2024+ Land Cruiser - Disconnecting/Replacing the 12V Battery
Need to replace your 12V battery? Here's how to do it safely, including what you need to know about your hybrid system and how to avoid losing your vehicle settings.
(Reference: Owner's Manual, pg. 619-620, 665)
Battery Replacement, 12V Battery Specifications, Removal and Installation, Terminal Procedure​
WARNING: Terminal Removal Sequence
Always disconnect the negative terminal first. Here's why: if the positive terminal touches any metal nearby, you can get a spark that ignites the hydrogen the battery off-gases. That's serious. Fires, shocks, injuries. So negative first, no exceptions.
WARNING: Avoiding 12V Battery Fires or Explosions
Batteries off-gas hydrogen, which is flammable. Here's how to keep that from becoming dangerous:
  • Connect each jumper cable to the right terminal, and nowhere else, intentionally or accidentally.
  • Keep the + cable away from any other metal (brackets, unpainted surfaces, whatever). It shouldn't touch anything but the battery.
  • Keep the + and - clamps separated. If they touch, you've got an instant short circuit.
  • Do not smoke, use matches, cigarette lighters or allow open flame near the 12-volt battery.
CAUTION: 12V Battery Chemical Hazards
Your battery contains corrosive acid and lead compounds (both dangerous if you're not careful). Here's what to watch for:
  • When working with the 12-volt battery, always wear safety glasses and take care not to allow any 12-volt battery fluids (acid) to come into contact with skin, clothing or the vehicle body.
  • Do not lean over the 12-volt battery.
  • In the event that 12-volt battery fluid comes into contact with the skin or eyes, immediately wash the affected area with water and seek medical attention. Place a wet sponge or cloth over the affected area until medical attention can be received.
  • Always wash your hands after handling the 12-volt battery support, terminals, and other battery-related parts.
  • Do not allow children near the 12-volt battery.
CAUTION: ECU Information Clearing
When you disconnect the battery terminals, the ECU clears its stored information. Before you do this, reach out to your Toyota dealer; they can help you preserve your vehicle settings if that matters to you.
NOTICE: System Initialization Required
If your battery dies or gets removed, the ECU clears its information. Dead battery? Get it checked by your Toyota dealer; they'll make sure everything resets properly and your systems reinitialize.
— Source: Pages 619, 620
Disconnecting the 12V Battery​
Prerequisites & Preparation
Before you start:
  • Park the vehicle on level ground
  • Turn the power switch OFF (preserves system memory mode)
  • Locate the 12V battery (typically under the hood)
  • Gather required tools and equipment
Tools/Materials Needed:
  • Socket wrench set (appropriate size for battery terminal fasteners)
  • Battery terminal pullers (optional but helpful)
  • Safety glasses (REQUIRED)
  • Work gloves
  • Container for drain fluids (if spillage occurs)
  • Wet sponge or cloth (for emergency acid exposure)
Step-by-Step Removal Procedure
  1. Prepare the work area: Ensure proper ventilation (battery emits flammable gases). Keep no smoking, matches, cigarette lighters, or open flame in the work area.
  2. Disconnect the negative terminal FIRST: Locate the negative (-) terminal (typically black cable). Using the appropriate socket wrench, loosen and remove the connector. Move the negative cable away from battery.
  3. Disconnect the positive terminal: Locate the positive (+) terminal (typically red cable). Loosen and remove the connector. Move the cable away and keep it away from metal surfaces.
  4. Remove battery hold-down: If equipped, remove any battery hold-down bracket or clamp. Note the bracket location.
  5. Remove the old battery: Use the handle to lift the battery straight up and out of the battery tray. If no handle, use both hands to carefully lift.
Installing the New 12V Battery​
Battery Specifications & Requirements
Your 2024+ Land Cruiser requires a 12V battery with the following specifications:
SpecificationRequirement
Case SizeLN3 (exact match required)
Capacity (20HR)70Ah or greater
Cold Cranking Amps (CCA)600A or greater
Battery TypeVentilation type calcium battery
Handle RequirementMUST have handle (removal becomes difficult without)
RegulationsMust conform to European regulations
Why These Specifications Matter:
  • Case Size (LN3): If sizes differ, the battery cannot be properly secured in the tray and may shift during driving, risking terminal disconnection.
  • Capacity (70Ah minimum): If capacity is too low, the vehicle may not be able to restart, especially after the battery has discharged.
  • CCA Rating (600A minimum): Lower ratings may result in difficulty starting or hybrid system failure to restart.
— Source: Page 619
Installation Procedure
  1. Position the new battery: Ensure it meets all specifications listed above. Place in tray with terminals pointing in correct direction.
  2. Reinstall hold-down bracket: If removed, secure firmly but do not overtighten.
  3. Reconnect the positive (+) terminal: Connect connector to positive post. Tighten firmly.
  4. Reconnect the negative (-) terminal: Connect connector to negative post. Tighten firmly.
  5. Attach exhaust hose/plug: Use the exhaust hose from the old battery and confirm it is firmly connected to the hole section of the vehicle. If new battery includes an exhaust plug, use it. Consult your Toyota dealer for specific guidance if unclear.
Post-Replacement: System Initialization​
Critical Information After Reconnection
Power Switch Mode Memory: The power switch mode is memorized by the vehicle. When the 12V battery is reconnected, the system will return to the mode it was in before discharge. Before disconnecting the battery, turn the power switch off.
Hybrid System Start Behavior: The hybrid system may not start on the first attempt after battery recharge but will start normally after the second attempt. This is not a malfunction.
Smart Key System: In some cases, it may not be possible to unlock the doors using the smart key system when the 12-volt battery is discharged. Use the wireless remote control or mechanical key.
— Source: Page 619
Systems Requiring Initialization
The following items must be initialized for normal system operation after the 12V battery has been reconnected:
SystemWhen to InitializeReference
Tire Pressure Warning SystemAfter reconnecting or when tire pressure changedPage 551
Maintenance Required MessageAfter maintenance is performedPage 532
Oil Maintenance IndicatorAfter maintenance is performedPage 542
Power Back Door (if equipped)After reconnecting the 12V batteryPage 142
Power WindowWhen functioning abnormallyPage 181
Moon Roof (if equipped)After reconnecting the 12V batteryPage 185
Initialization Steps: Refer to the manual page numbers listed above for detailed initialization procedures specific to each system.
— Source: Page 665
Community Best Practices​
Preserve Vehicle Memory Settings During Battery Swap
Keep 12V power to the vehicle during replacement using a booster pack or even a 9V battery (connected to preserve power to ECU). This prevents loss of radio presets, security codes, and other learned settings. This is especially useful if you have security codes set up that you'd prefer not to reset.
Battery Tender for Extended Storage
For extended periods when the vehicle won't be driven, use a battery tender (4A recommended, 5A or less per manual) connected to the jumper positive terminal and bracket negative. This prevents battery discharge from the constant DC to DC inverter draw that occurs even when the vehicle is parked.
Consider AGM Battery Upgrades
Many drop-in AGM (Absorbed Glass Mat) batteries work well with the Land Cruiser's DC/DC charger. AGM batteries offer better deep cycle performance and can prevent permanent damage from discharge that would affect traditional lead-acid batteries. If you choose this route, verify voltage compatibility before purchasing.
Prevent Battery Terminal Corrosion with Protective Coating
Apply battery terminal grease to terminals after reconnection to create a protective barrier against moisture, acid, and dirt. This simple step can extend your battery's lifespan.
Use Felt Battery Washers
Felt washers (chemically treated to neutralize acid) are effective for preventing corrosion by absorbing battery acid vapors before they reach terminals.
Clean Corroded Terminals with Baking Soda and Water
Mix baking soda and water to pancake-batter consistency and apply to terminals. The mixture slowly dissolves corrosion. Safe, inexpensive, and effective.
Regular Terminal Inspection Schedule
Inspect battery terminals every 3-6 months for corrosion signs. Early detection prevents electrical issues and extends battery life.
— Community sources: Land Cruiser Forum (landcruiserforum.com), AMSOIL, AutoZone
Forgetting to Note Security Code Before Disconnect
Before disconnecting the battery, document your head unit security code or disable the security feature. After reconnection, you'll need to re-enter the code. Forgetting it locks you out of head unit operations.
Ignoring Power Rear Hatch Recalibration
After battery reconnection, the power rear hatch (if equipped) must be manually closed to recalibrate the system. Skipping this step causes hatch malfunction.
Using Incompatible Aftermarket Batteries
The Land Cruiser uses a DC to DC inverter (not traditional alternator) to charge the 12V battery. Some aftermarket batteries specify different voltage ranges. Verify compatibility before purchasing.
Allowing AGM Battery Voltage to Drop Below 12.4V
If using an AGM battery, avoid deep discharge below 12.4V, as this causes sulfation and permanent battery damage. The Land Cruiser's constant DC/DC inverter draw can cause this during extended idle periods.
Not Recognizing Hybrid Charging System Differences
Your J250 Land Cruiser charges the 12V battery through a DC to DC inverter from the hybrid traction battery, not a traditional alternator. The vehicle should be driven at least once or twice per month to maintain charge. Extended periods require a battery tender.
— Community sources: Land Cruiser Forum discussions
Hybrid System Context​
Unlike conventional vehicles with alternators, your J250 Land Cruiser uses a DC to DC inverter from the hybrid traction battery to charge the 12V battery. This means:
  • Constant (but low) draw on 12V system even when parked
  • Vehicle needs regular driving (at least 1-2x per month) to maintain charge
  • Extended storage requires a battery tender, not just disconnection
Understanding this difference helps explain why certain precautions are necessary and why your battery management differs from conventional vehicles.
— Community expertise: Land Cruiser Forum hybrid system discussions
When to Contact Your Toyota Dealer​
Contact your Toyota dealer if:
  • You are unsure about the battery specifications or type
  • You plan to remove the battery terminals (dealer can preserve vehicle settings)
  • The hybrid system does not start after battery reconnection
  • Warning lights or error messages appear after battery replacement
  • You need guidance on system initialization procedures
  • You have questions about ECU information preservation
  • Removal and installation procedure: Pages 619-620
  • Safety precautions: Page 620 (WARNING section)
  • System initialization requirements: Page 665
  • Land Cruiser Forum (landcruiserforum.com) - Owner community discussions
  • AMSOIL Blog - Battery maintenance and corrosion prevention
  • AutoZone DIY - Battery corrosion cleaning procedures
  • Family Handyman - Battery terminal maintenance
  • Various automotive publications - AGM battery specifications and hybrid charging systems
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only. When in doubt about battery terminals or ECU settings, contact your authorized Toyota dealer to preserve your vehicle's warranty and learned settings.
For complete instructions on system-specific initialization procedures, refer to your owner's manual pages 142, 181, 185, 532, 542, and 551 as noted in the initialization table above.
