2024+ Land Cruiser - Power Back Door Settings
Power back door acting up or want to customize how it works? Here's everything you need to know about operating your Land Cruiser's power back door, from basic controls to advanced features and custom settings. (Reference: Owner's Manual, pg. 138-139, 145)
Critical Safety Information​
Important: Don't push or pull on the door while it's moving. Excessive force can damage the motor and mechanical components.
Watch Out For: The sensors on the door edges (right and left) are vulnerable. Don't nick them with sharp objects. If a sensor gets damaged and disconnects, the auto-close function stops working.
IMPORTANT — Close & Lock Function: When closing the power back door using the close & lock function, a different buzzer than the normal one will sound before the operation begins. To check that the operation has started correctly, check that a different buzzer than the normal one has sounded. When the power back door is fully closed and locked, operation signals will indicate that all of the doors have been locked. Before leaving the vehicle, make sure that the operational signals have operated and that all of the doors are locked.
— Source: Owner's Manual pages 138-139, 145
Power Back Door Operation, Control Methods, Door Settings, Vehicle Features​
Using the Instrument Panel Switch​
The power back door switch is located on the instrument panel for convenient access from the driver's seat while seated.
To Open or Close:
  1. Press and hold the power back door switch on the instrument panel
  2. The power back door will automatically open or close
Important Notes:
  • Unlock the back door before operating from the instrument panel
  • Pressing the switch while the door is opening/closing stops the operation
  • When the door halts mid-operation, press and hold the switch again during the stopped operation to reverse the motion
Stopping Mid-Operation: Pressing the switch while the power back door is opening/closing stops the operation immediately. Press and hold the switch again during the halted operation, and the back door will perform the reverse operation.
Using the Back Door Mounted Switches​
The power back door has mounted switches for direct operation without accessing the instrument panel.
Opening the Back Door:
When the back door is unlocked:
  • Press the back door opener switch on the exterior of the door
  • The power back door automatically opens
When the back door is locked:
  • While carrying the electronic key on your person, press and hold the back door opener switch
Closing the Back Door:
  1. Press the switch on the lower part of the back door
  2. The power back door automatically closes
  • Pressing the switch while the power back door is operating will stop the operation
  • When the switch is pressed again during the halted operation, the back door will perform the reverse operation
Advanced Functions​
Standard Close & Lock Function​
This feature closes all doors and locks them in a single operation.
To Activate:
  1. Close all doors except the back door
  2. Carry your electronic key on your person (within proximity)
  3. Press the switch on the lower part of the back door
What Happens:
  • A different buzzer (different from normal) will sound
  • The back door will begin closing automatically
  • All doors except the back door lock automatically
  • The back door locks at the same time it fully closes
  • Operation signals on the instrument panel indicate all doors have been closed and locked (see page 130 for signal details)
Stopping the Operation:
  • Pressing the switch while the back door is operating will stop the operation
  • When the switch is pressed again during the halted operation, the back door will close
Note: You can customize this at your dealer if you want.
Walk-Away Close & Lock Function​
This advanced function closes and locks all doors automatically after detecting you've moved away from the vehicle.
Note: This setting must be customized at your Toyota dealer for initial activation.
To Activate:
Standby Mode:
  • The close & lock (Walk-Away) function enters standby mode
After Moving Away:
  1. While the buzzer is sounding, move away from the back door
  2. When the proximity sensor detects that you are away from the back door, the buzzer will sound again and the emergency flashers will flash
Completion:
  • All doors other than the back door lock
  • After the back door closes, the back door also locks
  • When all doors have been closed and locked, the buzzer sounds and emergency flashers flash
Sensor Sensitivity Note: Depending on the direction of moving away from the back door, the location of the key, and circumstances, the sensor may not detect your movement properly. Do not rely solely on this function in critical security situations.
Customizing Settings​
The 2024+ Land Cruiser allows customization of power back door behavior through the multi-information display.
Accessing PBD Settings​
Menu Navigation:
  1. On the multi-information display, navigate to Vehicle Settings
  2. Select PBD (Power Back Door) from the menu
  3. Adjust settings as desired (see pages 101, 111 for detailed menu navigation)
Important Information:
  • Changed power back door settings are NOT reset when you turn the power switch to OFF
  • To restore original settings, you must manually change them back through the Vehicle Settings menu
Adjusting the Open Position​
You can customize the height at which the power back door stops when opening, allowing it to stop at your preferred height for access clearance.
To Set Custom Open Position:
  1. Stop the back door in your desirable position (use the switches from page 138 to position it)
  2. Press and hold the switch on the lower part of the back door for approximately 2 seconds
  3. When settings are complete, the buzzer will sound 4 times
  4. The next time you open the back door, it will automatically stop at this saved position
Verifying the Setting:
  • When the setting is complete, listen for 4 buzzer sounds
  • Upon next opening, the door will stop at the adjusted position
Resetting to Factory Open Position​
If you want to reset the back door to its original factory open position:
To Cancel the Adjusted Position:
  1. Press and hold the switch on the lower part of the back door for approximately 7 seconds
  2. Listen for the buzzer pattern: 4 sounds will indicate the reset, followed by 2 additional sounds
  3. After this pattern, the back door will return to the factory-set open position
  4. The next time you open the back door, it will stop at the original position
Real-World Tips from the Community​
Pro Tips​
Use the Walk-Away Function with Key Proximity
Hold or carry your electronic key on your person for optimal sensor detection. Stand directly underneath or very close to the hatch door and press the button. The sensor is sensitive to positioning. Direct proximity yields best results. (Source: Land Cruiser Forum - Auto Lock while walking away)
Ensure Glass Hatch is Fully Latched First
Before using the power back door, make sure the rear glass access hatch is fully closed and latched. The glass hatch can appear closed but not be latched, which blocks the power back door from operating. A simple latch click confirms the glass hatch is secure. (Source: Land Cruiser Forum - Rear Hatch Becomes Unresponsive)
Customize Position Setting for Your Cargo Access Pattern
Set the custom open position to match your typical cargo height (e.g., truck bed level, roof rack level). This eliminates the need to manually stop the door mid-opening on each use. Particularly useful for regular users who load/unload the same type of cargo. (Source: Land Cruiser Forum - Power Rear Lift Gate Close and Lock Feature)
Verify All Doors Are Closed Before Using Close & Lock
The Close & Lock function requires ALL regular doors to be closed first. Opening any door while the function is activating may prevent proper completion. This is a safety feature to prevent accidental locking with doors open. (Source: Toyota Land Cruiser Official - Smart Key System)
Expecting Walk-Away Function to Work from a Distance
The walk-away sensor is proximity-based and requires you to be near the door when activating it. Standing several feet away results in only a beep with no action. Always stand within 1-2 feet of the hatch and use the button when within range. (Source: Land Cruiser Forum - Auto Lock while walking away)
Assuming the Glass Hatch Latch is Complete When It Looks Closed
The glass hatch can appear latched but not actually be fully latched. In this state, the power back door becomes unresponsive and won't operate, and you'll get warning signals if you attempt to drive. Physically check that the glass hatch clicks into place. Close it gently but firmly until you hear/feel the latch engage. (Source: Land Cruiser Forum - Rear Hatch Becomes Unresponsive)
Carrying Multiple Key Fobs or Items Near the Sensor When Using Walk-Away
The sensor can become confused by multiple electronic devices near the door, reducing reliability of the walk-away function. Keep the electronic key in a single pocket, away from other devices. Don't carry multiple keys or devices in the same area when using the walk-away function. (Source: Land Cruiser Forum - Auto Lock while walking away)
Applying Force to the Door During Operation
As the manual states, applying excessive force while the door is opening/closing can damage the motor and mechanical components. Never push, pull, or apply pressure to the door while the power mechanism is active. If an obstacle is detected, the motor automatically stops. (Source: Toyota Land Cruiser Owner's Manual - Page 145)
Helpful Context​
Walk-Away Sensor Behavior vs. Button Operation
The walk-away function uses passive proximity detection (not an active kick sensor on the J250). This differs from some aftermarket systems that use motion-activated foot sensors. The manual button is more reliable for guaranteed operation; walk-away is a convenience feature with sensor sensitivity limitations. (Source: Land Cruiser Forum - Auto Lock while walking away)
Sensor Locations and Care Requirements
The back door has proximity sensors on both the right and left edges (as mentioned in the manual). These sensors must be kept clean and clear of obstructions. Regular inspection during vehicle cleaning prevents sensor damage and ensures reliable operation. (Source: Toyota Land Cruiser Owner's Manual - Page 145)
Customization Options Available at Dealer
The Walk-Away Close & Lock function is customizable and may need to be enabled through dealer menu settings. Some J250 models come with this feature enabled; others require dealer activation. Check with your dealer if the walk-away function doesn't appear in your PBD menu settings. (Source: Land Cruiser Forum - Question About Rear Hatch Close and Lock Button)
Recommended Products​
  • Smart key protective cover to prevent accidental activation
  • Proximity key pouch organizer for reliable sensor detection
  • Door latch lubricant for smooth operation and longevity
  • Microfiber cloth for sensor maintenance and cleaning
  • Operating procedures: Pages 138-139
  • System settings and customization: Page 145
  • Additional references: Pages 101, 111, 130
  • Land Cruiser Forum - Community discussions and user experiences
  • Toyota Official Resources - Smart Key System documentation
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the Land Cruiser owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only. When in doubt, consult your dealer or refer to the official manual.
