This thread consolidates information from pages 444-446 of your 2024+ Land Cruiser owner's manual, covering the Downhill Assist Control system - a critical tool for safe, controlled descents on steep terrain.
Downhill Assist Control (DAC) is a specialized driving support system designed to help maintain stable, controlled descent on steep downhill terrain. The system automatically applies the brakes to maintain a set speed, allowing you to focus on vehicle direction and road hazards rather than brake control.
The system helps prevent excessive speed on steep downhill slopes and operates when your vehicle is traveling under 18 mph (30 km/h) with the accelerator and brake pedals released and the transfer mode is in H4.
WARNING
Do not rely overmuch on the downhill assist control system. This function does not extend the vehicle's performance limitations. Always thoroughly check the road conditions, and drive safely.
(Source: Page 444)
WARNING
The system may not operate on the following surfaces, which may lead to an accident causing death or serious injury:
(Source: Page 446)
Activation and Speed Setting
To activate DAC and set your desired speed:
When using the MODE SELECT switch:
When the system is active, the slip indicator light will flash on the dashboard and the stop lights/high mounted stop lights will illuminate. A sound may also occur during the operation. This does not indicate a malfunction.
When DAC Will Operate
The system automatically engages when ALL of the following conditions are met:
When DAC Will NOT Operate
The system will not engage or will deactivate in these situations:
Special Note: If the shift lever is in Neutral, the indicator will flash as an alert to the driver, but the system will still operate while flashing.
Deactivating the System
To turn off Downhill Assist Control:
If you use DAC continuously on extended steep descents, the brake actuator can overheat:
Warning Signs:
What to Do:
Stop using DAC immediately and continue driving normally (the vehicle is fully drivable). Wait until the indicator stays on and the warning message clears. The system will be ready to use again after cooling.
DAC relies on the brake system for controlled descent. Continuous operation on long downhill grades generates heat. When the brake actuator reaches its thermal limit, the system automatically protects itself by stopping operation. This is a safety feature, not a malfunction.
When using DAC, you may experience the following. None of these indicate a malfunction:
Sounds:
Vibrations:
Have your vehicle inspected by a Toyota dealer immediately if you experience any of these conditions:
Community feedback confirms that DAC is a valuable addition to the Land Cruiser's 4WD system:
Brake System Protection: The key advantage is eliminating the need for constant brake pedal input on extended descents. This is important because riding your brakes for a long period can overheat the brakes and reduce their effectiveness. DAC preserves brake system health through distributed wheel braking.
Integration with 4WD Systems: DAC works seamlessly with other Land Cruiser off-road systems:
Community experience confirms DAC effectiveness varies by terrain:
Where DAC Excels:
Where to Use Traditional Braking:
J250 owners with off-road plans specifically mention looking forward to testing DAC on upcoming adventures. The feature is universally viewed as valuable for serious terrain, particularly for those doing extended overland travel where brake system preservation matters.
The complete specifications and procedures for Downhill Assist Control can be found on pages 444-446 of your 2024+ Land Cruiser Owner's Manual. These pages provide:
Keep your physical or digital manual handy for reference when learning any new vehicle system.
Manual Source:
Important Disclaimer:
This thread is compiled from your vehicle's official owner's manual and community forums for informational purposes. While every effort has been made to provide accurate information, you should always refer to your vehicle's official owner's manual for the most authoritative guidance. Vehicle specifications, procedures, and safety information change with model year updates and regional variations.
Always verify any technical information against your specific manual before performing any procedure. If you're uncertain about any aspect of your vehicle's systems, consult a Toyota dealer.
The information provided here represents the knowledge of Toyota enthusiasts and is not a substitute for professional service or official Toyota guidance.
DAC Operation, Downhill Assist Control, Speed Control, Manual Guide, Off-Road System
What is Downhill Assist Control?
WARNING
(Source: Page 444)
WARNING
- Slippery surfaces such as wet or muddy roads
- Icy surface
- Unpaved roads
(Source: Page 446)
Activating and Operating DAC
- Press the DAC/CRAWL switch located on the dashboard
- The Downhill Assist Control system indicator will illuminate
- Use the MODE SELECT switch to set desired speed (Approximately 3 to 18 mph / 4 to 30 km/h)
- The set speed is displayed on the multi-information display
- Rotate up to increase speed
- Rotate down to decrease speed
- Vehicle speed is under 18 mph (30 km/h)
- Accelerator pedal is released
- Brake pedal is released
- Shift lever is in a position other than P (Park) or N (Neutral)
- Transfer case is in H4 (High 4-Wheel Drive)
- Rear differential is NOT locked (if equipped)
- Transfer case in L4 (Low 4-Wheel Drive): DAC requires H4 mode
- Rear differential locked (if equipped): system disables
- Shift lever in P or N: transmission position prevents operation
- Vehicle speed exceeds 18 mph (30 km/h): speed too high for system
- Brake system overheating: thermal protection disables system
- Press the DAC/CRAWL switch again (with indicator illuminated)
- The indicator will flash as the system gradually ceases operation
- The indicator turns off when the system is fully disengaged
Thermal Performance and Safety Limits
Warning Signs:
- A buzzer will sound
- The Downhill Assist Control system indicator will start flashing
- The multi-information display will show "Traction Control Turned OFF"
What to Do:
Normal Operating Sounds and Vibrations
Sounds:
- Operating noise from the engine compartment while system is active
- Sound from the engine compartment when the hybrid system starts
- Motor sound after the vehicle comes to a complete stop
Vibrations:
- Vibrations felt through the vehicle body during operation
- Vibrations felt through the steering wheel
System Malfunction Indicators
- The slip indicator light illuminates (constant, not flashing)
- DAC indicator does not illuminate when the power switch is turned to ON
- DAC indicator does not illuminate when you press the DAC/CRAWL switch
- The multi-information display does not show an indicator for Multi-Terrain Select even though the mode is selected
Real-World Tips and Community Context
Why DAC Matters for J250 Owners
- H4/L4 Mode: DAC operates in H4 (High 4-Wheel Drive) mode. When you switch to L4 for extreme terrain, DAC disables automatically, allowing you to use traditional braking for descents where precision driver control is critical.
- Crawl Control Relationship: Community users describe Crawl Control as "DAC on steroids": it gives you more control over speed adjustments and works on very rough terrain, but requires more driver involvement. Both systems are complementary tools for different terrain scenarios.
- Differential Locking: DAC automatically disables when rear differentials are locked. When locked differentials are engaged for maximum traction in climbing, DAC's precision brake modulation is bypassed to preserve traction.
Real-World Terrain Applications
Where DAC Excels:
- Rocky Technical Descents: On steep grades with manageable traction, DAC holds the vehicle to a slow, steady crawl down steep banks
- Winter and Snow Conditions: "The first time you try backing down a steep, slippery hill in the snow will convince you of its usefulness" - the system's precision wheel braking is particularly effective on reduced-grip surfaces
- Extended Descents: Prevents brake fade and thermal damage on long mountain passes in H4 mode
- Extreme slopes in L4 mode: use full driver control
- Loose or rocky surfaces where traditional braking provides better feedback
- When differentials are locked: DAC disables automatically
- In emergency situations: driver has instantaneous brake response
Community Consensus
- System activation procedures
- Operating conditions and limitations
- Safety precautions and warnings
- Thermal protection thresholds
- Malfunction indicators
Source Attribution and Disclaimer
Manual Source:
- 2024+ Toyota Land Cruiser Owner's Manual, pages 444-446
- Section: Using the Driving Support Systems
- Topic: Downhill Assist Control System
- Land Cruiser Forum (landcruiserforum.com) — J250 owner discussions and experiences
- Land Cruiser Club (landcruiserclub.net) — Community guidance on DAC usage
- IH8MUD.com Forum — Toyota off-road specialist community
- Toyota UK Magazine — Official educational content about DAC operation
- Your Mechanic — Professional automotive explanations
