the camera lens (a convenient feature many new owners don't discover immediately). This is especially useful during muddy or snowy driving when visibility is compromised.
Camera Location
The camera for the Digital Rear-view Mirror is located on the rear of the vehicle. Refer to your vehicle's manual for the specific location on your model.
From J250 Owner Experiences​
Master the Mode Toggle
Community enthusiasts consistently recommend learning to quickly toggle between digital and optical mirror modes. The lever makes this seamless, and many drivers prefer keeping the digital mode for daily parking and backing scenarios while using optical mode on the highway for consistency and stability. Some owners report the digital display can feel less stable than the optical mirror when driving at highway speeds.
Source: Land Cruiser Forum community discussions
Highway Driving Note
Several owners report the digital display can feel less stable than the optical mirror when driving at highway speeds, with some experiencing flickering or sensitivity to reflected light. The manual's warning about checking the difference before driving is reinforced by real-world community experience. Many experienced drivers prefer optical mode at sustained highway speeds for visual consistency.
Known Mirror Vibration at Speed
Multiple J250 owners report that the driver's side mirror exhibits noticeable vibration at highway speeds, with dealers acknowledging the issue as standard operating condition. Some owners have addressed this through aftermarket mirror replacements or dealer service. If you experience this, investigating early can prevent long-term frustration.
Source: Torque News, Land Cruiser community discussions
Regular Lens Cleaning Maintains Image Quality
Off-road and dirty environments quickly degrade camera lens clarity. Community consensus recommends inspecting the lens frequently and using a soft, lint-free cloth for gentle cleaning. Avoid abrasive materials that could scratch the coating. This is particularly important during or after muddy, snowy, or dusty driving conditions.
Source: Toyota Owners Club community discussions
No Recording Capability
Some owners approach the digital rear-view mirror expecting recording functionality like a dashcam. The system provides live video display only (it doesn't record footage in an owner-accessible format, and it's unclear if any data is recorded at all in the vehicle's systems). This distinction matters for those considering the system as backup evidence recording.
Integration with Other Toyota Rear-View Systems
The digital rear-view mirror is part of Toyota's comprehensive rear-visibility ecosystem that includes the Panoramic View Monitor (360-degree camera system) and Rear Cross Traffic Alert. Understanding how these systems complement each other helps optimize rear visibility when backing, parking, and maneuvering.
Source: Toyota Official Digital Mirror Documentation
Camera Protection Considerations
While aftermarket sites advertise protective coatings for camera lenses, the manual explicitly warns against allowing car wax, window cleaner, or glass coating to adhere to the camera. Community consensus recommends avoiding third-party protective coatings and sticking to periodic gentle cleaning with lint-free cloth. For off-road enthusiasts concerned about camera protection during serious trail work, specialized camera relocation kits exist as optional solutions for extreme use cases.
Source: Land Cruiser Forum and manufacturer guidance
  • System overview and operating modes: Pages 167-168
  • Operating procedures and troubleshooting: Pages 168-169
  • Maintenance, camera protection, and safety warnings: Page 172
  • Complete system coverage: Pages 167-172
  • Land Cruiser Forum - Community discussions on digital mirror operation, night driving, maintenance, and mirror adjustments
  • Torque News - J250 mirror vibration reports and dealer acknowledgment
  • Toyota Owners Club - Camera lens cleaning best practices
  • Toyota Official Documentation - System integration with other rear-view systems
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only. When backing or parking, always conduct direct visual checks of your vehicle's surroundings, especially when using the Digital Rear-view Mirror system.
