2024+ Land Cruiser - Front and Rear Differential Fluids
Keeping your differential fluid in spec ensures 4WD reliability and long-term protection. Here's what the manual specifies for your Land Cruiser. (Reference: Owner's Manual, pg. 633)
Differential Fluid Capacity, Type, Viscosity, GL-5 Classification​
DifferentialCapacity (US Quarts)Capacity (Liters)Capacity (Imperial)
Front1.29 qt.1.22 L1.07 Imp.qt.
Rear5.94 qt.5.62 L4.94 Imp.qt.
Source: Owner's Manual page 633
Fluid Type and Viscosity
  • Approved Fluid: Toyota Genuine Differential Gear Oil LT
  • Viscosity: 75W-85 GL-5 or equivalent
  • OEM Requirement: Use Toyota approved fluid or an equivalent of matching quality
Important Notes​
Your Toyota vehicle is filled with Toyota Genuine Differential Gear Oil at the factory.
Replacement Information: The fluid capacity figures shown above are reference values. If replacement is needed, a Toyota dealer can handle this.
For professional service work, a Toyota dealer can help with this.
Understanding Your Differential Fluid​
Why 75W-85 GL-5?
The Land Cruiser's differentials, especially the locking rear differential, require 75W-85 GL-5 specification for:
  • Cold Temperature Protection: The 75W rating ensures quick lubrication at startup
  • High-Temperature Performance: The 85 rating maintains film strength at operating temperature
  • Gear Protection: GL-5 classification provides anti-scuff protection required for hypoid differential gears
  • Locking Mechanism Support: Adequate viscosity supports the electronic and mechanical locking functions
Front vs. Rear Capacity Difference
The rear differential holds significantly more fluid (5.94 qt vs. 1.29 qt) because:
  • Rear differential carries greater torque load in 4WD operation
  • Larger capacity improves thermal management for extreme off-road use
  • Mechanical locking mechanism requires adequate fluid for cooling and operation
Equivalent Fluid Selection
While the manual permits equivalent fluids, "matching quality" is non-negotiable. Any substitute must:
  • Meet GL-5 classification (NOT GL-4 or GL-3)
  • Maintain 75W-85 viscosity rating
  • Be synthetic or synthetic-blend for full-time 4WD reliability
Improper fluid selection can compromise differential protection during high-torque 4WD operation.
Recommended Products​
  • Toyota Genuine 75W-85 GL-5 Differential Fluid
  • Differential Fluid Drain Plug Gasket Kit
  • Differential Fluid Drain Pan
  • Specifications: Page 633, Section 8-1 (Vehicle Specifications)
This guide pulls directly from your 2024+ Land Cruiser owner's manual, with extra context on why these specs matter. Keep your manual handy for service details - and if you need fluid work done, a Toyota shop can handle it.
