2024+ Land Cruiser - How to Jump Start the Land Cruiser
Dead battery? Whether you left a light on or the cold finally got to it, here's how to jump-start your Land Cruiser. (Reference: Owner's Manual, pg. 617-618)
Jumper cables and a second vehicle are usually all you need to get running again.
Jump Starting, Dead Battery, Jumper Cables, Electrical System, 12V Battery​
CRITICAL: When connecting the jumper cables, depending on the situation, the alarm may activate and the doors locked. This is normal hybrid system behavior and does not indicate a problem.
IMPORTANT: The hybrid system cannot be started by push-starting. This differs from traditional gasoline vehicles.
DEALER REQUIREMENT: Once the hybrid system starts, have the vehicle inspected at your Toyota dealer as soon as possible.
BATTERY PRESERVATION: Turn off the headlights and the audio system while the hybrid system is stopped. Turn off any unnecessary electrical components when the vehicle is running at a low speed for an extended period.
What You'll Need​
  • Jumper cables (appropriate length to reach the terminals)
  • Second vehicle with 12-volt battery in good condition
  • Electronic key (must be with you during procedure)
  • Approximately 5-10 minutes of time
Skill Level: Beginner (no special tools or expertise required)
Step-by-Step Procedure​
Step 1: Confirm that the electronic key is being carried with you. The electronic key presence activates hybrid system intelligence during jump-starting.
Step 2: Open the hood and access the right-hand side fuse box cover. Locate the right-hand side fuse box cover on the passenger side of the engine bay. Push the tab inward and lift the lid off. This provides clearance for the next step.
Step 3: Open the exclusive jump starting terminal cover. Look for the dedicated terminal cover on the right side of the engine bay. This is NOT the standard battery terminal location. Lift the cover to expose the jump starting terminal [A].
Key Distinction: The J250 Land Cruiser uses an exclusive jump starting terminal on your vehicle, not the standard 12-volt battery terminals. The donor vehicle connects to its own standard battery terminals. This design protects your hybrid system electronics.
Step 4: Connect jumper cables in the specified order
  1. Connect the positive jumper cable clamp to [A] on your vehicle (the exclusive jump starting terminal)
  2. Connect the other end of the positive cable to on the second vehicle (its battery positive terminal, marked with +)
    [*]Connect the negative cable clamp to [C] on the second vehicle (its battery negative terminal, marked with −)
    [*]Connect the other end of the negative cable to [D] (a metallic point on your vehicle (see diagram on Page 618)
Why order matters: Connecting positive first isolates the circuits appropriately. Connecting negative last prevents accidental sparks during connection. The donor vehicle's negative connection to ground [D] on your vehicle prevents hydrogen gas ignition risk that could occur at the battery negative terminal.
Step 5: Start the donor vehicle and maintain engine speed. Start the engine of the second vehicle, increase the engine speed slightly, and maintain this elevated speed for approximately 5 minutes. This period allows the donor vehicle's alternator to transfer charge back into your Land Cruiser's 12-volt battery.
Step 6: In your Land Cruiser, turn the power switch to ON (do not press the brake pedal). Maintain the elevated engine speed on the second vehicle during this step. The donor vehicle must be actively charging.
Step 7: Verify the READY indicator illuminates. The READY indicator confirms that the hybrid system has recognized sufficient 12-volt battery voltage to operate safely. Without it, the system detected an insufficient charge and is protecting itself.
IF the READY indicator DOES NOT illuminate: Contact your Toyota dealer or a qualified repair shop. The hybrid system is protecting itself by preventing an unsafe startup. Do not attempt to restart.
Step 8: Remove jumper cables in the exact reverse order
    • Remove the negative cable clamp from [D] on your vehicle
    • Remove the negative cable clamp from [C] on the second vehicle
    • Remove the positive cable clamp from on the second vehicle
      [*]Remove the positive cable clamp from [A] on your vehicle (the exclusive jump starting terminal)
Reverse order prevents voltage spikes: Removing cables out of sequence could create voltage spikes that damage hybrid electronics and trigger fault codes.
Step 9: Close the exclusive jump starting terminal cover and reinstall the right-hand side fuse box cover to its original position. Close your hood.
After Jump-Starting
CRITICAL NEXT STEP: Once the hybrid system starts, have the vehicle inspected at your Toyota dealer as soon as possible. This inspection ensures your hybrid system's battery management circuits and main hybrid battery status are normal after a low-voltage event.
Pro Tips from the Community
Use High-Quality Jumper Cables
Cable gauge dramatically affects charging speed. Heavy-gauge cables (0, 2, or 4 gauge) transfer current much more efficiently than cheap cables (8-10 gauge), reducing jump-start time from 10-15 minutes to 3-5 minutes. Land Cruiser owners recommend investing in quality cables as a one-time purchase that will last for years.
Position Vehicles Strategically
Placing vehicles close enough for cable reach without touching prevents accidental ground connections and ensures stable cable positioning. Best practice: Keep both vehicles in Park with parking brakes engaged during the entire procedure.
Pre-Jump System Check
Headlights or interior lights left on are the #1 cause of unnecessary battery drain overnight. Before attempting a jump start, turn off all lights and verify they're actually off. Some vehicles have lights that take 10+ minutes to fully extinguish when doors close.
Consider Modern Alternatives
Lithium jump boxes eliminate the need for a second vehicle and are increasingly popular with Land Cruiser owners for emergency preparedness. Owners often keep portable lithium jump packs in their vehicle as emergency backup, especially for off-road or remote situations. These are convenient for situations where finding a second vehicle may be difficult.
Mistake 1: Reversing Cable Connections
Connecting positive to negative and vice versa creates sparks at connection points and can damage electrical components. The J250's hybrid system electronics are sensitive to reverse polarity. Even momentary reversal can trigger fault codes requiring dealer diagnostics. Always use the marked sequence.
Mistake 2: Connecting Negative to Battery Terminal Instead of Ground
Hydrogen gas near the battery's negative terminal can ignite from sparks created during cable connection, creating serious explosion and fire risk. The manual explicitly recommends grounding to frame point [D], not the battery. The exclusive jump starting terminal on the J250 already isolates this risk for your vehicle, but the donor vehicle requires this extra precaution.
Mistake 3: Using Thin-Gauge or Low-Quality Cables
Undersized cables generate excessive heat and voltage drop, requiring 15+ minutes of charging versus 5 minutes with proper cables. This extends the emergency situation, increases risk of overheating cables, and may not deliver enough current for reliable startup. Forum users consistently report that cheap cables turned a 5-minute jump-start into 20-30 minute ordeals.
Mistake 4: Disconnecting Cables Out of Sequence
Disconnecting positive before negative creates voltage spikes that can damage hybrid system electronics. The J250's inverter and hybrid battery management system are voltage-sensitive. Out-of-sequence disconnection may trigger fault codes. The manual explicitly states "exact reverse order." This is non-negotiable for hybrid systems.
Mistake 5: Using Vehicle Accessories While Parked in Accessory Mode
Navigating infotainment menus, adjusting climate control, or using other systems in Accessory mode draws 12V battery power without the engine or hybrid system running to recharge it. Over hours or overnight, this depletes the 12V battery completely, requiring a jump start the next morning. The hybrid system cannot power the 12V battery without the engine/motor running. Accessory mode is a complete drain.
Understanding Your J250's Two-Battery System
The J250 has TWO distinct batteries:
12V Battery: Located in driver's side rear cargo area (behind interior trim panel). This is what you jump-start when needed for emergency power restoration.
Hybrid Battery: Located under cargo floor. This is the traction battery that powers the electric motor and manages your hybrid system's efficiency.
When the 12V battery is dead, the hybrid system cannot start because it needs 12V electrical power to activate the inverter and motor/generator circuits. Once you jump-start and the 12V battery is restored, the traction battery (hybrid battery) can actually help recharge the 12V battery through the inverter while driving.
Why this matters: It explains why a successful jump-start requires 5 full minutes of charging and the READY indicator verification. The system must verify both the 12V electrical system AND the hybrid battery are in safe operating condition.
Why the Exclusive Jump Terminal Exists
Toyota engineers designed the exclusive jump starting terminal specifically to protect the Land Cruiser's sophisticated hybrid system from the electrical stress of donor vehicle connections. This approach:
  • Isolates the hybrid battery management circuit from external voltage fluctuations
  • Prevents feedback voltage into the main hybrid battery (which could confuse its charge-state estimation)
  • Protects the inverter and motor/generator control circuits
  • Ensures safe hybrid system restart without triggering fault codes
What the "Approximately 5 Minutes" Really Means
The stated 5-minute recharge timing is conservative and accounts for:
Donor vehicle alternator output variability: Older vehicles or smaller cars may charge more slowly than newer vehicles.
Temperature effects: Cold weather reduces charge acceptance rates (consider 7-10 minutes in winter).
Battery condition: A partially sulfated (aged) battery may accept charge more slowly than factory condition.
Cable resistance: Longer cables or smaller gauge than optimal may reduce charging rate.
Practical guideline: If 5 minutes have passed but the READY indicator didn't illuminate on first attempt, wait 2-3 additional minutes rather than giving up immediately.
Primary Source: Owner's Manual pages 617-618
Related Topics: Page 538 (hood opening), Page 80 (door lock behavior)
  • Primary procedure: Pages 617-618
  • Hood opening reference: Page 538
  • Door lock behavior with electronic key: Page 80
Additional Community Sources:
  • Land Cruiser Club
  • Land Cruiser Forum
  • IH8MUD Forum
  • CarCare Kiosk
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the Land Cruiser owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only. If jump-starting is unsuccessful or if you have concerns about your vehicle's electrical system, consult your Toyota dealer or a qualified repair shop.
