2024+ Land Cruiser - Using Crawl Control and Multi-Terrain Select
Want to master your Land Cruiser's off-road capabilities? Crawl Control and Multi-Terrain Select are powerful systems that make extreme terrain manageable. Here's what you need to know to use them effectively and safely.
(Reference: Owner's Manual, pg. 438-441)
Crawl Control, Multi-Terrain Select, Off-Road Systems, Land Cruiser​
Important Safety Information​
Know Your System's Limits
Crawl Control is a powerful tool, but it's not magic. The system can't overcome extreme conditions or extend your vehicle's physical capabilities. Before heading out, scout the terrain. If you can't drive it manually, Crawl Control won't magically make it passable. Always check conditions first and drive within what you're comfortable with.
Where the System Struggles
Crawl Control works best on rocky, moderate terrain. Skip it on these surfaces - the system just can't maintain a constant speed reliably:
- Extremely steep inclines (more than about 40 degrees)
- Extremely uneven surfaces (boulder fields, large gaps)
- Snow-covered roads or other slippery surfaces (not enough traction info for the system to work with)
Deactivating While Moving (Handle with Care)
If you need to turn off Crawl Control while the vehicle is moving, the system stops managing speed immediately. You lose automatic brake control, which means you need to be ready to manually control the vehicle. Best practice: stop first, then deactivate. If you must turn it off while moving, drive very carefully for the next few moments.
Watch for Brake Overheating
Extended Crawl Control use generates brake heat - it's using brake modulation to control speed, not just the engine. If the brakes get too hot, you'll hear a buzzer, see a malfunction message, and the Crawl Control will shut down temporarily. If this happens, find a safe spot and let the brakes cool. You can still drive normally while they cool - just give them a break from Crawl Control duty.
Transmission Can Overheat Too
Just like the brakes, the transmission works hard in Crawl Control mode. If it gets too hot, you'll hear a buzzer and see a message - the system shuts down to protect itself. Find a safe place to park and let everything cool. This is rare, but it happens in extreme conditions like continuous rock crawling for extended periods.
Getting the Most from Multi-Terrain Select
Before you drive, check that your selected mode's indicators light up on the display. If they don't, the system isn't active - select the mode again.
The mode descriptions are guidelines, not guarantees. Real terrain varies. A mode labeled for "rocky terrain" might not be ideal if the rocks are particularly loose or if the pitch is steeper than usual. Trust the system, but also trust your judgment - if conditions don't match what you selected, change modes.
Understanding Crawl Control​
Think of It as Off-Road Cruise Control
Crawl Control is your Land Cruiser's secret weapon for extreme rocky terrain. Instead of you managing throttle and brake at crawling speeds (where tiny movements mean the difference between control and chaos), the system handles it automatically. You focus entirely on steering - choosing your line through rocks and obstacles - while Crawl Control keeps the speed constant.
It works on rocky, uneven surfaces where a human driver would struggle. The hybrid system and brakes work together to maintain a steady, slow speed - no accelerator or brake pedal needed from you. You just steer.
What You Need to Make It Work
Four things have to be true for Crawl Control to activate:
  • Engine running (The hybrid system needs to be on (obviously)
  • Gear selected (Any gear except Park or Neutral (D, R, or any manual position)
  • L4 engagement (Four-wheel drive must be in Low range (this is critical - H4 won't work)
  • Door closed (Safety lock requirement (system disables if any door opens)
Activation Steps
  1. Press the DAC/CRAWL switch located on the dashboard
    - The indicator light illuminates on the switch
    - Crawl Control indicator lights up on the meter
    - The slip indicator light flashes briefly
  2. Use the MODE SELECT switch to choose your driving mode
    - Turn the switch left or right to select the appropriate mode
    - The selected mode appears on your multi-information display
  3. Begin driving carefully (the system now controls speed automatically for low-speed off-road operation
(Source: Pages 438-439
How Crawl Control Works
Crawl Control is best understood as off-road cruise control. Once activated:
- The system automatically manages acceleration and braking at low speeds
- You maintain control of steering while the system handles speed
- Do NOT use the accelerator or brake pedal while system is active
- Vibrations are normal (brake modulation in action)
- Motor sounds after stopping are normal
(Source: Pages 438, 440-441
Operational Conditions and Speed Limits
Crawl Control has different capabilities based on speed and differential lock status:
With UNLOCKED rear differential (standard 4WD mode):
- System operates normally up to approximately 6 mph (10 km/h)
- Above 15 mph (25 km/h), both hybrid system control and brake control are unavailable
- Between 6-15 mph, limited control available
With LOCKED rear differential (electronic locking engaged):
- Above 6 mph (10 km/h), hybrid system control becomes unavailable
- Brake control may continue but with reduced effectiveness
(Source: Page 440
Automatic Deactivation
Crawl Control will automatically disable in these situations (buzzer sounds as warning):
  • When shift lever is moved to P (Park) or N (Neutral)
  • When four-wheel drive control switch is moved to H4 (High range)
  • When driver's door is opened
  • When vehicle speed exceeds operational limits for current differential lock status
When auto-deactivation occurs:
- The Crawl Control indicator flashes and then goes off
- A buzzer sounds briefly
- A message appears on the multi-information display confirming deactivation
(Source: Page 440
Manual Deactivation
To turn off Crawl Control:
  1. Press the DAC/CRAWL switch again while the indicator light is illuminated
  2. Confirmation: The Crawl Control indicator and slip indicator lights go off
  3. Display message: The multi-information display briefly shows a message confirming Crawl Control has been turned off
    IMPORTANT: If deactivating while moving, stop the vehicle first OR drive extremely carefully afterward as the vehicle will immediately lose automatic speed control.
(Source: Pages 439-440
Normal Operating Sensations (Not Malfunctions)
Don't be alarmed by these normal Crawl Control operational characteristics:
  • Vibrations through vehicle body and steering (Brake and drive control adjustments create subtle vibrations
  • Motor sound after vehicle stops (The hybrid system makes characteristic sounds during operation and after shutdown
  • Sound from engine compartment (May hear sounds when hybrid system starts or vehicle begins moving
These indicate the system is actively controlling traction - they are not malfunctions.
(Source: Pages 440-441
Multi-Terrain Select System​
What Multi-Terrain Select Does
Multi-Terrain Select is a sophisticated system that optimizes your vehicle's brake control, drive force distribution, and suspension settings based on terrain type. When you select a mode matching current conditions, the system automatically calibrates itself for optimal traction and stability on that specific terrain.
When AUTO mode is selected, all three systems (brake control, drive force control, and suspension control) are optimized automatically according to detected road conditions in real-time.
(Source: Page 441
The Five Selectable Modes
Using the MODE SELECT switch, turn left or right to select the mode that most closely matches your current terrain. Each mode optimizes the vehicle for specific conditions:
ModeBest ForUse Case
MUD & SANDSoft, shifting terrainMaximum tire slippage for deep mud, sand, and compressible surfaces; allows tread clearing
LOOSE ROCKRocky, unstable surfacesSecond-highest tire slippage for loose rock and boulder fields
MOGULUneven terrainMid-range tire slippage for rutted, mogul-like terrain
ROCK & DIRTMixed hard terrainReduced tire slippage for solid ground with mixed rock and dirt surfaces
ROCKSolid groundMinimum tire slippage for solid rock and hard-packed terrain
(Source: Page 439
Using the MODE SELECT Switch
To change modes:
  1. Turn the switch LEFT or RIGHT to select the desired mode (while driving or stationary)
  2. Visual feedback: Both the 7-inch and 12.3-inch multi-information displays show the available modes with mode selection indicators
  3. Mode activation: The selected mode indicator illuminates on your display
  4. Real-time adjustment: You can change modes at any time while Crawl Control is active (the system adapts instantly
(Source: Page 439
Community Best Practices​
Think of Crawl Control as Off-Road Cruise Control
Automatically manages acceleration and braking at low speeds so you can focus on steering. Put in low, select first gear, keep your foot on the brake while the system handles speed management. This is the core principle for effective use.
Give the System Time to React in Soft Terrain
For deep sand or mud, give the system a moment to react before applying more throttle. Crawl Control needs microseconds to modulate brake and drive force, especially on compressible surfaces.
Multi-Terrain Select and Crawl Control Work Best Together
MTS optimizes suspension and traction control for the terrain; Crawl Control handles speed automation. Using both systems together provides comprehensive terrain adaptation. MTS works best at low speeds with Crawl Control engaged.
Select Mode That Matches Current Terrain
Real-world testing showed the J250 handles rocky, muddy, sandy, and steeply rutted terrain without issue. Matching the MTS mode to what you're currently driving through optimizes all three control systems.
Forgetting L4 Engagement Before Activation
Crawl Control will not function unless the four-wheel drive control switch is in L4 (Low range). A common setup error is trying to use Crawl Control in H4 or 2H and expecting it to work. The system is designed specifically for low-speed, high-torque scenarios that only exist in low-range 4WD.
Manual Throttle/Brake Control While System is Active
The accelerator and brake should not be operated when using Crawl Control. The system is designed to manage these automatically at low speeds. Manually overriding throttle or brake while the system is actively controlling defeats the purpose and can create dangerous instability.
When turning off Crawl Control while driving, stop the vehicle first before pressing the DAC/CRAWL switch. If you must disengage while in motion, drive extremely carefully afterward as the vehicle will immediately lose automatic speed control.
Misinterpreting Vibrations as Malfunction
Crawl Control uses the brakes to maintain low speed (not engine compression braking alone). This causes noticeable vibrations through the steering wheel and vehicle body. Many new users think this indicates a problem when it's actually normal operation. Excessive braking pressure generates vibrations in the driveline (this is physics, not a malfunction).
Expecting Perfect Line with Crawl Control
Crawl Control individually grabs wheels for traction (ABS-modulation based), which causes more sliding than manual throttle control. Experienced rock crawlers understand that the system trades line precision for maximum traction and safety. It's not designed for precise steering control on technical terrain.
System Integration Context​
Crawl Control and Multi-Terrain Select work alongside:
- Electronic locking rear differential (for maximum traction)
- Locking center differential
- A-TRAC (All-Terrain Traction Control) during normal driving
- DAC (Downhill Assist Control) for steep descents
- Optional Stabilizer Disconnect Mechanism (SDM) for maximum articulation
These systems work together; Crawl Control is the "autopilot" for extreme low-speed scenarios specifically.
Real-world testing by established reviewers confirmed the J250 Land Cruiser handles loose gravel tracks, deeply rutted terrain, steep inclines, axle-twisting dips, and log bridges without issue. Multi-Terrain Select adapts traction control, drive force distribution, and suspension settings dynamically for these conditions.
Related Topics​
For additional Land Cruiser J250 off-road system information, see:
- Locking the Center and Rear Differentials
- How to Use the 4WD System (H4 to L4 Shifting)
- Downhill Assist Control (DAC)
- SDM (Stabilizer Disconnection Mechanism) Guide
- Multi-Terrain Monitor and Camera Use
Manual Pages Reference​
Complete System Information: Pages 438-441 of your 2024+ Toyota Land Cruiser Owner's Manual
The extracted pages from your official manual are available for download:
  • Full procedure and system explanations (4 pages)
  • Visual diagrams of controls
  • Complete specifications and operational data
  • System overview and Crawl Control activation: Page 438
  • Multi-Terrain Select modes and Crawl Control deactivation: Page 439
  • Operational conditions, limitations, and auto-cancellation: Page 440
  • System behavior and Multi-Terrain Select details: Page 441
Additional Research Sources:
  • iH8MUD.com Forum - Established Toyota off-road community
  • Land Cruiser Forums - Generation-specific discussions
  • Land Cruiser Club - Owner experiences and real-world feedback
  • Toyota Support - Official system documentation
  • Brown Car Guy - Independent testing and reviews
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual (OM60Y03U) with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance and system operation. This is a reference guide only. When in doubt about system operation or vehicle maintenance, consult your Toyota dealership.
