Understanding your Pre-Collision System means the difference between relying on it effectively and being surprised by how it actually works. This guide pulls together everything from your manual about PCS into one place - how it works, what to expect, how to configure it, and what real J250 owners experience on the road.
(Reference: Owner's Manual, pages 266-267, 277, and 657)
WARNING
For safe use
Driving safely is solely the responsibility of the driver. Pay careful attention to the surrounding conditions in order to ensure safe driving.
Never use the pre-collision system in place of normal braking operations. This system cannot help avoid or reduce the impact of a collision in every situation. Over-reliance on this system to drive the vehicle safely may lead to an accident resulting in death or serious injury.
Although the pre-collision system is designed to help avoid or help reduce the impact of a collision, its effectiveness may change according to various conditions. Therefore, it may not always be able to achieve the same level of performance.
Read the following items carefully. Do not overly rely on this system and always drive carefully.
System Overview
Your Pre-Collision System uses sensors up front to watch for objects in the road ahead. When it detects a possible collision, it escalates through a few stages: first a warning to get your attention, then increases brake pressure to help you stop, and finally applies the brakes automatically if it thinks a crash is imminent. Each stage is designed to give you a chance to react - the system doesn't jump straight to automatic braking.
What the System Can Detect
The pre-collision system can detect the following as detectable objects (note that detectable objects differ depending on the function):
Note: Some limitations apply. For example, the system may not detect walls when the road is reflected on the wall or when the vehicle is approaching the wall at an angle.
The pre-collision system works through a series of escalating interventions, from initial warning to automatic braking.
Stage 1: Pre-Collision Warning
When the system determines that the possibility of a collision is high, a buzzer will sound and an icon and warning message will be displayed on the multi-information display to urge the driver to take evasive action.
If the detectable object is a vehicle, there may be cases where moderate braking will be performed with the warning.
If the system determines that the accelerator pedal is strongly depressed, a specific icon and message will be displayed on the multi-information display.
Stage 2: Pre-Collision Brake Assist
If the system determines that the possibility of a collision is high and the brake operation by the driver is insufficient, the braking power will be increased. This augments the driver's braking effort to help achieve collision avoidance.
Stage 3: Pre-Collision Brake Control
If the system determines that the possibility of a collision is extremely high, the brakes are automatically applied to help avoid the collision or reduce the impact of the collision. This automatic intervention occurs when collision risk is judged to be imminent.
Stage 4: Emergency Steering Assist
If the system determines that the following conditions are all met, assistance will be provided to help enhance vehicle stability and prevent lane departure:
During assistance, in addition to the pre-collision warning, a specific icon will be displayed on the multi-information display.
Enabling and Disabling the System
You can turn your PCS on or off through your vehicle's customize settings (detailed instructions are on page 647).
Important Default Behavior: Your PCS automatically turns back on every time you start the vehicle - even if you'd disabled it before. This is intentional. Toyota's designed it this way so the safety system is always active by default, protecting you unless you actively turn it off.
System Status Indicator
When the system is disabled, the PCS warning light will illuminate and a message will be displayed on the multi-information display. This visual indicator confirms that the system is not actively monitoring for collision threats.
Adjusting Warning Timing (Page 277)
You can adjust when the system triggers its warning and interventions by selecting one of three timing options:
Important Linkage: When the pre-collision warning timing is changed, the emergency steering assist timing will also be changed accordingly.
System Interactions with Other Driver Assists (Page 277)
The pre-collision system communicates with other driver assistance systems and will automatically override your user settings in certain conditions to ensure maximum safety:
Vehicle with Driver Monitor Camera
When the system determines that the driver is not facing forward, the pre-collision warning and emergency steering assist will operate at the (earlier) timing, regardless of your user setting. The vehicle prioritizes safety when the driver's attention is diverted.
Dynamic Radar Cruise Control (DRCC)
When the dynamic radar cruise control is operating, the pre-collision warning will operate at the (earlier) timing, regardless of your user setting. The systems work together to maintain safer following distances and collision avoidance.
Traffic Jam Assist
When the Traffic Jam Assist is operating, the pre-collision warning will operate at the (earlier) timing, regardless of your user setting. This coordination ensures consistent collision avoidance behavior during low-speed traffic situations.
Radar Sensor Variations (Page 277)
The effectiveness of emergency steering assist depends on your vehicle's sensor configuration:
Default settings may change in conjunction with your vehicle's My Settings configuration. See page 647 for detailed customization procedures.
Keep sensors clean for optimal performance
The radar sensor and front camera can be affected by snow, dirt, stickers, or other debris. Regular cleaning ensures the PCS functions at full capability. This is preventive maintenance that many owners find extends system reliability.
Understand that sensitivity settings control timing, not detection range
Sensitivity adjustments change when the system alerts you, not how far it can detect. Choosing "Earlier" or "Later" warning timing affects user experience but doesn't change the physical sensor range. Select the setting that lets you maintain awareness without being overwhelmed by false alerts.
System resets on every startup for safety consistency
The PCS automatically enables each time you start the vehicle. This intentional behavior ensures the safety system is active unless you explicitly disable it, protecting against scenarios where you forget to re-enable it after previously disabling it.
Sensor recalibration may be needed after major events
If your windshield is replaced or the vehicle is in an accident, the camera calibration may be affected. This typically requires a visit to a Toyota dealer or qualified technician. Address this promptly to maintain system effectiveness.
Sensor obstruction issues
Snow, ice, dirt, or debris on the radar sensor or front camera will cause PCS malfunction warnings. The system cannot detect properly when sensors are blocked. Regular cleaning is preventive maintenance that prevents false warnings.
Variable effectiveness in different conditions
The system may not activate or function fully if you're driving at low speeds or during sharp turns. It's most effective at normal highway speeds with stable steering inputs. This is normal behavior and not a malfunction.
False alerts after rain or washing
Moisture on the sensors can trigger false PCS and DRCC malfunction messages after car washing or during heavy rain. This typically resolves once sensors dry out, but can take hours. Understanding this as normal behavior prevents unnecessary dealer visits.
Off-Road Specific: Low overpass and 4 Low mode behavior
Some J250 owners have reported experiencing PCS false collision warnings when driving under low overpasses or in 4 Low mode off-road situations. Community discussions suggest the system may be applying conservative thresholds in these scenarios. If you experience alerts during technical off-road driving, you can temporarily disable the system through the vehicle settings menu.
How the dual-sensor system works
The PCS uses both a forward-facing camera and radar sensors that work in concert. This dual-sensor approach provides more reliable detection than either technology alone, but also means both sensors must be functioning and clean to maintain effectiveness.
Why the multi-stage response
The progression from warning to brake assist to automatic braking is designed to give drivers maximum opportunity to react. The system doesn't jump straight to automatic braking. Instead, it gives you multiple chances to take control of the situation, building in layers of protection.
J250 owner community resources
The Land Cruiser Forum and IH8MUD.com have dedicated sections for 2024+ Land Cruiser (J250) discussions where owners share configuration tips, common issues, and real-world experiences with the PCS and other driver assists. These are valuable resources for learning from other owners' experiences.
Official Manual Sources:
Community and Informational Sources:
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community and authoritative automotive sources. Always follow your official owner's manual for warranty compliance and safety-critical procedures. This is a reference guide only and does not replace the manufacturer's recommendations. Driving safely is solely the responsibility of the driver. Do not over-rely on driver assistance systems.
Pre-Collision System Overview, Sensor Detection, Collision Avoidance, Safety Warning
WARNING
For safe use
- For safe use: See Owner's Manual page 254
- When to disable the pre-collision system: See Owner's Manual page 254
Understanding the Pre-Collision System
System Overview
- Vehicles: All vehicle types
- Bicycles: Including riders
- Pedestrians: Walking or standing in vehicle path
- Motorcycles: Only when being ridden
- Walls: Physical barriers and large stationary objects
How the System Works: The Warning Progression
- The possibility of a collision is high
- There is sufficient space within the lane to perform evasive steering maneuvers
- The driver is operating the steering
Configuration and Customization
- Earlier — System triggers warnings sooner; more aggressive protection, may alert you to situations you're already handling
- Default — System triggers at factory-calibrated timing; recommended for most drivers
- Later — System triggers warnings at a later point; less aggressive, gives you more time to react, requires more confidence in your driving
Traffic Jam Assist
- Vehicles without front side radar sensors: When "later" timing is selected, the emergency steering assist will not operate in most cases
- Vehicles with front side radar sensors: When "later" timing is selected, the emergency steering assist (excluding the active steering function) will not operate in most cases
Customization Settings Reference (Page 657)
| Function | Customized Setting | Available Options |
| Pre-Collision System | On / Off | Selectable in all vehicle configurations |
| Warning Timing | Earlier / Default / Later | Selectable in all vehicle configurations |
Community Tips & Real-World Insights
Pro Tips from J250 Owners
Things to Know About Limitations
Helpful Background
- System overview and function: Pages 266-267
- Configuration and customization: Page 277
- Settings reference table: Page 657
- Safety precautions: Page 254
- Detailed customization procedures: Page 647
- West Edmonton Mall Toyota
- Colonial Toyota
- Toyota Owners Club
- IH8MUD Forum
- ToyotaSpace
- Land Cruiser Forum
- Elgin Toyota
