Proper tire pressure is one of those things that seems simple but really matters - it affects how your Land Cruiser handles, how long your tires last, how much you pay at the pump, and your safety. Here's what you need to know about checking pressure, understanding your tire options, and what those warning lights mean.
(Reference: Owner's Manual, pg. 561, 590, 635)
Critical Measurement Rule:
Check only when the tires are cold. If your vehicle has been parked for at least 3 hours or has not been driven for more than 1.5 km (1 mile), you will get an accurate cold tire inflation pressure reading.
Always use a tire pressure gauge. You can't tell if a tire is properly inflated just by looking at it.
It is normal for the tire inflation pressure to be higher after driving as heat is generated in the tire. Do not reduce tire inflation pressure after driving.
Never exceed the vehicle capacity weight. Passengers and luggage weight should be placed so that the vehicle is balanced.
Source: Owner's Manual page 561
Incorrect tire pressure affects all of these:
Important: If a tire needs frequent refilling, have it checked by your Toyota dealer.
All 2024+ Land Cruiser models use the same tire pressure across all wheel positions:
These are recommended cold tire inflation pressures. Source: Owner's Manual page 635
Option 1: 20-Inch Tires (Standard)
Option 2: 18-Inch Tires - Type A
Option 3: 18-Inch Tires - Type B
Step-by-Step Procedure:
Check Interval: Check your tire pressure every two weeks - or once a month at minimum.
Important: Do not forget to check the spare.
Your Land Cruiser's tire pressure warning light provides three distinct scenarios with different meanings and required actions:
What you observe: Light blinks for approximately 1 minute, then stops (no buzzer sound)
What it means: Malfunction in the tire pressure warning system
What to do: Have the system checked by your Toyota dealer.
Source: Owner's Manual page 590
What you observe: Light comes on with buzzer sound (after weather changes or temperature drop)
What it means: Low tire inflation pressure from natural causes (temperature change)
What to do: After the temperature of the tires has lowered sufficiently (or stabilized), check the inflation pressure of each tire and adjust them to the specified level of 33 psi.
What you observe: Light comes on with buzzer sound (sudden appearance while driving)
What it means: Low tire inflation pressure from a flat or punctured tire
What to do: Immediately stop the vehicle in a safe place and perform the necessary actions (check tires for damage, repair as needed, or call for roadside assistance).
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with all specifications extracted verbatim. Always follow your official owner's manual for warranty compliance and the most current information. Verify against your vehicle's door jamb sticker for any trim-specific variations. This is a reference guide only and does not replace professional maintenance by a qualified technician.
Tire Pressure Checking, Cold PSI Specifications, Inflation Adjustment, Pressure Monitoring
Safety & Checking Guidelines
Effects of Incorrect Tire Inflation Pressure
- Reduced fuel economy
- Reduced driving comfort and poor handling
- Reduced tire life due to wear
- Reduced safety
- Damage to the drive train
Tire Pressure Specifications
| Wheel Position | Pressure (psi) | Pressure (kPa) | Pressure (kgf/cm²) |
| Front | 33 | 230 | 2.3 |
| Rear | 33 | 230 | 2.3 |
| Spare | 33 | 230 | 2.3 |
Tire and Wheel Options
| Specification | Value |
| Tire Size | 265/60R20 112H |
| Tire Pressure (all positions) | 33 psi (230 kPa, 2.3 kgf/cm²) |
| Wheel Size | 20 × 7 1/2J |
| Wheel Nut Torque | 97 ft·lbf (131 N·m, 13.4 kgf·m) |
| Tire Size | 245/70R18 110H |
| Wheel Size | 18 × 7J |
| Tire Size | 265/70R18 116S |
| Wheel Size | 18 × 7 1/2J |
How to Check Tire Pressure
- Remove the tire valve cap.
- Press the tip of the tire pressure gauge onto the tire valve.
- Read the pressure using the gauge gradations.
- If the tire inflation pressure is not at the recommended level (33 psi), adjust the pressure. If you add too much air, press the center of the valve to deflate.
- After completing the tire inflation pressure measurement and adjustment, apply soapy water to the valve and check for leakage.
- Put the tire valve cap back on.
Understanding Tire Pressure Warning Light
Scenario 1: System Malfunction
Scenario 2: Natural Pressure Loss
Scenario 3: Flat Tire
- Tire specifications and wheel data: Page 635
- Tire pressure checking procedure and effects: Page 561
- Tire pressure warning light guide: Page 590
