2024+ Land Cruiser - Dynamic Radar Cruise Control (DRCC)
Want your Land Cruiser to handle highway driving for you? Dynamic Radar Cruise Control (DRCC) uses radar to automatically maintain your set distance from the vehicle ahead. Here's everything you need to know to get the most out of this system.
(Reference: Owner's Manual, pg. 304-309)
Dynamic Radar Cruise Control, DRCC Operation, Cruise Control Settings, Adaptive Cruise Features​
WARNING - For Safe Use
Driving safely is solely the responsibility of the driver. Do not overly rely on this system, and pay careful attention to the surrounding conditions in order to ensure safe driving.
The dynamic radar cruise control provides driving assistance to reduce the driver's burden. However, there are limitations to the assistance provided. Read the following items carefully. Do not overly rely on this system and always drive carefully.
Important Safety Statements
  • Set the speed appropriately according to the speed limit, traffic flow, road conditions, weather conditions, etc. The driver is responsible for confirming the set speed.
  • Vehicle Detection May Differ - Even if the system is operating correctly, the condition of a preceding vehicle as recognized by the driver and detected by the system may differ. Therefore, it is necessary for the driver to pay attention, assess risks, and ensure safety. Over-reliance on this system to drive the vehicle safely may lead to an accident resulting in death or serious injury.
  • Precautions for the Driving Assist Systems - Observe the following precautions, as there are limitations to the assistance provided by the system. Over-reliance on this system may lead to an accident resulting in death or serious injury.
  • What DRCC Can and Cannot Do - The dynamic radar cruise control is only intended to help the driver in determining the distance between the driver's own vehicle and a designated preceding vehicle. It is not a system which allows for careless or inattentive driving, and is not a system which assists in poor visibility conditions. The driver must pay attention to their surroundings, even when the vehicle stops.
  • Driver Judgment Required - You are responsible for safe driving at all times.
What Is Dynamic Radar Cruise Control?​
DRCC is your Land Cruiser's radar-based system that automatically keeps a safe distance from the vehicle ahead. It reduces highway fatigue by handling acceleration and braking for you - you set the speed and distance, and the system takes it from there.
Recommended Use: Use the dynamic radar cruise control only on highways and expressways.
How to Activate and Set Your Cruising Speed​
Prerequisites
To use DRCC, you need:
  • Vehicle must be in D (Drive) position
  • Minimum activation speed: approximately 20 mph (30 km/h) or more
  • Highway or expressway driving (per manual recommendation)
  • Preceding vehicle must be detected for full functionality
Step-by-Step Activation
1. Reach Your Desired Speed
Using the accelerator pedal, accelerate or decelerate to the vehicle speed you want to maintain (approximately 20 mph [30 km/h] or more).
2. Press the Driving Assist Switch
Once at your desired speed, press the driving assist switch. The set vehicle speed will be displayed on your multi-information display.
3. Release the Switch
The vehicle speed at the moment you release the switch becomes your set vehicle speed. DRCC is now active.
Adjusting Your Set Vehicle Speed​
Method 1: Using the (+) and (−) Switches (Recommended for Most Adjustments)
The "+" and "−" switches on your steering wheel let you fine-tune your set speed up or down.
Short Press Adjustment:
  • Except for Canada: Increases or decreases by 1 mph (1.6 km/h) each time you press the switch
  • For Canada: By 1 km/h (0.6 mph) or 1 mph (1.6 km/h) each time you press the switch
Use short presses for precise speed adjustments (e.g., from 65 to 66 mph).
Long Press Adjustment (Hold Until Desired Speed Reached):
  • Except for Canada: Increases or decreases in 1 mph (1.6 km/h) increments continuously while the switch is pressed and held
  • For Canada: Increases or decreases in 5 km/h (3.1 mph) or 5 mph (8 km/h) increments continuously while the switch is pressed and held
Use long press for faster adjustments (e.g., dropping from 75 to 55 mph quickly).
Method 2: Using the Accelerator Pedal
You can also increase your set speed using the accelerator pedal for a more traditional approach:
To Increase Set Speed via Pedal:
  1. Depress the accelerator pedal to accelerate the vehicle to your desired vehicle speed
  2. Press the "+" switch
This method is useful if you want to accelerate to pass a vehicle and then lock in that new, higher set speed quickly.
Vehicle-to-Vehicle Distance Settings​
DRCC lets you choose how far behind the preceding vehicle you want to maintain. There are four distance settings:
SettingDistance NameApproximate Distance (at 60 mph / 100 km/h)
1Extra LongApproximately 200 ft. (60 m)
2LongApproximately 145 ft. (45 m)
3MediumApproximately 100 ft. (30 m)
4ShortApproximately 85 ft. (25 m)
How It Works:
  • Each time you press the vehicle-to-vehicle distance switch, the setting changes to the next level
  • The actual distance varies in accordance with the vehicle speed (proportional spacing)
  • If a preceding vehicle is detected, the preceding vehicle mark [A] will be displayed
  • When no preceding vehicle is detected, the distance indicator shows no target marker
Important: When the vehicle is stopped by system control, it will be stopped at a certain distance from the preceding vehicle, depending on the situation, regardless of your setting.
Canceling and Resuming DRCC​
Canceling Control
Press the Cancel Switch or Driving Assist Switch to cancel DRCC control immediately.
Control will also be canceled if the brake pedal is depressed.
Exception: If the vehicle has been stopped by system control (DRCC applied braking to match a stopped vehicle ahead), depressing the brake pedal will NOT cancel control. You must use the cancel switch or driving assist switch.
Resuming Control
Press the "RES" (Resume) Switch to resume DRCC at your previously set speed.
DRCC will resume at whatever speed you originally set. You don't need to reset it.
Operating Conditions​
Required Conditions for DRCC to Work:
  • The D shift position is selected
  • The desired set speed can be set when the vehicle speed is approximately 20 mph (30 km/h) or more
What If You Set Speed Too Low?
If the vehicle speed is set while driving at below approximately 20 mph (30 km/h), the set vehicle speed will be approximately 20 mph (30 km/h). DRCC has a minimum threshold to ensure safe highway operation.
Limitations and Additional Safety Considerations
For detailed information on conditions under which DRCC may not operate correctly, consult Page 310 of your Toyota Land Cruiser Owner's Manual.
DRCC Cannot Reliably Detect:
  • Stationary objects
  • Vehicles in certain weather conditions (heavy rain, fog, snow)
  • Vehicles at extreme angles (sharp lane changes)
  • Pedestrians or cyclists (Pre-Collision System handles those)
Pro Tips from the J250 Community​
Optimize Following Distance for Your Comfort Level
New DRCC users should start with the maximum following distance (Extra Long / Setting 1) while learning the system. Once comfortable with how the system behaves in various traffic conditions, adjust to your preferred distance. Real-world experience from Land Cruiser Forum users shows this approach builds confidence quickly.
Use Long-Press Switch Adjustment for Faster Speed Changes
Hold the (+) or (−) switch to rapidly increase or decrease your set speed, rather than tapping repeatedly. This works smoothly and provides quicker adjustments when needed, as noted by Toyota dealership instructors.
DRCC Can Improve Fuel Economy on Long Highway Drives
The system optimizes speed adjustments and reduces unnecessary acceleration/braking cycles. Maintaining steady cruise on long interstate drives with DRCC active can contribute to better overall fuel economy than manual driving.
The LC 250 DRCC Detects Multiple Vehicles
Unlike earlier Land Cruiser generations, the J250 Land Cruiser's TSS 3.0 DRCC can detect more than one preceding vehicle and vehicles in adjacent lanes. This enables smoother, more natural speed adjustments when you change lanes.
Radar Calibration After Service
If you have windshield replacement, bumper repair, or front-end collision repair, the TSS 3.0 radar calibration can drift. Have a Toyota dealer perform TSS calibration (usually via diagnostic scan) after any front-end service to ensure DRCC operates accurately. This is a worthwhile investment for continued reliable operation.
Neglecting the Radar Sensor in Bad Weather
The millimeter-wave radar is mounted as a flat plate on the front grille. In snow, rain, or dusty conditions, buildup of mud, snow, or debris blocks the sensor and causes DRCC to stop working. Periodically check and clean the front grille area, especially before winter driving or off-road trips.
Using DRCC in Narrow, Winding Roads
DRCC cannot operate properly on sharp curves or narrow-radius turns. The radar signal reflects inconsistently, and the system may disengage unexpectedly. Manual steering input is safer on mountain passes and winding terrain.
Setting Following Distance Too Short in Heavy Traffic
DRCC with shorter distance settings (Medium or Short) produces jarring acceleration and hard braking in stop-and-go traffic. Highway speeds tolerate shorter distances smoothly, but urban/suburban traffic with frequent stops is better handled with Long or Extra Long distance.
Over-Relying on TSS 3.0 Before Fully Understanding It
Forum consensus recommends new J250 owners disable TSS 3.0 features entirely when first acquiring the vehicle. Drive it as a normal car, learn the basic controls, then slowly enable each feature (DRCC, PCS, LTA, etc.) one at a time. Understanding what each system does prevents misuse and dangerous situations.
Where DRCC Excels and Where to Use Manual Control​
DRCC Performs Best On:
  • Interstate highways with steady traffic flow (70+ mph)
  • Long-distance driving where driver fatigue is a concern
  • Traffic with predictable spacing and speeds
  • Highway cruising (70-75 mph steady traffic)
When to Take Manual Control:
  • Heavy city traffic (too many stop-start cycles)
  • Mountain passes and winding roads (curves confuse radar)
  • Poor visibility conditions
  • Parking lots or low-speed maneuvering (system disengages below ~20 mph anyway)
Full-Speed Range Performance
The system operates smoothly across the full speed range from approximately 20 mph to 110 mph. The J250 Land Cruiser's TSS 3.0 implementation includes enhanced algorithms for smoother transitions, particularly when entering/exiting following mode or when multiple vehicles are detected.
  • System overview and safety precautions: Page 304
  • Speed setting and adjustment procedures: Page 308
  • Advanced control and distance settings: Page 309
  • Operating limitations: Page 310
  • Land Cruiser Forum (landcruiserforum.com) - Active J250 owner community
  • IH8MUD Forum (forum.ih8mud.com) - Established Toyota off-road community
  • Earnhardt Toyota - DRCC operational guidance
  • Toyota dealership resources
  • Toyota Service Documentation
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the J250 owner community and authoritative sources. Always follow your official owner's manual for warranty compliance and safety. This is a reference guide only. Driving safely is your responsibility. Do not overly rely on any driver assistance system. Pay attention to your surroundings at all times.
