2024+ Land Cruiser - Heated and Ventilated Seats
Want to understand heated and ventilated seats on your J250? Here's the complete guide to operation, comfort optimization, and practical insights from owners. (Reference: Owner's Manual, pages 479-480)
Heated Seats, Ventilated Seats, Seat Controls, Operation Guide​
Important Safety Note: Heated seats can get hot enough to cause burns if misused. Here's what to know:
  • Do not cover the seat with a blanket or cushion when using the seat heater.
  • Do not use seat heater more than necessary.
Source: Page 479
Overview​
Your 2024+ Land Cruiser (J250) has heated front seats and (on most trims) ventilated front seats as part of the climate control system. These features provide comfort in cold and warm weather conditions. Both the heated and ventilated functions are controlled through identical switch mechanisms with three intensity levels.
The system is integrated with your vehicle's air conditioning system. When ventilation is set to its highest level, the seat ventilator fan speed will automatically adjust based on the air conditioning system's fan speed, optimizing both comfort and energy efficiency for the hybrid system.
Heated Seats Operation​
Front Seats (Driver and Passenger)
  1. Locate the heated seat switch on your front seat
  2. Press the switch to turn the heater ON
  3. Level indicators will illuminate to show the current heat level
  4. Each time you press the switch, the operation changes through these levels:
    • Hi (3 segments lit) - Maximum heat
    • Mid (2 segments lit) — Medium heat
    • Lo (1 segment lit) — Low heat
    • Off (no segments lit) — Heat disabled
Optimal Usage
  • First Cold Start: Start at Lo or Mid level to avoid sudden high temperature
  • Long Drives: Use Lo or Mid for extended use to maintain comfort without excessive heat
  • Passenger Comfort: Both driver and passenger seats operate independently. Adjust each separately
  • Battery Awareness: On J250 hybrids, heated seats draw from the 12V auxiliary system; using lower heat levels for non-essential warmth helps battery management
Second Row Seats (Outboard Seats - If Equipped)
Some Land Cruiser trims include heated second-row outboard seats:
  1. Locate the heated seat switch on the outboard second-row seat bolster
  2. Press the switch to activate heating
  3. Cycle through the same four levels: Hi → Mid → Lo → Off
  4. Each occupant controls their own seat independently
Note: Not all trims include rear heated seats. Check your seat bolsters for switches.
Ventilated Seats Operation​
  1. Locate the ventilated seat switch on your front seat
  2. Press the switch to turn the ventilator ON
  3. Level indicators will illuminate to show the current ventilation level
    • Hi (3 segments lit) — Maximum ventilation/cooling airflow
    • Mid (2 segments lit) — Medium ventilation
    • Lo (1 segment lit) — Low ventilation
    • Off (no segments lit) — Ventilation disabled
AC System-Linked Control
When you set seat ventilation to Hi level, the seat ventilator fan speed automatically increases based on the air conditioning system's fan speed. This means in warm weather with strong AC demand, your seat ventilation will automatically intensify, providing enhanced comfort without manual adjustment.
Optimal Usage
  • Warm Weather: Start at Lo or Mid to avoid excessive seat cooling
  • Long Drives: Use Mid level for sustained comfort
  • AC System Efficiency: The linked control with AC system optimizes energy use. The ventilator speed adjusts to match overall cooling demand
  • Hybrid Context: Ventilated seats on the J250 work with your hybrid system's climate management for balanced energy consumption
Some Land Cruiser trims include ventilated second-row outboard seats:
  1. Locate the ventilated seat switch on the outboard second-row seat bolster
  2. Press the switch to activate ventilation
Note: Not all trims include rear ventilated seats. Check your seat bolsters for switches.
Control Features Summary​
FeatureFront SeatsRear OutboardControl LevelsRequirement
Heated seatsStandardOptionalHi/Mid/Lo/OffPower switch ON
Ventilated seatsStandardOptionalHi/Mid/Lo/OffPower switch ON
AC Linked ventilationYesYes (if equipped)Automatic at HiAC system active
AC System Integration Optimization
Most owners report that ventilated seat effectiveness varies based on AC fan speed setting. Stronger ventilation occurs when the AC fan is set higher, as the system automatically links seat ventilator fan speed to overall AC fan speed. In hot climates (like Dallas), even Level 1 ventilation setting provides noticeable cooling.
Source: Land Cruiser Forum Community
Drive Mode Affects Heating Performance
J250 owners report that heated seat temperature varies by drive mode, with ECO mode providing reduced heat output and Sport mode delivering faster heating and hotter temperatures. For optimal warmth in winter, consider switching to Sport or Normal mode rather than ECO.
Heating Bridges Cabin Warm-Up Time
Heated seats warm up quickly and can be used strategically to maintain comfort while waiting for the cabin to reach full temperature. This is especially effective when paired with the heated steering wheel feature for complete occupant warmth.
Source: IH8MUD Forum Community
Ventilator Filters Require Maintenance
While not mentioned in the manual, community sources report that J250 seat ventilators have replaceable filters. Toyota recommends contacting a dealer for filter replacement service—this is a longer-term maintenance item but worth noting for owners planning long-term vehicle upkeep.
Source: Land Cruiser Community
What to Know​
Heat Levels Are Moderate, Not Extreme
Some owners report that even at the highest heat setting, J250 heated seats don't reach the extreme temperatures they've experienced in other luxury vehicles. This is normal and varies by seat material type. Setting expectations appropriately prevents disappointment. Heat is less noticeable with cloth seats compared to leather—if you have cloth seats, perceived warming may feel less intense than expected. This is physics (thermal conductivity difference), not a malfunction.
Remote Start Doesn't Activate Heated Seats
Heated seats do NOT activate during remote start—they only turn on after you enter the vehicle and manually activate the heated seat switch. This is a design limitation, not a malfunction.
S-Flow Smart Climate Integration
The J250 includes an advanced "S-Flow" automatic climate system that detects occupant seating and pushes heat or AC only to occupied seats. This works in concert with heated and ventilated seats for comprehensive comfort—when seat heating is activated, it complements the S-Flow system's zone management for maximum efficiency and comfort.
Hybrid System Considerations
For the i-FORCE MAX hybrid J250 owners, heated and ventilated seats benefit from the vehicle's intelligent energy management. The auxiliary 12V system managing seat controls independently means these comfort features have minimal impact on hybrid battery efficiency, making them genuinely practical for everyday use without energy concerns.
Common Questions​
Can I use both heated AND ventilated seats at the same time?
No. Each seat has one control (either heater or ventilator). You must choose which function to use. However, the heater and ventilator buttons are separate, so other occupants can use their heater while you use ventilation.
Why does my ventilator speed change automatically?
When set to Hi, the system links to your AC system—as your AC fan speed increases for heavier cooling demand, the seat ventilator automatically increases too. This provides better overall comfort in hot weather without needing manual adjustment.
Does using heated seats drain the hybrid battery?
Heated seats draw from the auxiliary 12V system, not the high-voltage hybrid battery. Your 12V system has independent charging, so seat heating has minimal impact on hybrid efficiency. However, using lower heat settings (Lo/Mid) is always more efficient than Hi.
Are rear seat controls the same as front?
Yes—same four-level cycling (Hi/Mid/Lo/Off) for both heated and ventilated functions on second-row seats where equipped.
If controls aren't working, what should I check?
First, verify the power switch is ON. If still inactive, check that the fuse is intact. If the fuse is good, the issue could be a faulty switch or, in rare cases, a factory code that needs clearing by a Toyota dealer.
Maintenance​
No User Maintenance Required
Heated and ventilated seat systems are maintenance-free under normal use.
If Controls Not Working
Check that power switch is ON. If still inactive, consult your owner's manual troubleshooting section or visit a Toyota dealer.
Winter Storage
If your Land Cruiser will be stored in very cold conditions, occasional use of seat heaters (even at Lo level) can help maintain system responsiveness.
Manual Pages Reference​
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual (Model OM60Y03U), pages 479-480.
Owner's Manual Pages
  • Heated seat controls and specifications: Page 479
  • Ventilated seat controls and AC-linked operation: Page 480
  • Safety precautions: Page 479
Additional Sources
  • Land Cruiser Forum
  • IH8MUD Forum
  • 250 Land Cruiser Community
  • Street Toyota
Disclaimer
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
