New to hybrid startup? Here's everything you need to know about starting and stopping your Land Cruiser's hybrid system, with community tips and troubleshooting. (Reference: Owner's Manual, pg. 220-222, 613)
WARNING - Critical Safety Alert
Always start the hybrid system while sitting in the driver's seat. Do not depress the accelerator pedal while starting the hybrid system under any circumstances. Doing so may cause an accident resulting in death or serious injury.
Source: Page 222
Service Requirements
If the hybrid system becomes difficult to start, have a dealer check it immediately.
If the power switch seems to be operating somewhat differently than usual, such as the switch sticking slightly, there may be a malfunction. Contact your Toyota dealer immediately.
Source: Page 222
Prerequisites
Time Required: Less than 30 seconds
Skill Level: Basic
Step-by-Step Starting Procedure
Important: When operating the power switch, one short, firm press is enough. It is not necessary to press and hold the switch. The vehicle will not move when the 'READY' indicator is off.
Understanding what the power switch illumination means:
Step-by-Step Stopping Procedure
Automatic Hybrid System Shut-off Feature
Your Land Cruiser has a smart shut-off feature: If you leave the hybrid system running with the shift lever in P, the system will automatically shut down after approximately 1 hour. This feature conserves the 12-volt battery and is designed for situations where you might accidentally leave the engine running.
The 1-hour timer resets if you depress the brake pedal or move the shift lever out of the P position.
When you lock the doors (either from inside with the door lock switch or from outside with the mechanical key), the automatic shut-off feature is disabled. The timer re-activates if the driver's door is opened again. This allows you to lock the vehicle without worrying about premature automatic shutdown.
Note: Cooling Fan After Shutdown
After you've turned off the power switch, you may notice the cooling fan continues running even though the power switch is off. This is normal and is part of the thermal management system. The cooling fan will stop automatically after the system cools down. Do not be alarmed if you hear it running for 30-60 seconds after shutdown.
If the system doesn't start despite following the correct procedure, check for these potential causes:
1. Electronic Key Not Functioning
Verify the key is near the vehicle (within the proximity range). Check the electronic key battery isn't dead. See manual page 615 for key battery replacement.
2. Insufficient Fuel
Check fuel gauge on dashboard. Refuel vehicle if needed (See manual page 249).
3. Immobilizer System Issue
The security system may not have been deactivated. This requires dealer service. Contact your Toyota dealer immediately.
4. Electrical System Problems
Electronic key battery might be depleted. A blown fuse might be affecting starting circuits. Depending on the malfunction type, an interim measure is available to start the system. See page 613 for emergency starting procedures.
5. Hybrid Battery Temperature Extreme
If the traction battery (hybrid battery) is extremely cold (below -35°C / -31°F), the system may not start. Allow the vehicle to warm up in a garage if this is the issue. See page 221 for more information on battery temperature.
6. 12-Volt Battery Issue (Most Common)
If interior lights and headlights are DIM or the horn is WEAK: The 12-volt battery may be discharged. See manual page 617 for jump-starting procedures.
If interior lights and headlights DON'T TURN ON or horn is SILENT: The 12-volt battery may be completely discharged OR 12-volt battery terminals may be loose or corroded. Check battery connections (page 548) or jump-start (page 617).
When to Call Your Dealer
If none of these checks resolve the starting issue, or if you don't know how to perform the troubleshooting steps safely, contact your Toyota dealer immediately.
While your Land Cruiser has a powerful traction (hybrid) battery, the 12-volt battery is the critical component for starting. Here's why:
The 12V battery boots multiple computer systems (approximately 7 systems) BEFORE the traction battery comes online. Only after these systems are fully booted and online can the main traction battery be brought online to start the engine. This startup sequence is unique to hybrids and different from traditional vehicles.
Common misconception: Many owners unfamiliar with this sequence mistakenly think the traction battery can help with starting if the 12V battery is weak. It cannot. The traction battery cannot engage until the 12V has completed its boot sequence.
This understanding helps you recognize normal startup behavior versus actual problems. A weak 12V battery is the most common reason hybrids won't start.
Keep a Jump Box in Your Vehicle
Multiple J250 owners recommend keeping a lithium jump box or NOCO jump box readily available. This is particularly important in cold climates where 12V battery stress is higher. A quality lithium jump box (like NOCO brand) is compact, maintains charge longer than traditional lead-acid jump starters, and handles the J250's starting demands well.
Check 12V Battery Voltage Regularly
Use a multimeter to verify battery voltage; a healthy battery should read around 12.6 volts. This simple preventative check helps avoid no-start surprises. Do this check particularly before winter driving season in cold climates.
Inspect Battery Terminals for Corrosion
Corroded battery terminals are a common cause of starting issues. Check connections are tight before assuming a deeper problem. This simple inspection can save a dealer service visit.
Understand System Boot-Up Behavior
The J250 uses a NiMH (nickel-metal hydride) hybrid battery, not lithium. NiMH batteries are functional in temperature extremes and can handle the J250's startup sequence down to the temperature thresholds noted in your manual. In extremely cold conditions, the system uses a backup starter motor to turn over the engine more gently rather than relying on aggressive traction motor cranking. This is normal operation, not a malfunction.
The i-FORCE MAX hybrid system is well-suited for cold climates:
The NiMH traction battery operates effectively even in cold conditions, maintaining the ability to support system startup. While the 12V battery still suffers from cold-weather performance degradation (which is the main cold-start concern in any vehicle), the J250's hybrid system design handles temperature-related challenges well.
Cold climate recommendation: Keep a lithium jump box accessible. Before winter, have your 12V battery checked by a professional to ensure it's in good condition.
Warranty note: The NiMH traction battery is covered by a 10-year/150,000-mile warranty from Toyota, reflecting manufacturer confidence in its durability and reliability across all climates.
For roadside confidence, keep these items accessible:
Know the jump-starting locations before you need them: Rear left interior (auxiliary 12V connection point) and front right engine bay (primary battery location).
Primary Pages (This Thread):
Supporting References:
Based on common needs identified in this guide, these products may be helpful for J250 owners:
For exact product compatibility and current availability, search Amazon or your preferred automotive retailer using these terms: "lithium jump starter portable", "Toyota 12 volt battery", "battery terminal cleaner kit", "digital multimeter battery tester".
Community and Expert Sources:
Disclaimer
This guide is derived from the official 2024+ Toyota Land Cruiser (J250) Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance and safety. This is a reference guide only. For vehicle-specific concerns, diagnosis, or repair, consult your Toyota dealer.
Hybrid System Starting, Power Switch Operation, READY Indicator, Starting and Stopping Procedures
Source: Page 222
Source: Page 222
Starting the Hybrid System
Prerequisites
- You must be sitting in the driver's seat (safety requirement)
- The electronic key (smart key) must be with you in the vehicle
- The parking brake should be verified set
- The shift lever must be in the P (Park) position
Skill Level: Basic
- Verify Parking Brake: Pull the parking brake switch to confirm it's engaged. Check that the parking brake indicator illuminates on the dashboard. This prevents accidental vehicle movement during startup.
- Shift Lever Position: Confirm the shift lever is in the P (Park) position. Your Land Cruiser won't start if the shift is in any other position. This is a safety interlock that prevents starting in Drive, Reverse, or Neutral.
- Depress Brake Pedal Firmly: Press the brake pedal down firmly with your foot. A message will be displayed on the multi-information display. If the startup message does NOT appear, the hybrid system cannot be started. If this happens, check that your electronic key is present and try again.
- Press Power Switch (Correct Technique): Press the power switch once, shortly and firmly. Do NOT hold the switch down - one firm, brief press is sufficient. The power switch can start the system from any power switch mode (OFF, ACC, or ON). When the READY indicator turns on, the hybrid system will operate normally.
- Verify READY Indicator Illuminates: Continue holding the brake pedal until the READY indicator illuminates. The vehicle will NOT move when the READY indicator is off. Once READY illuminates, the system is fully online and ready to drive. Release the brake pedal and proceed to drive normally.
Power Switch Illumination States
| Condition | Illumination | What It Means |
| Door opened (with electronic key) | Illuminates | System is ready for access |
| Brake pressed + electronic key near + power OFF | Blinks | System is responding to your presence |
| Power in ACC or ON mode | Illuminates | System is in accessory or on position |
| Switching from ACC/ON to OFF | Illuminates briefly, then off | Normal shutdown sequence |
Stopping the Hybrid System
- Stop Vehicle Completely: Bring your Land Cruiser to a complete stop. The hybrid system cannot be shut down while moving.
- Engage Parking Brake: If your parking brake is in manual mode, set the parking brake manually. Verify the parking brake indicator illuminates on the dashboard. (If your parking brake is in automatic mode, this may be automatic.)
- Shift to P (Park): Move the shift lever to the P (Park) position. Do NOT continue pressing the shift lever button after you've moved it to P. Release the button once the shift is complete.
- Press Power Switch: Press the power switch once, shortly and firmly. The hybrid system will stop immediately. The meter display will go dark/extinguish. This is confirmation that the system has shut down completely.
- Verify System is Off: Release the brake pedal. Check the multi-information display. Confirm that "ACCESSORY" or "POWER ON" is NOT shown on the display. This verifies the system has fully powered down.
Troubleshooting: Hybrid System Won't Start
Why the 12V Battery Matters in Hybrids
Pro Tips from the J250 Community
Cold Weather Starting Considerations
Emergency Preparedness
- Lithium jump box (NOCO brand is popular among J250 owners for reliability and compact size)
- Basic multimeter for checking battery voltage
- Battery terminal cleaner kit (prevents corrosion)
- Flashlight or headlamp (cold-weather emergency prep)
- Page 220: Starting procedure, READY indicator, power switch operation
- Page 222: Stopping procedure, safety warnings, automatic shut-off feature
- Page 613: Emergency procedures when system won't start
- Page 221: Hybrid battery temperature considerations
- Page 249: Fuel system and refueling
- Page 548: Battery connections and terminal maintenance
- Page 615: Electronic key battery replacement
- Page 617: Jump-starting procedures
- Page 619: Battery replacement
Recommended Products
- Jump starter box (particularly lithium portable models used by the community)
- 12V battery replacement (Toyota Genuine for warranty compatibility)
- Multimeter for checking battery voltage and electrical diagnostics
- Flashlight or headlamp for emergency diagnostics
- Primary procedure and warnings: Pages 220-222
- Emergency procedures: Page 613
- Supporting technical information: Pages 221, 249, 548, 615, 617, 619
- 250landcruiser.com - J250-specific forum and technical discussions
- Land Cruiser Forum (landcruiserforum.com) - Established J250 owner community
- IH8MUD.com - Off-road and automotive expertise community
- RepairPal - Professional automotive diagnostic resource
- Toyota Parts Center - OEM technical resources
Disclaimer
