2024+ Land Cruiser - Multi-Terrain Monitor & Camera Use
Got a Multi-Terrain Monitor on your J250? Here's everything you need to know to use it effectively. You'll learn about the different camera views and how to keep the system maintained properly. (Reference: Owner's Manual, pg. 363-364, 377, 420)
Critical System Limitations​
WARNING - When using the Multi-terrain Monitor system
Here are the critical safety points. They matter because these systems have real limitations:
Never rely solely on the Multi-terrain Monitor. As with unequipped vehicles, drive carefully while directly confirming the safety of your surroundings and the area to the rear of the vehicle. Take particular care to avoid parked cars and other obstacles.
Due to the characteristics of the camera lens, the actual position and distance of people and other obstacles will differ from those shown on the Multi-terrain Monitor screen. Directly confirm the safety of your surroundings before driving.
WARNING - Driving Attention Required
Always make sure to visually check behind you and your surroundings while you are driving.
Never drive while looking only at the screen as the image on the screen is different from actual conditions. If you are driving while looking only at the screen, you may hit a person or an object, resulting in an accident. When driving, be sure to check the vehicle's surroundings with your own eyes and the vehicle's mirrors.
The position of the guide lines displayed on the screen may change due to factors such as number of passengers, load capacity, and road gradient. Always make sure to visually check behind you and your surroundings while you are driving.
In low temperatures, the screen may darken or the images may become faint. Images of moving objects in particular may distort or disappear from the screen. Therefore, make sure to drive carefully while directly visually confirming the safety of your surroundings.
If you replace your tires, the position of the guide lines displayed on the screen may be incorrect.
NOTICE - Camera Malfunction Display
When the camera malfunctions, the screen may be displayed as follows:
When the shift position is in any position other than "R", the camera image continue to be displayed
When the shift position is in "R", part or all of the screen may appear black
When the shift position is in "R", the screen may not change to the camera image
The guide lines are not displayed on the camera image, and attention symbols and caution notices are displayed
Multi-Terrain Monitor, Camera System, Terrain Assessment, Maintenance​
What It Is and What It Does​
The Multi-Terrain Monitor is a camera system designed to help you check your vehicle's surroundings in a variety of situations. It's particularly valuable when judging terrain conditions during off-road driving or checking for obstacles when parking.
This system works seamlessly with other Toyota off-road technologies: Multi-Terrain Select (which adjusts throttle, braking, and traction control) and Crawl Control (which maintains steady low speeds). Using all three together creates comprehensive situational awareness for serious overlanders and technical terrain driving.
The system uses multiple cameras positioned around your J250:
  • Front camera - Located in front bumper area
  • Side cameras - One on driver-side, one on passenger-side body panels
  • Rear camera - Located at rear bumper area
Operating Conditions​
The system is available in different configurations depending on your driving mode:
  • Available in most shift positions (P, D, N, R)
  • Screen selection depends on shift position and vehicle speed
  • Most comprehensive views when 4WD is in H4 or L4 position
  • Multi-Terrain Select must be ON for specialized terrain views
Camera Views Explained​
Front View & Dual Side Views​
This view combination is available when your 4WD control switch is in H4 or L4 and Multi-Terrain Select is activated. It displays what's in front of and to the sides of your vehicle simultaneously.
Best For:
  • Assessing approach angle during terrain climbs
  • Seeing obstacles and guidance lines on both sides
  • Determining safe driving line in narrow passages
  • Checking tire placement during technical sections
The system displays guide lines that show your vehicle's projected path and footprint. These are helpful references, but remember they change with load, passenger count, and road gradient. Always visually confirm guidance lines match actual conditions before proceeding.
Under-Vehicle Terrain View​
This specialized view shows lines indicating your current vehicle position and tire placement displayed over an image of terrain captured behind your current position. It directly assists in checking conditions underneath your vehicle and determining front tire position.
To Display This Screen:
Press the camera switch when the shift lever is in P, D, or N position.
Important Notes:
  • You must drive a certain distance for the image to be displayed (not immediate)
  • If selected while another screen is displayed, the view switches from normal to magnified
  • Selecting again returns to normal display
Understanding the Display:
  • Current Vehicle Position (A) - Your real-time location
  • Image Displayed (B) - Composite view of terrain behind you
  • Vehicle Position at Image Capture Time (C) - Where you were when image was taken
  • Vehicle Width Lines (E - Blue) - Shows full width including mirrors (critical for tight passages)
Pro Tips from the Community​
Using the System Effectively​
Cycle Through Different Views
The system works best when you use multiple camera views to assess terrain. Don't rely on just one view for critical decisions. Take time to understand what each view shows you, then select the most useful combination for your current situation.
Guide Lines as Reference, Not Scripture
On-screen guide lines change with load, passengers, road gradient, and tire changes. Use them as reference points, not absolute positioning guarantees. Experienced overlanders mentally adjust guide line positions based on their current vehicle loading before critical maneuvers.
Integrate with Multi-Terrain Select
The system is most effective when used with Multi-Terrain Select activated. MTS calibrates throttle, braking, and traction control for your selected terrain, while the camera provides visual confirmation of your positioning. Using both creates maximum situational awareness.
Go Slow to See Clearly
The Multi-Terrain Monitor works optimally at low speeds (particularly with Crawl Control engaged). This isn't a limitation. It's by design for low-speed technical driving. High-speed camera updates don't provide the clarity needed for terrain assessment.
Clean Cameras Preventatively
In dusty or muddy environments, brief stops to wipe camera lenses maintain image clarity throughout the day. Don't wait for visibility to degrade significantly. The rear camera has a dedicated washer system (see Owner's Manual page 246) that's useful to operate preventatively in heavy dust or mud.
Don't Rely Solely on the Camera for Critical Decisions
Camera distortion, blind spots, and display limitations mean you could miss obstacles. Always validate what the camera shows with direct line-of-sight or by dismounting to physically inspect problematic sections. Multiple forum discussions document damage from incidents where drivers relied only on camera view without physical confirmation.
Don't Ignore Temperature and Lighting Conditions
Camera system performance degrades significantly in:
  • Extreme temperatures (very hot or very cold)
  • Low light conditions (night driving)
  • High humidity (rain)
Proceeding in these conditions with degraded camera visibility leads to terrain assessment errors. Moving object distortion increases in cold weather. The camera may show movement that isn't there or fail to show actual movement.
Don't Forget Camera Blind Spots
Objects very close to vehicle corners or underneath bumpers aren't visible on any camera view. In confined spaces (between rocks, tight canyon passages), use a spotter or dismount to verify clearance in blind zones.
Don't Assume Guide Lines Stay Accurate After Vehicle Changes
After tire changes, passenger load changes, or when driving on different gradients, guide lines may no longer match actual vehicle width. Erring toward conservative positioning is safer than assuming guide line accuracy.
Camera System Maintenance​
Camera Locations​
The Multi-Terrain Monitor uses four cameras integrated into your vehicle:
  • One front camera in the front bumper area
  • Two side cameras integrated into body panels (driver and passenger sides)
  • One rear camera at the rear bumper area
Together, these cameras provide 360-degree situational awareness.
Cleaning and Care​
Routine Cleaning
If dirt or foreign matter such as water droplets, snow, or mud has stuck to a camera, you will not be able to see the image clearly. Splash the camera with a large amount of water and then wipe the camera lens clean with a soft, damp cloth.
Rear Camera Dedicated Cleaner
The rear camera includes a dedicated camera cleaning washer system. Dirt on the rear camera lens can be cleaned by operating this dedicated washer (see Owner's Manual page 246 for washer controls and operation).
Critical Care Instructions
The Multi-terrain Monitor may stop functioning correctly. Take note of the following items:
Do not hit or apply a forceful impact on the camera. Doing so may change the position and mounting angle of the camera.
The camera is designed to be waterproof. Do not detach, disassemble, or modify it.
When washing the camera lens, splash the camera with a large amount of water and then wipe the camera lens clean with a soft, damp cloth. Rubbing the camera lens forcibly may scratch the camera lens and you may no longer be able to see images clearly.
The camera cover is made of resin. Do not allow an organic solvent, car wax, window cleaner, or glass coating to adhere to the camera. If this happens, wipe it off immediately.
Seasonal Maintenance Guide​
Regular Maintenance (All Times)
Inspect camera lenses weekly for dirt, mud, or water droplets. In off-road conditions, cleaner cameras mean better visibility and safer driving decisions.
Spring
After winter temperature swings, verify image clarity. Remember that low temperatures can cause screen darkening and image faintness (see warning above).
Summer
After off-road use in dust or mud, clean cameras immediately. Don't wait for visibility to degrade. Operate the rear camera dedicated washer if you've encountered mud or dust.
Fall
Run a pre-winter camera system check. Verify all cameras are responding and undamaged. Note that cold temperatures coming ahead will affect performance.
Winter
Monitor for image degradation in cold conditions. Clean cameras more frequently since snow and ice stick to lenses readily. Increase safety margins when using the camera in cold weather.
After Deep Water Crossings
Rinse cameras after water crossings with fresh water to prevent salt spray or mineral buildup.
Coastal Driving
Flush cameras regularly with fresh water to counteract salt spray effects.
  • System overview and warnings: Pages 363-364
  • Under-vehicle terrain view: Page 377
  • Camera locations and maintenance: Page 420
  • Land Cruiser Forum (landcruiserforum.com) - Owner community discussion and experience
  • IH8MUD Forum (ih8mud.com) - Established off-road enthusiast community
  • Toyota Support (support.toyota.com) - Official feature information
  • Brown Car Guy automotive review
  • J.D. Power automotive reference
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance and vehicle-specific procedures. This is a reference guide only. Before attempting any operation, verify all procedures against your vehicle's manual.
