2024+ Land Cruiser - How to Use the 4WD System (H4 to L4 Shifting)
Master the 2024+ Toyota Land Cruiser J250's transfer case and understand when to use high-speed (H4) or low-speed (L4) four-wheel drive modes. This guide consolidates information from owner's manual pages 434-435 and 458 with supplementary community insights.
WARNING: Off-road driving precautions
Always observe the following precautions to minimize the risk of death, serious injury or damage to your vehicle:
  • Drive carefully when off the road. Do not take unnecessary risks by driving in dangerous places.
  • Do not grip the steering wheel spokes when driving off-road. A bad bump could jerk the wheel and injure your hands. Keep both hands and especially your thumbs on the outside of the rim.
  • Always check your brakes for effectiveness immediately after driving in sand, mud, water or snow.
  • After driving through tall grass, mud, rock, sand, rivers, etc., check that there is no grass, bush, paper, rags, stone, sand, etc. adhering or trapped on the underbody. Clear off any such matter from the underbody. If the vehicle is used with these materials trapped or adhering to the underbody, a breakdown or fire could occur.
  • When driving off-road or in rugged terrain, do not drive at excessive speeds, jump, make sharp turns, strike objects, etc. This may cause loss of control or vehicle rollover causing death or serious injury. You are also risking expensive damage to your vehicle's suspension and chassis.
Source: Owner's Manual Page 458
Additional System Alerts:
  • VSC Automatic Disengagement: When the four-wheel drive control switch is in L4 with the center differential locked, VSC is automatically turned off. The center differential lock and VSC OFF indicator lights will come on. Source: Page 435
  • Cold Weather Operation: If the hybrid system is started when the outside temperature is low, the four-wheel drive control switch may not be shifted between H4 and L4, as the automatic transmission fluid temperature is low. In this case, follow the instructions displayed on the multi-information display and operate the switch again after warming up the engine. Source: Page 435
4WD Transfer Case, H4 vs L4 Modes, Four-Wheel Drive Shifting, Transfer Case Operation​
H4 (High Speed Position)​
Definition: Normal driving on all types of roads.
When to Use H4:
  • Daily commuting and highway driving
  • Normal road conditions (asphalt, gravel)
  • Situations where fuel efficiency is important
  • Any driving that doesn't require maximum traction
Performance: In H4, the transmission delivers normal power distribution for everyday use. The system is most fuel-efficient in this mode.
L4 (Low Speed Position)​
Definition: Driving requiring maximum power and traction such as climbing or descending steep hills, off-road driving, and hard pulling in sand or mud, etc.
When to Use L4:
  • Rock crawling and extreme off-road terrain
  • Steep hill climbs where maximum torque is needed
  • Deep sand or mud requiring maximum traction
  • Recovery situations where pulling power is critical
Performance: In L4, the transfer case reduces wheel speed to approximately 1:1.9 ratio (depending on gear selection), multiplying engine torque significantly. This enables precise vehicle control at very low speeds in extreme conditions.
Shifting Procedures​
CRITICAL REQUIREMENT: Before attempting any shift, ensure your vehicle is completely stopped and the shift lever is in Neutral. The system will not allow shifting otherwise as a safety measure.
Shifting from H4 to L4​
Use this procedure when you're about to enter challenging terrain and want maximum traction and power.
Prerequisites:
  • Vehicle must be completely stopped
  • Engine must be running (power switch in ON)
  • Shift lever must be in Neutral (N)
Step-by-Step Procedure:
  1. Stop the vehicle completely. Come to a full stop on stable terrain if possible. Do not attempt shifting while moving, even at very low speeds.
  2. Shift the transmission to Neutral. Move the shift lever to the N position. The vehicle should be in neutral, not in Drive or Reverse.
  3. Push and shift the four-wheel drive control switch to L4. Locate the 4WD control switch on the steering column. Push it firmly and move it to the L4 position (labeled on the switch). You may feel or hear a slight clunk as the transfer case engages low range. Maintain pressure on the switch until the indicator light comes on completely.
  4. Confirm engagement. Wait until the low speed four-wheel drive indicator light turns on steady (not blinking). Once it's steady, the shift is complete and you can proceed. If the indicator blinks continuously, the shift is still in progress (maintain the switch position and wait). If it continues blinking after several seconds, release and try again.
Shifting from L4 to H4​
Use this procedure when you're leaving challenging terrain and returning to normal roads.
Prerequisites:
  1. Stop the vehicle completely. Come to a full stop on stable terrain. Do not attempt shifting while moving.
  3. Push and shift the four-wheel drive control switch to H4. Locate the 4WD control switch. Push it firmly and move it to the H4 position. You'll feel a slight mechanical engagement as the transfer case shifts back to high range.
  4. Confirm completion. Wait until the low speed four-wheel drive indicator light turns off (extinguishes). Once it's completely off, you're back in H4 and the shift is complete.
Operational Conditions and Restrictions​
When You Can Shift Between H4 and L4​
The four-wheel drive control switch can be operated when:
  • The power switch is in ON
  • The shift lever is in N (Neutral)
  • The vehicle is stopped completely
The system has these safety interlocks:
  • Engine must be running. Shifting requires power from the hybrid system
  • Vehicle must be fully stopped. This prevents transmission damage
  • Shift lever in Neutral. This disengages the transmission during the transfer case shift
Speed Restrictions for Center Differential Lock​
The center differential lock switch can be operated when:
  • The vehicle speed is less than 62 mph (100 km/h)
The center differential lock is an additional feature that works alongside H4/L4 shifting. The 62 mph speed limit applies to engaging and disengaging the lock. Once locked, you may continue driving, but return to unlocked status before normal road driving to ensure proper handling and tire wear.
Indicator Light Guide​
The low speed four-wheel drive indicator will come on when L4 is engaged. The indicator light blinks while shifting between H4 and L4. Source: Owner's Manual Page 435
Light StateMeaningAction
Steady onL4 is fully engaged (Source: Page 435)System ready to use
BlinkingShift in progress or incomplete (Source: Page 435 describes blinking during shifting)Wait for completion; if blinking continues after procedure, stop and try again
OffH4 is engaged (Source: Page 435)Normal driving mode active
Note: The manual page 435 indicates the indicator light blinks during shifting transitions. The distinction between slow and rapid blinking rates is an editorial clarification based on expected shift behavior, not a direct manual quote.
If the indicator continues blinking after you've completed the procedure, stop the vehicle with the shift lever in Neutral and attempt the operation again.
Center Differential Lock (Additional Feature)​
The Land Cruiser J250 includes a center differential lock for extreme off-road conditions. This locks the center differential for maximum traction when wheels are stuck or on extremely slippery surfaces.
Lock the Center Differential When:
  • Your vehicle's wheels get stuck in a ditch
  • Driving on slippery or bumpy surfaces
  • Using L4 mode for extreme rock crawling
Unlock the Center Differential:
  • After the wheels have been freed
  • After moving to a flat, non-slippery surface
  • Always before returning to normal roads
Speed Restrictions:
  • Engage/disengage operations only work at speeds under 62 mph (100 km/h)
  • Once locked, return to normal driving as soon as terrain permits
Advanced Driving Tips​
Driving on Slippery Roads​
If you shift the four-wheel drive control switch to L4 and shift the shift lever to the 2 range of M (Manual) mode while driving in steep off-road areas, the output of the brake can be controlled effectively by the Active TRAC system. This assists the driver to control the driving power of all 4 wheels (useful for steep descents where you need engine braking).
For maximum power and traction when your wheels get stuck or when driving down a steep incline, use the 1 range of M mode of the shift lever.
Troubleshooting: Blinking Indicator Lights​
If the low speed four-wheel drive indicator light or center differential lock indicator blinks:
  2. Move the shift lever to N (Neutral)
  3. Try the operation again
If the indicator light does not turn off when unlocking the center differential:
  • Drive straight ahead while accelerating or decelerating
  • Or drive in reverse
  • The indicator should eventually turn off
If the center differential lock/unlock is not completed within 5 seconds while cruise control is on:
  • Cancel the cruise control system
  • Try the operation again
If the low speed four-wheel drive indicator light continues to blink even after attempting all the above steps:
  • There may be a malfunction in the engine, brake system, or four-wheel drive system
  • Consult a Toyota dealer for diagnostic service
Important System Interactions​
VSC (Vehicle Stability Control):
When the four-wheel drive control switch is in L4 with the center differential locked, the VSC system automatically turns off. This is normal operation (the VSC OFF indicator lights will come on alongside the center differential lock indicator). VSC will automatically re-engage when you unlock the differential or return to H4.
Cruise Control:
If the center differential lock/unlock operation is not completed within 5 seconds while cruise control is on, the system will automatically cancel cruise control as a safety measure.
If the hybrid system is started when outside temperatures are very cold, the four-wheel drive control switch may not respond immediately. This is because the automatic transmission fluid temperature is too cold. In this case: (1) Follow the instructions displayed on the multi-information display, (2) Wait for the engine and transmission to warm up, (3) Try the shift operation again.
Pro Tips from J250 Owners​
Use smooth, gradual engagement when shifting:
Don't accelerate hard when engaging the H4/L4 lever. Stay off the throttle during the switch, then give it a little gas afterward. This prevents transmission shock and ensures smooth engagement.
Use L4 for control and modulation, not just traction:
L4 provides multiple benefits beyond traction: engine braking, transmission cooling, and more forgiving throttle response. It's preferred when you need to stay under 20-25 mph for extended slow-speed driving.
Coast briefly in neutral before transfer case shifts:
Coasting a few feet with transmission in N before stopping reduces load on gears. This makes H4↔L4 shifts smooth without grinding, especially helpful on inclines where tension builds up.
About H4 Mode on Pavement:
The 2024+ Land Cruiser J250's full-time 4WD system with Torsen center differential is engineered for all road conditions including highways and dry pavement. H4 is the standard mode for most driving situations. The full-time design (unlike older part-time 4WD systems) allows highway speeds without risk. Use H4 for normal road driving and L4 only when maximum traction is needed in extreme terrain.
Don't worry if transmission revs higher than expected in L4:
Normal behavior: transmission won't upshift from 3rd gear in L4 until approximately 3,200-3,500 RPM. High RPMs don't indicate a problem (the transmission is functioning as designed). This avoids unnecessary troubleshooting or dealership visits.
Don't force shifts in cold weather:
If you have trouble shifting in cold weather, reduce speed or stop the vehicle. Wait for the transmission fluid to warm up before attempting to shift again.
  • H4/L4 mode definitions and shifting procedures: Pages 434-435
  • Off-road driving precautions: Page 458
  • Differential lock operation: Pages 434-435
  • IH8MUD Forums - Established Toyota enthusiast community
  • Land Cruiser Forum - Dedicated Land Cruiser owners
  • FJ Cruiser Forums - Toyota 4WD procedures and experience
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from verified owner communities. Always follow your official owner's manual for warranty compliance. This is a reference guide only (consult your manual for definitive specifications and procedures).
Manual Pages Reference:
Pages 434-435: 4WD system operation, H4/L4 shifting procedures, differential lock operation
Page 458: Off-road driving precautions and safety warnings
