2024+ Land Cruiser - Hitch and Trailer Wiring Setup
Hitch Installation, Trailer Wiring, Weight Distribution, J250 Towing​
Planning to add a trailer to your Land Cruiser? Here's what you need to know about hitch selection, installation, wiring, and how your J250's systems work with a trailer.
(Reference: Owner's Manual, pg. 213-215, 337)
WARNING — Hitch Weight Capacity
Here's the critical thing about hitch ratings: every hitch has a maximum weight capacity set by its manufacturer, and that's your hard limit—not what your vehicle can physically pull. The risk is real: exceed it and the hitch can fail under load, potentially causing the trailer to detach or flip.
(Source: Page 213)
NOTICE — Hitch Installation Position
When installing a trailer hitch: Use only the position recommended by your Toyota dealer. Do not install the trailer hitch on the bumper; this may cause body damage.
(Source: Page 213)
Installation Warning — Trailer Lights
Please consult your dealer when installing trailer lights, as incorrect installation may cause damage to the vehicle's lights. Please take care to comply with your state's laws when installing trailer lights.
(Source: Page 215)
Official Manual Information​
Hitch System Overview​
The Land Cruiser J250 is equipped with provisions for a trailer hitch system that allows safe towing when properly configured. This guide aggregates the scattered manual sections on hitch installation, ball selection, positioning, and electrical integration.
Hitch Installation and Setup​
Step 1: Prepare for Hitch Installation
Before purchasing or installing a hitch:
  1. Determine your towing needs: Identify the gross trailer weight you plan to tow and confirm your Land Cruiser can handle that weight per owner's manual specs
  2. Contact your Toyota dealer: You need to follow Toyota's position recommendations for hitch selection and installation. The dealer will ensure proper mounting location and prevent body damage. Do not attempt to install the hitch on the bumper.
  3. Lubricate the hitch ball: Once installed, apply a light coating of grease to the hitch ball to prevent corrosion and ensure smooth operation
  4. Remove when not in use: Remove the hitch ball whenever you are not actively towing a trailer. Remove the entire hitch assembly if you do not need it long-term. After removal, seal any mounting holes in the vehicle body to prevent entry of substances into the vehicle.
Step 2: Remove the Hitch Cover
The hitch assembly has a protective cover. To access the hitch ball mount:
  1. Locate the hitch cover clips: The cover is located at the rear of the vehicle under the bumper. Identify the 6 clips holding the cover in place.
  2. Remove the cover: Pull the lower edge of the hitch cover toward you and remove the 6 claws/clips. Separate the cover from the hitch assembly.
  3. Reattach the cover: When reinstalling, reverse the removal steps and ensure all 6 clips are fully seated.
Selecting the Correct Trailer Ball​
The trailer ball is the critical component connecting your vehicle to the trailer. Incorrect selection can result in unsafe coupling.
Trailer Ball Load Rating
The ball load rating must match or exceed the gross trailer weight rating of the trailer you plan to tow. Your trailer's total weight (when loaded) cannot exceed the ball's rated capacity. Check your trailer's documentation for its GVWR (Gross Vehicle Weight Rating).
Ball Diameter Sizing
The ball diameter must match the size of the trailer coupler. Most trailer couplers are stamped with the required ball size. Standard sizes for Land Cruiser towing:
Trailer ClassBall Size
Class I1 7/8 inches
Class II2 inches
Class III2 inches
Class IV2 5/16 inches
To check: Look at the coupler opening on your trailer—the size is typically marked on the coupler casting.
Shank Length
The shank must protrude beyond the bottom of the lock washer and nut by at least 2 threads. Insufficient shank length can cause the ball to separate under towing loads.
Shank Diameter
The shank diameter must match the ball mount hole diameter size. The shank must fit snugly in the hitch receiver without excessive play.
Hitch Position Specifications​
The Land Cruiser hitch system has precise position requirements for safe operation.
Weight Carrying Ball Position: 51.7 inches (1312.2 mm)
This dimension is measured from a fixed reference point on the vehicle to the center of the hitch ball when properly installed. This height ensures proper weight distribution and prevents trailer sway.
Hitch Receiver Pin Hole Position: 44.9 inches (1140.2 mm)
This is the vertical position where the locking pin inserts to secure the hitch assembly.
Ball Height Alignment
No matter which class of tow hitch applies, the trailer ball setup must be at the proper height to match the coupler on the trailer. A ball that is too high or too low creates:
  • Unsafe weight distribution (tongue weight may be excessive or insufficient)
  • Trailer sway during highway driving
  • Difficulty coupling/uncoupling
  • Potential for trailer detachment
When properly coupled, the trailer should sit level (not tilted up or down). If the setup appears misaligned, do not tow—consult your Toyota dealer.
Trailer Electrical System Setup​
The Land Cruiser has a dedicated wire harness for trailer light integration.
Wire Harness Location
Use the wire harness stored in the rear end under the vehicle body (Page 215). Locate the wire harness bundles stored underneath the rear of the vehicle. Route the harness according to the diagram in your manual. Connect to the trailer's light circuits (stop/turn signals, tail lights, backup lights). Ensure connections are weatherproof and secure.
Auto Current Cut-Off Function
The Land Cruiser has a built-in protection system for the trailer light circuits. In case of overcurrent, the auto cut-off function stops the power flowing to the trailer lights to prevent damage to the vehicle's electrical system.
This function activates when the rated current of any trailer light circuit component is exceeded:
  • Stop/turn signal light (right): Maximum 10 A
  • Stop/turn signal light (left): Maximum 10 A
If a trailer light does not come on due to activation of the auto current cut function, the light system will need to be reset (Page 215).
Resetting Trailer Light Circuits
If the auto cut-off function activates and a trailer light will not operate:
  1. If a tail light does not come on: Turn off the headlight switch, wait 10 seconds, then turn the headlight switch back on.
  2. If the right-side stop/turn signal light does not come on: Put the turn signal in the off position OR remove your foot from the brake pedal. Wait 10 seconds, then operate the turn signal again.
  3. If the left-side stop/turn signal light does not come on: Put the turn signal in the off position OR remove your foot from the brake pedal. Wait 10 seconds, then operate the turn signal again.
  4. If the emergency flashers do not operate: Press the emergency flasher switch to turn them off, wait 10 seconds, then press the switch again to turn them back on.
After reset: Operate the light switches again to see if the lights operate normally. If the lights do not operate normally, have the vehicle inspected by your Toyota dealer.
Intelligent Parking Assist Integration​
The Land Cruiser J250 features Intuitive Parking Assist, which is disabled automatically when towing.
When the 7-pin connector is connected: The rear sensor automatically turns off. When you plug in the trailer electrical connector, the parking assist system recognizes that a trailer is attached and disables the rear parking sensors. This prevents false warnings from the trailer, which the sensors would otherwise interpret as obstacles.
When shift position is in R (Reverse): The intuitive parking assist OFF indicator turns on and a message is displayed in the multi-information display, alerting you that parking assist is disabled while towing.
If a camera malfunction occurs during towing: There may be cases where the notification message indicating that intuitive parking assist, RCD (if equipped), or PKSB is OFF may not be displayed. Check the multi-information display manually if you're experiencing parking assist issues while the trailer is connected.
(Source: Page 337)
Real-World Tips and Context​
Pro Tip: Measure Hitch Ball Height ONLY with Loaded Trailer
The most critical measurement mistake is measuring ball height when the trailer is empty. The ball height changes dramatically once the trailer's weight is on the hitch. Proper measurement must occur with the loaded trailer attached and balanced in its final configuration.
Pro Tip: Use Weight-Distribution Hitch for Loads Over 5,000 lbs
For any trailer over 5,000 lbs gross weight, you should use a weight-distribution hitch. This prevents excessive tongue weight that would overload the vehicle's front axle and cause unsafe handling.
Pro Tip: Verify Front Axle Weight Returns to Original
If you cannot directly measure front axle weight before and after trailer connection, measure the front fender height above the front axle before connection. Then adjust the weight-distribution hitch torque until the fender returns to exactly the same height. This ensures proper weight distribution.
Pro Tip: Tongue Weight Should Be 9-11% of Total Trailer Weight
For the J250 Land Cruiser (6,000 lb towing capacity), tongue weight should typically be 490-600 lbs for a fully loaded trailer. Too little tongue weight causes trailer sway; too much causes front axle overload.
Pro Tip: Always Measure Actual Weights at a Professional Scale
Estimated weights are unreliable. Visit a highway weighing station, building supply company, or truck yard with certified scales to measure:
  • Gross vehicle weight (Land Cruiser + cargo)
  • Gross trailer weight (fully loaded)
  • Tongue weight (hitch load)
This verifies your setup is within J250's limits before highway towing.
Pro Tip: Enable Tow/Haul Mode to Prevent Engine Shutoff During Towing
The J250's hybrid system can shift into EV-only mode automatically during light throttle. When actively towing, use Tow/Haul mode to keep the gas engine running continuously. This prevents unexpected power loss while towing.
Wrong Hitch Ball Diameter
Example: Installing a 2 inch ball in a trailer with a 1-7/8 inch coupler. Even a 1/8 inch mismatch can cause:
  • Excessive play between ball and coupler
  • Trailer sway and oscillation during highway driving
  • Potential for trailer detachment under cornering loads
The ball must fit snugly in the coupler. Always check your trailer's coupler markings to confirm the exact ball size needed.
Ignoring Sway Control for Trailers Over 2,000 lbs
You should use sway control for any load exceeding 2,000 lbs. Without sway control on moderate to large trailers:
  • Wind gusts can induce oscillation
  • Lane changes may cause trailer fishtailing
  • Braking can create yaw (side-to-side swinging)
Sway control dampens these movements and keeps the trailer tracking straight behind the Land Cruiser.
Exceeding 10-15% Tongue Weight Ratio
Installing a hitch ball mount that creates excessive tongue weight (over 15% of trailer weight) can:
  • Overload the J250's front suspension
  • Reduce steering control and stability
  • Cause accelerated wear on front tires
  • May exceed the vehicle's GVWR rating
Your Land Cruiser has a maximum front axle rating. Excess tongue weight pushes you toward that limit and beyond safe operating conditions.
Not Pre-Testing Brake Systems Before Towing
Connecting a trailer with non-functional brake lights, signal lights, or brakes without a pre-test drive can:
  • Discover problems at highway speeds
  • Allow auto cut-off function to activate, leaving you without trailer brakes
  • Reduce stopping power when most needed
Trailer brake function is critical for safe towing. Test all connections and lights in a parking lot before highway driving.
Helpful Context​
Parking Assist Sensors Automatically Disable When Trailer Is Connected
When you plug in the 7-pin connector, the J250's Intuitive Parking Assist rear sensors automatically turn off. This is intentional—the sensors would otherwise treat the trailer as an obstacle and trigger false warnings. The system is correctly designed for this situation.
Front Sensors Still Operate in Reverse Even When Towing
While rear parking assist disables when a trailer is connected, the front corner sensors still operate. This provides parking assist protection for the front bumper and hood during reverse maneuvering. Don't be surprised when the front sensors engage while the rear remains silent.
J250 Towing Capacity Is 6,000 lbs (Confirmed)
The 2024+ Toyota Land Cruiser J250 has a maximum towing capacity of 6,000 lbs when properly equipped with an adequate hitch. This applies to the hybrid-only model available in North America. Always verify your specific vehicle's towing capacity in the owner's manual or via your Toyota dealer.
Weight Distribution Hitch Returns Front Axle to Original Weight
When using a weight-distribution hitch, the goal is to transfer some tongue weight to the trailer's axles, allowing the front axle weight to return to its pre-towing level. This restores normal handling, reduces brake wear, and improves highway stability.
  • Primary procedure: Pages 213-214 (Hitch installation, ball selection, specifications)
  • Electrical setup: Page 215 (Wiring, light circuits, auto cut-off function)
  • System integration: Page 337 (Parking assist behavior when towing)
  • Land Cruiser Forum (landcruiserforum.com) — Active enthusiast community
  • IH8MUD.com Forum — Toyota-focused community
  • Cars.com — Major automotive publication
  • ETrailer.com — Professional trailer equipment retailer
  • Proven Industries — Professional hitch installation company
  • TLACruiser.com — Toyota enthusiast technical site
  • HitchCorner.com — Specialized hitch safety site
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual (OM60Y03U) with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
