2024+ Land Cruiser - Parking Support Brake (PKSB)
Overview: Wondering how your Land Cruiser's parking support brake works? Here's what you need to know about the PKSB system and how to use it effectively. (Reference: Owner's Manual, pg. 352, 354, 357)
Parking Support Brake, PKSB System, Collision Avoidance, Safety Sense​
What is the Parking Support Brake (PKSB)?​
The Parking Support Brake (PKSB) is a Toyota Safety Sense advanced driving support system designed to help prevent low-speed collision damage. It combines camera-based object detection with automatic braking to protect your vehicle when parking or maneuvering in tight spaces.
How It Works:
The PKSB system continuously monitors the front and rear of your vehicle using cameras and proximity sensors. When traveling at low speeds such as during parking maneuvers, if the system detects an object in the vehicle's path and determines a collision may occur, it will issue warnings and automatically apply braking to reduce the impact and resulting damage.
Primary Detection Scenarios:
The system responds to three types of objects:
  1. Static objects (walls, poles, curbs) in front or rear of the vehicle
  2. Moving vehicles approaching from the rear
  3. Pedestrians in the detection area (if equipped)
Enabling and Disabling the PKSB System​
How to Enable or Disable:
Press the PKSB switch (located on the dashboard) to toggle the system on or off. The switch controls whether the system actively monitors for objects.
Understanding the Dashboard Indicator:
When PKSB is disabled (switched OFF), the Driving Assist Information Indicator on your instrument cluster illuminates, and a text message appears on the multi-information display confirming the system is OFF.
Important: Persistent System State
Once you disable the PKSB system by pressing the switch to OFF, it will remain disabled until you manually switch it back to ON. The system does not automatically re-enable even if you turn the vehicle off and back on. This is intentional. Your disable preference is remembered across power cycles, giving you consistent control.
When PKSB Automatically Disables​
Understanding when the system automatically turns off helps you know when collision avoidance is unavailable:
4WD Low Mode (L4):
When you shift the four-wheel drive control switch to L4 (Low range), the Parking Support Brake function automatically turns off. The system will re-enable when you shift out of L4.
Trailer Towing:
When you connect a trailer (7-pin connector engaged), the PKSB system automatically disables for safety. This is because the system cannot accurately assess collision risk with a trailer attached. The system re-enables when you disconnect the trailer.
Note on Reverse Gear with Trailer:
When the shift position is in Reverse while a trailer is connected, the Intuitive Parking Assist OFF indicator illuminates, and a message displays on the multi-information display. Additionally, if a camera malfunction occurs while the trailer is connected, the system may not display notification messages for Intuitive Parking Assist, RCD (if equipped), or PKSB status.
Understanding Alerts and Responses​
Hybrid-Specific Output Control:
Because the Land Cruiser uses a hybrid powertrain, when the PKSB system detects an object and begins collision avoidance, it operates the hybrid system output restriction control and brake control together. This coordinated response provides more precise collision mitigation than brakes alone.
What You'll Experience:
  • Buzzer Alert: The system sounds a buzzer to alert you to the detected object.
  • Dashboard Messages: Visual messages appear on both the multimedia display and multi-information display.
  • Message Example: "Object Detected Acceleration Reduced" indicates the system is restricting engine acceleration to prevent collision.
  • Acceleration Restriction: If an object is detected during acceleration, the system restricts acceleration greater than a certain amount. You'll notice reduced responsiveness when you press the accelerator.
Factors That Affect PKSB Detection Accuracy​
The rear camera system that powers PKSB can have detection challenges in certain conditions. Being aware of these factors helps you rely on the system appropriately:
Vehicle-Related Factors:
  • Backing up toward an incline or decline
  • Vehicle height changes (nose up, nose down positioning)
  • Aftermarket parts installed near the rear camera (backlit license plate, fog light)
  • Bumper protectors or additional trim strips added to the rear bumper
  • Camera misalignment from collision impact or removal/installation work
  • Towing eyelets installed to the rear of the vehicle
Environmental Factors:
  • Water flowing over the rear camera lens
  • Dirty or obscured camera lens (dirt, snow-melting agent buildup)
  • Flashing lights in the detection area (emergency flashers of nearby vehicles)
  • Tire chains or emergency tire repair kit in use
  • Extreme cabin temperatures (extremely hot or cold conditions may prevent the display from operating correctly)
Audio Considerations:
The buzzer alert may be difficult to hear if you're in a noisy environment (heavy traffic) or if the audio system volume is set high.
Real-World Tips and Context​
Pro Tips from Land Cruiser Owners​
Use the Camera View Smart Trick for Parallel Parking:
Hit the VIEW button while moving forward slowly before you begin the actual parking maneuver. The camera view will remain displayed as you shift between reverse and drive, making parallel parking significantly easier. This is a practical technique frequently shared among Land Cruiser forum users.
Maintain Clean Sensors with Simple Methods:
Regular sensor cleaning keeps the system reliable. WD40 spray is safe for parking sensors and acts as a degreaser. Alternatively, contact cleaning spray and warm dish soap water with a microfiber cloth work effectively. Many owners report that routine maintenance is the most effective way to prevent false alerts and ensure consistent system performance.
Understand System Response Time:
The PKSB system is effective but not instantaneous. Brake control will only last approximately 2 seconds after activation, so you should be ready to apply brake pedal pressure immediately if the system engages.
Over-Relying on PKSB Without Visual Confirmation:
PKSB is a convenience system, not a collision guarantee. Always visually confirm the safety of your surroundings while parking. Relying exclusively on the system may lead to accidents, particularly with obstacles the sensors can't detect.
Ignoring Dirty Sensor Warnings During Winter or After Washing:
Dirty or contaminated sensors are the most frequent cause of PKSB malfunctions. Winter conditions and car washing routinely cause sensor contamination. This is the number one issue reported by owners. Regular inspection and cleaning of the rear camera lens should be part of your routine maintenance.
Using Hitch-Mounted Accessories Year-Round Without Disabling PKSB:
Hitch-mounted bike racks trigger constant false alerts and automatic braking since the rack is detected as a permanent obstacle. Many owners disable PKSB when hitch accessories are installed to avoid nuisance alerts and unnecessary system engagement.
Neglecting System After New Sensor Installation:
When a parking sensor is replaced, the system may need recalibration. Aggressive PKSB malfunction warnings after sensor work often indicate a calibration need rather than a defective sensor. If you've recently had sensor work done, consult your dealer about recalibration procedures.
Environmental Context​
Why PKSB Struggles with Detection in Certain Conditions:
Sensor detection is inherently limited to specific vehicle areas (front corners and rear bumper zones). Environmental factors that interfere with sensor accuracy include:
  • Dirt and debris accumulation (especially post-washing or during winter)
  • Snow or ice on sensors (critical in cold climates; sensors essentially "freeze")
  • Extreme weather affecting electrical system performance
This explains why the manual documents so many difficult detection conditions. Sensors work well in ideal conditions but have real limitations in dirt, wet, or winter environments.
Hybrid System Integration Considerations:
The J250 Land Cruiser's hybrid system interacts with PKSB in ways gas-only vehicles don't. The low-voltage 12V battery is critical for all electrical systems, including PKSB. Owners report that battery voltage issues (common after extended storage or electrical work) disproportionately affect the parking assist system before other systems fail. If you notice PKSB malfunction messages after electrical work, check your battery voltage and connections.
Why PKSB Disables in L4 (4WD Low):
For off-road use in L4, the system automatically disables because detection accuracy becomes unreliable with extreme suspension articulation and the different vehicle posture when in low-range. This is by design for safety during technical off-road driving.
Frequently Asked Questions​
Q: Why is my PKSB giving false alerts in winter?
A: Cold weather can freeze the rear camera lens or cause condensation on the sensor. Winter conditions commonly trigger detection errors. Regular inspection of the rear camera and cleaning of the lens can resolve many winter-related false alerts.
Q: Does PKSB work in reverse only, or does it monitor forward as well?
A: PKSB monitors both directions—forward static objects, rear static objects, and moving vehicles approaching from behind. It's active whenever you're driving at low speeds, not just in reverse.
Q: Can I disable PKSB permanently?
A: You can disable PKSB by pressing the PKSB switch, and it will remain off until you manually re-enable it. However, it will automatically disable again when you enter L4 or connect a trailer, regardless of your previous setting.
Q: What does "Object Detected Acceleration Reduced" message mean?
A: This message indicates that the system has detected an object and is restricting acceleration to help prevent collision. It means you're in an active PKSB engagement. You should prepare to apply the brake immediately.
Q: Is there anything I can do to improve PKSB accuracy?
A: Keep the rear camera lens clean and free from debris. Avoid installing aftermarket parts directly above or around the rear camera (such as backlit license plates or fog lights). If you've had any rear bumper work or collision repairs, ensure proper camera alignment. Regular maintenance of the sensor area is the most effective way to maintain PKSB reliability.
Manual Pages:
  • System overview and detection limitations: Page 352
  • Enable/disable controls and automatic disabling: Page 354
  • System operation and static object detection: Page 357
  • Land Cruiser owners forums and community forums (landcruiserforum.com, ih8mud.com)
  • Toyota PKSB maintenance guides and technical resources
  • Owner experiences and best practices from the J250 Land Cruiser community
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative automotive sources. Always follow your official owner's manual for warranty compliance and safety-critical procedures. This is a reference guide only. For warranty service or safety concerns, consult an authorized Toyota dealer.
