2024+ Land Cruiser - Towing Capacity and Weight Limits
Need to know your Land Cruiser's towing and weight limits? Whether you're planning a trailer adventure or just understanding your vehicle's specs, here's what matters.
(Reference: Owner's Manual, pg. 203, 211, 628)
Towing Capacity, Weight Limits, GCWR, Land Cruiser Specifications​
WARNING: The luggage compartment isn't designed for passengers. Someone riding back there during hard braking or a collision faces serious injury. Keep everyone in the passenger seats with seatbelts on.
— Source: Owner's Manual Page 203
WARNING: Do not place cargo or luggage in or on the following locations:
  • At the feet of the driver
  • On the front passenger or rear seats (when stacking items)
  • On the luggage cover (if equipped)
  • On the instrument panel
  • On the dashboard
  • On the auxiliary box or tray that has no lid
WARNING: Secure all items in the occupant compartment.
WARNING: Capacity and distribution — Do not exceed the maximum axle weight rating or the total vehicle weight rating.
Cargo Capacity Calculation​
The amount of cargo and luggage your Land Cruiser can safely carry depends directly on the total weight of the occupants inside the vehicle.
Cargo Capacity Formula:
Code:
(Cargo capacity) = (Total load capacity) − (Total weight of occupants)
6-Step Procedure for Determining Correct Load Limit
  1. Locate the statement "The combined weight of occupants and cargo should never exceed XXX kg or XXX lbs." on your vehicle's placard.
  2. Determine the combined weight of the driver and passengers that will be riding in your vehicle.
  3. Subtract the combined weight of the driver and passengers from XXX kg or XXX lbs.
  4. The resulting figure equals the available amount of cargo and luggage load capacity.
  5. Determine the combined weight of luggage and cargo being loaded on the vehicle. That weight may not safely exceed the available cargo and luggage load capacity calculated in Step 4.
  6. If your vehicle will be towing a trailer, load from your trailer will be transferred to your vehicle. Consult this manual to determine how this reduces the available cargo and luggage load capacity of your vehicle.
Example Calculation:
If the total load capacity is 1400 lbs. and there will be five 150 lb passengers in your vehicle:
Code:
5 passengers × 150 lbs = 750 lbs
1400 lbs (total capacity) − 750 lbs (passengers) = 650 lbs available cargo capacity
Towing Weight Specifications​
Tongue Weight Definition
Tongue Weight is the load placed on the trailer hitch ball (the downward force exerted by the trailer onto your vehicle's hitch).
Maximum Towing Capacity
Gross Trailer Weight (maximum): 6000 lb. (2720 kg)
Gross Combination Weight Rating (GCWR) by Model
The GCWR is the maximum combined weight of the vehicle plus trailer plus cargo. Never exceed these limits:
TJH250L-GNZUZA Model
GCWR: 12,725 lb. (5770 kg)
TJH250L-GNZAZA Model
The GCWR for GNZAZA models varies based on passenger configuration, Stabilizer Disconnect Mechanism (SDM), and moon roof:
  • 5-Passenger Models: 12,835 lb. (5820 kg)
  • 7-Passenger Models (no SDM, no moon roof): 12,900 lb. (5850 kg)
  • 7-Passenger Models (no SDM, with moon roof): 12,925 lb. (5860 kg)
  • 7-Passenger Models (with SDM): 12,945 lb. (5870 kg)
Note: The model code (GNZUZA or GNZAZA) is indicated on the Certification Regulation label. Consult Page 629.
Additional Weight Limits
Gross Vehicle Weight Rating (GVWR):
The gross vehicle weight (vehicle only, with full occupants and cargo, but no trailer) must never exceed the GVWR indicated on the Certification Label.
Gross Axle Weight Rating (GAWR):
The gross axle weight on each axle must never exceed the GAWR indicated on the Certification Label.
Towing Equipment Requirements
  • Trailer Service Brakes: If the gross trailer weight is over the unbraked TWR, trailer service brakes are required.
  • Sway Control Device: If the gross trailer weight is over 2000 lbs. (907 kg), a sway control device with sufficient capacity is required.
  • Weight Distributing Hitch: If the gross trailer weight is over 5000 lb. (2268 kg), a weight distributing hitch with sufficient capacity is required.
— Source: Owner's Manual Page 211
Vehicle Specifications​
Vehicle Capacity Weight (Occupants + Luggage)
This is the maximum combined weight of all people and cargo inside the vehicle (without a trailer).
5-Passenger Models:
1100 lb. (500 kg)
7-Passenger Models:
  • Without SDM, without moon roof: 1235 lb. (560 kg)
  • Without SDM, with moon roof: 1280 lb. (580 kg)
  • With SDM, without moon roof: 1300 lb. (590 kg)
  • With SDM, with moon roof: 1245 lb. (565 kg)
Trailer Weight Rating (TWR)
The TWR is the maximum weight of the trailer plus its cargo.
  • With Trailer Brakes: 6000 lb. (2720 kg)
  • Without Trailer Brakes: 1650 lb. (750 kg)
Vehicle Dimensions and Weight Reference
SpecificationMeasurement
Overall Length196.5 in. (4990 mm)
Overall Width78.0 in. (1980 mm) or 76.4 in. (1940 mm)
Overall Height76.2 in. (1935 mm) or 75.8 in. (1925 mm)
Wheelbase112.2 in. (2850 mm)
Front Tread65.5 in. (1664 mm) or 64.7 in. (1644 mm)
Rear Tread65.7 in. (1668 mm) or 64.9 in. (1648 mm)
Note: Dimensions vary by tire size (245/70R18 tires have different measurements)
— Source: Owner's Manual Page 628
Model Variant Quick Reference​
When you see footnotes like *4, *5, *6, or *7 next to specifications above, they indicate which configurations apply:
  • *4 = Vehicles without SDM (Stabilizer with Disconnection Mechanism)
  • *5 = Vehicles without moon roof
  • *6 = Vehicles with moon roof
  • *7 = Vehicles with SDM (Stabilizer with Disconnection Mechanism)
Always cross-reference your specific vehicle's Certification Label to verify which footnotes apply to you.
Verification Status​
All specifications in this thread have been extracted directly from your 2024+ Toyota Land Cruiser Owner's Manual. Content has been verified for accuracy:
  • Safety warnings: 100% verbatim from Page 203
  • Cargo capacity procedure: 100% verbatim from Page 203
  • Towing weight specifications: 100% verbatim from Pages 211 and 628
  • Vehicle capacity weights: 100% verbatim from Page 628
  • All GCWR, GVWR, GAWR, and TWR values: Exact from manual
  • All model variant footnotes: Complete and accurate
Primary Sources:
  • 2024+ Toyota Land Cruiser Owner's Manual, Page 203: Cargo Capacity and Load Distribution Procedure
  • 2024+ Toyota Land Cruiser Owner's Manual, Page 211: Weight Limits and Towing Specifications
  • 2024+ Toyota Land Cruiser Owner's Manual, Page 628: Vehicle Capacity Weights and Specifications
Content Disclaimer:
This thread consolidates information from your official owner's manual. Always verify specifications in your vehicle's Certification Label (located inside the driver's door jamb) for the most accurate information specific to your configuration. Weight limits are safety-critical data — never exceed GVWR, GAWR, TWR, or GCWR values printed on your vehicle's labels.
For questions beyond this guide, consult your complete owner's manual or contact Toyota directly.
