Your Land Cruiser's driver monitor is constantly watching, tracking where you're looking, your hand position, and whether you're paying attention. It's a key part of Toyota Safety Sense 3.0, and understanding how it works will help you optimize its performance. (Reference: Owner's Manual, pg. 191, 263-264)
WARNING: Driver Monitor Safety Limitations
Remember: the driver monitor isn't designed to prevent careless driving or poor posture. Stay focused on the road around you to drive safely.
Source: Page 264
WARNING: Drowsiness Not Reduced
The driver monitor cannot reduce drowsiness. If you feel unable to concentrate or drowsy, take a break and sleep to ensure safe driving.
Source: Page 264
CAUTION: Proper Seating Position Critical
When the position of the steering wheel/driver's seat is too high or too low, the driver monitor camera may not be able to recognize the whole face of the driver which can limit feature functionality and possibly trigger an alarm. Adjust the steering wheel/seat position to achieve a proper seating position where the whole meter is visible. Confirm proper seat belt routing, head restraint positioning, and appropriate distance from the steering wheel and frontal air-bag as described in this manual. If the alarm continues even after making the recommended adjustments, contact your Toyota dealer.
Source: Page 264
CAUTION: Unobstructed View Required
The driver monitor needs an unobstructed view of your face to operate properly. If your steering column or seat position is too high or too low, or if anything obstructs the camera's view, some driving support systems may not work, or you may see a warning message.
Source: Page 263
Your Land Cruiser's driver monitor is part of Toyota Safety Sense 3.0. During driving, it continuously:
The system continuously monitors these factors to support several TSS 3.0 features including Lane Change Assist (LCA), Lane Departure Alert (LDA), Proactive Driving Assist (PDA), Dynamic Radar Cruise Control (DRCC), and the Emergency Driving Stop System.
The system alerts you when:
Inattention to the Road: If the system sees you're not paying attention to the road ahead, it buzzes and displays a message.
Eyes Closed: When your eyes close, the system alerts you.
Poor Driving Posture or Face Detection Issues: When your face can't be detected or your posture is off, the system alerts you. This happens when your head's at an angle the camera can't see, obstructions block the view, or your seat/steering wheel position is wrong.
For the driver monitor camera to function properly, it requires a clear, unobstructed view of your face. The critical setup factors are:
If your steering column or seat position is too high or too low, the camera may not see your entire face, which can limit or disable some TSS 3.0 features, trigger false warning messages, or reduce system effectiveness in detecting inattention.
Take time to set your driving position for both comfort and to ensure the driver monitor camera has a clear view of your face. If warning messages persist even after adjustment, contact your Toyota dealer to verify camera alignment.
Beyond driver attention monitoring, the driver monitor camera also serves as an individual identification device for your vehicle's personalized My Settings profile system.
How Face Identification Works:
When enabled, the system digitizes your facial traits during initial setup, stores this digitized information in a vehicle computer, and uses it to identify you when you enter the vehicle. The system prioritizes face identification over other authentication methods (electronic key, digital key, Bluetooth device).
Toyota has implemented strict data protections for the face identification system:
What IS Stored:
Digitized facial information (mathematical representation of your face)
What IS NOT Stored:
Actual face images or photographs, video recordings of your face, or audio/voice recordings
Data Usage:
Digitized face information is used only for identification within My Settings, cannot be decoded, and will not be disclosed or provided to third parties. You can delete your face information at any time.
Your driver monitor supports several other Toyota Safety Sense 3.0 features. These systems may show reduced availability or warnings if the monitor can't get a proper view:
If you see warning messages related to any of these systems, check your seating position and steering wheel adjustment.
Owners have found practical tips for getting the best performance from your driver monitor:
Settings Customization:
The driver monitor system has toggleable settings. Navigate to your vehicle's settings menu and select "Driver Monitor Settings" where you can independently turn off "Driver Monitor Alert" and "DMC Recording" to customize how the system responds to you. Traffic Jam Assist and other TSS 3.0 features continue working even with driver monitor recording disabled, allowing you to disable recording features if privacy is a concern while maintaining access to other safety features.
My Settings Profile Persistence:
You can permanently save your driver monitor alert preferences by changing the setting from "default" to "my settings." The vehicle will remember your preference automatically when you enter the vehicle.
Camera Location:
The camera sits above your steering wheel, in front of the digital cluster. Knowing where it is helps you position your seat correctly.
Hand Position Sensitivity:
Driving with your left hand at 12 o'clock on the steering wheel can constantly trigger driver monitor alerts, even when you ARE paying attention. The system reads hand position as part of attention detection. Hands at top-center are less visible to the camera than hands on the sides. Adjust your grip to 9/3 o'clock position or higher positions (11/1) if experiencing false alerts.
Expecting to Completely Disable Monitoring:
Some owners report receiving monitoring alerts even after setting both "Driver Monitor Alert" and "DMC Recording" to OFF. The camera may still be detecting and evaluating, as some TSS 3.0 functions require active monitoring. Use the "My Settings" profile to set your permanent preferences rather than trying to turn off the system completely.
Glancing Away from the Road:
The system is sensitive to where you're looking. Looking at other cars in a parking lot or down at instruments can trigger an alert. This is intentional design behavior for safety, not a bug. The camera tracks eye gaze, not just head position. If you find this intrusive, use the settings to adjust alert sensitivity.
Slouching or Reclined Seating Position:
Drivers report frequent alerts when the seat is reclined or when posture leans back from the camera's expected position. The camera needs a clear view of your entire face. Reclined seats change the angle and can make you harder to detect. Adjust your seat position (height, recline, fore-aft) to sit more upright if receiving position-based alerts.
Community members describe the driver attention system as designed to be very aware of driver alertness. It's not a passive observer; it actively monitors where you're looking, hand position, and posture. This is by design for safety reasons, but can feel intrusive to drivers who aren't expecting this level of monitoring. Understand that this sensitivity is intentional and serves to keep you engaged with the driving task.
Trim-Level Availability:
The driver monitor camera is part of the Premium Package on the Land Cruiser trim, but is NOT standard on all trims. It's absent from the 1958 trim and First Edition trim. This affects which owners will have this feature.
Relationship to Traffic Jam Assist:
The system works closely with Traffic Jam Assist. When TJA is activated, the system specifically asks if you want to be recorded, reinforcing that the driver monitor is actively capturing attention data for safety-critical systems.
Can I disable face identification?
Yes. You have full control over whether to use this feature. It's entirely optional through My Settings.
Why does it alert when I'm wearing glasses or sunglasses?
The camera reads facial features and eye position. Heavy-frame glasses or reflective sunglasses can sometimes obscure the camera's view. Contact lens wearers and clear glasses typically don't affect detection.
Does poor lighting affect the system?
The camera includes infrared detection, so it works in darkness, but very bright sunlight reflecting off glasses can occasionally cause detection issues.
Why is my camera so sensitive to my seating position?
The manual's emphasis on requiring an unobstructed view isn't theoretical. Owners report genuine issues when glasses, head restraint position, or seat angle obstruct the camera's view. This directly impacts TSS 3.0 feature availability.
What if I'm doing off-road driving?
Remember that the driver monitor still requires a clear view of your face. Adjusting your seating position or head position for off-road visibility may trigger warnings if the camera loses sight of your face. This is normal. The warnings are reminding you to maintain attention on the trail.
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only and does not replace official Toyota documentation. If you have questions about your driver monitor system, consult your owner's manual or contact your Toyota dealer.
Driver Monitor Camera, Attention Detection, Face Recognition, Camera Positioning
Source: Page 264
Source: Page 264
Source: Page 264
Source: Page 263
How the Driver Monitor Works
- Detects the position and direction your head is facing
- Determines whether your eyes are open or closed
- Assesses if you are checking your surroundings
- Evaluates whether you are in a position to perform driving operations
Warning Functions
Camera Positioning and Setup Requirements
- Steering wheel position (height and reach adjustment)
- Driver's seat position (height, fore-aft adjustment, and recline angle)
- Seat belt routing (must not obscure face)
- Head restraint positioning (must not block camera view)
- Distance from steering wheel and frontal airbag
Face Identification System and My Settings Integration
Privacy and Data Handling
What IS Stored:
What IS NOT Stored:
Data Usage:
Integration with Other TSS 3.0 Systems
- Lane Change Assist (LCA): Requires driver attention detection
- Lane Departure Alert (LDA): May display reduced alert if camera has impaired view
- Proactive Driving Assist (PDA): Relies on attention assessment
- Dynamic Radar Cruise Control (DRCC): Uses attention data for safety decisions
- Emergency Driving Stop System: Requires proper driver attention detection
Real-World Owner Tips and Community Context
Camera Location:
System Philosophy
Common Questions
- Page 191 - Face Authentication System and My Settings
- Pages 263-264 - Driver Monitor Camera System, operation, and warnings
- Land Cruiser Forum (landcruiserforum.com) - Community tips and real-world experiences
- IH8MUD Forum (forum.ih8mud.com) - Toyota off-road community
- 250landcruiser.com - J250 enthusiast community
- Toyota Official Documentation (toyota.com) - Safety system specifications
