Wondering what those warning messages on your dash mean? Understanding your Land Cruiser's warning messages is key for safe operation and proper maintenance. This guide pulls together scattered manual information into one clear reference. (Reference: Owner's Manual, pages 595-600)
When You Need Dealer Service Right Now:
When brake or accelerator pedal warnings appear while driving assist systems (Pre-Collision system, dynamic radar cruise control) are operating, you must decelerate the vehicle or follow instructions shown on the multi-information display. (Page 596)
Your Land Cruiser uses three distinct warning categories based on the visual indicator and audio signal. Understanding this hierarchy will help you prioritize your response.
Meaning: This is serious, a system related to driving is malfunctioning or danger could result if you don't address it. It could also mean damage to the vehicle or a safety hazard.
Action Required: Respond immediately. Pull over to a safe location and follow multi-information display instructions.
Examples: Check Engine Light, Brake System warnings, Oil Pressure warnings, Charging System warnings
Meaning: This means a system on your display may be malfunctioning and needs attention.
Action Required: Check system status immediately. Address if vehicle performance is affected.
Timeline: Schedule service within 1-2 days.
Examples: Safety system sensor warnings, battery warnings, coolant temperature warnings
Meaning: This usually means either an electrical component isn't working right, maintenance is due, an operation was performed incorrectly, or the system is telling you how to do something correctly.
Action Required: Address at convenient time. Follow reset procedures if provided in your manual.
Timeline: Can be scheduled at your next service appointment.
Examples: Oil change reminder, service interval notifications, door ajar, low fuel
Engine Service Required Visit Your Dealer
Source: Page 598
The engine or an engine component is malfunctioning. Have the vehicle inspected by your Toyota dealer immediately. This is a critical warning requiring immediate dealer service.
Engine Overheating
Source: Page 598
The engine coolant temperature is elevated. Your vehicle's acceleration performance and speed may be automatically reduced as a safety feature. Continue driving at reduced speed until the engine cools down. The message will disappear and engine power will resume once the engine coolant temperature returns to normal. If the message does not disappear after driving for a while, or comes on and off frequently, contact your Toyota dealer.
Engine Oil Level Low - Add or Replace
Source: Page 598
The engine oil level may be low. Actions: Check the level of the engine oil and add engine oil if necessary. This message may also display if the vehicle is stopped on a slope; try moving the vehicle to a level surface to see if the message disappears.
Oil Maintenance Required Soon
Source: Page 598
The engine oil should be scheduled to be changed. Check the engine oil level and change it if necessary. After changing the engine oil, reset this message using the procedure on page 542 of your manual.
Oil Maintenance Required Visit Your Dealer
Source: Page 598
The engine oil change is due based on your vehicle's maintenance schedule. Perform the necessary oil maintenance and reset the message after completion.
Shift into P before exiting vehicle
Source: Page 596
This message displays when the driver's door is opened without turning the power switch to OFF with the shift lever in any position other than P. Action: Shift the shift lever to P before exiting. This is a safety interlock to prevent the vehicle from moving unintentionally.
Auto Power OFF to Conserve Battery
Source: Page 596
Power was turned off due to the automatic power off function, which conserves battery when your vehicle is idle. The next time you start the engine, rev the engine slightly and maintain that level for approximately 5 minutes to recharge the battery.
Source: Page 598
All maintenance according to the maintenance schedule should be performed soon. This message comes on approximately 4,500 miles (7,200 km) after the message has been reset. If necessary, perform maintenance and reset the message on page 542. Refer to your separate Scheduled Maintenance supplement for the maintenance intervals applicable to your vehicle.
Source: Page 598
All maintenance is required according to your vehicle's maintenance schedule. This message comes on approximately 5,000 miles (8,000 km) after the message has been reset. Action: Perform the necessary maintenance and reset the message on page 542 of your manual. Important: The maintenance reminder will not work properly unless the message has been reset after service.
System Stopped Rear Camera - Low Battery
Source: Page 598-600
Affects: Proactive Driving Assist (PDA), Blind Spot Monitor (BSM), Rear Cross Traffic Alert (RCTA), Safe Exit Assist, Intuitive Parking Assist, Parking Support Brake (PKSB), and Rear Camera Detection (if equipped)
Correction Methods:
System Stopped Front Camera - Low Visibility
Source: Page 598
Affects: Pre-Collision System (PCS), Lane Departure Alert (LDA), Lane Tracing Assist (LTA), Lane Change Assist (if equipped), Automatic High Beam (AHB), Dynamic radar cruise control, Road Sign Assist (if equipped), Proactive Driving Assist (PDA)
Correction Methods:
System Stopped Front Camera - Out of Temperature Range
Source: Page 598
The front camera temperature is outside the normal operating range. Action: Wait until the system returns to normal operating temperature. The safety systems will resume operation automatically when the temperature normalizes.
Color-Coded Response Priority
Your Land Cruiser uses a three-tier warning system based on light color:
A buzzer sounds the first time a warning message appears on the display. A continuous audio alarm indicates critical warnings. In some cases, the buzzer may not be heard if you're in a particularly noisy location or if other audio is playing.
A routine inspection of your vehicle's sensors every 8,000 kilometers (approximately 5,000 miles) ensures critical components are functioning properly. This preventive maintenance can prevent many intermittent warning messages from appearing. Pay special attention to:
The "Check Fuel Cap" warning can sometimes appear due to a loosely secured fuel cap, which may temporarily imbalance the fuel system. This message typically resolves after you tighten the fuel cap and drive the vehicle for 50-100 miles or through several driving cycles. If the message persists after tightening and this driving period, have the fuel system inspected by your dealer.
When resetting tire pressure warnings, locate the tire pressure warning reset switch on your dashboard. Press and hold the switch until the tire pressure warning light blinks slowly three times and the message "TIRE PRESSURE RESET PROCEEDING" appears. Allow the system to complete the reset (wait a few minutes) before turning the ignition OFF. Important: Always verify actual tire pressures are correct before resetting the warning.
After adjusting tire pressure or replacing tires, sensors must be reinitialized. Failure to do this can cause persistent false tire pressure warnings even when tire pressures are correct. Always reset tire pressure sensors after any tire service work.
Brake System Warning (Red Light)
The red brake warning light is one of the most serious warnings. While the light may indicate the parking brake is applied, if the parking brake is properly released and the light remains on, it indicates low brake fluid level, a safety-critical issue requiring immediate inspection. Ignoring this warning could result in loss of stopping power. Pull over immediately and have your vehicle inspected by a Toyota dealer.
Oil Pressure Warning (Red Light)
The low oil pressure warning indicates a serious lack of engine lubrication. If ignored, low oil pressure can result in engine seizure, a catastrophic failure that typically requires complete engine replacement. This is one of the most expensive repairs possible. Pull over immediately if you see this warning and have the engine inspected before driving further.
Charging System Warning (Red Light / Battery Icon)
The charging system warning indicates a fault in the electrical charging system. If this red light comes on while driving, the engine may shut down soon, potentially leaving you stranded. Continuing to drive can lead to battery drain and engine stall. Pull over safely and have your vehicle inspected immediately. Do not attempt to drive long distances with this warning active.
This warning indicates the engine or an engine component is malfunctioning. This is always a critical warning requiring immediate dealer inspection. The specific issue could range from minor sensor malfunctions to serious engine problems.
Important Disclaimer:
This guide is derived from the official 2024+ Toyota Land Cruiser (J250) Owner's Manual (OM60Y03U) with supplementary information from the owner community and authoritative automotive sources. Always consult your official owner's manual for warranty compliance and the most current information. The warning messages explained here may differ from actual messages displayed depending on your vehicle's specific operation conditions and specifications. This is a reference guide only. For any warning that persists or requires clarification, contact your Toyota dealer. When in doubt, consult your dealer before performing any maintenance or troubleshooting procedures.
CRITICAL SAFETY WARNINGS
- System Malfunction: "If a message indicates the need for inspection by a dealer, have the vehicle inspected by your Toyota dealer immediately." (Page 595)
- System Component Failure: "The system or part shown on the multi-information display is malfunctioning. Have the vehicle inspected by your Toyota dealer immediately." (Page 596)
- Engine System Issues: "The engine or an engine component is malfunctioning. Have the vehicle inspected by your Toyota dealer immediately." (Page 598)
- Message Recurrence: "If a warning message is displayed again after the appropriate actions have been performed, contact your Toyota dealer." (Page 595, 598)
- Intermittent Messages: "If after driving for a while the message does not disappear or it comes on and off frequently, contact your Toyota dealer." (Page 598)
Driving Safety During Active Warnings
Warning Light Types, Classification, Urgency Levels, Multi-Information Display
Type 1: Critical Warning (Red Light with Sound)
Type 2: Important Alert (Light with Sound, No Flash)
Type 3: Maintenance/Informational (Light without Sound)
Detailed Warning Message Reference
Engine and Powertrain Messages
Source: Page 598
Engine Overheating
Source: Page 598
Source: Page 598
Source: Page 598
Source: Page 598
Transmission and Drive System Messages
Source: Page 596
Source: Page 596
Maintenance and Service Interval Messages
Source: Page 598
Source: Page 598
Safety System Messages (Toyota Safety Sense 3.0)
Correction Methods:
- Check the voltage of the 12-volt battery
- Check the sensors that Toyota Safety Sense 3.0 uses for foreign matter and remove any debris (page 255)
- If equipped with Rear Camera Detection: Check if the back door is open
- Check the situations in which the sensors may not operate properly and improve if necessary (pages 259, 331, 335, 339, 346, 351)
- Check for foreign matter attached to the rear bumper near the radar sensor and remove if present (page 328)
- Check all camera sensors for foreign matter and remove if found (page 336)
- Once problems are solved and sensors are operational, this indication may disappear by itself
Source: Page 598
Correction Methods:
- Use windshield wipers to remove dirt or foreign matter from the windshield
- Use the air conditioning system to defog the windshield
- Close the hood and remove any stickers or obstructions blocking the front camera
Source: Page 598
Understanding Warning Light Urgency
- Red warnings: Require immediate action. Pull over safely and address the issue right away. These indicate critical driving system malfunctions or safety hazards.
- Yellow/Amber warnings: Require attention soon, but not emergency-level. Schedule a service appointment within 1-2 days. These indicate systems that may be malfunctioning but don't pose immediate danger.
- Green/Blue informational lights: Require routine action. Address at your next convenient service appointment. These indicate maintenance needs or operational conditions requiring attention.
Understanding Audio Signals
Real-World Tips and Best Practices
Sensor Maintenance Prevents False Warnings
- Front camera lens - keep clear of dirt, ice, or condensation
- Rear sensors - remove debris from bumper areas
- Battery voltage - ensure 12V system is maintaining proper charge
- Tire pressure sensors - verify proper function after tire service
Fuel Cap Messages Are Usually Non-Critical
Tire Pressure Warning Reset Procedure
Sensor Reinitialization After Tire Service
Critical Warnings You Should Never Ignore
- Primary procedures and definitions: Pages 595-596, 598
- Safety system warnings: Pages 598-600
- Message reset procedures: Page 542
- Sensor operation references: Pages 255, 259, 328, 331, 335, 336, 339, 346, 351
- iCartea - Land Cruiser Warning Lights Guides
- Dash-Lights - Toyota Dashboard Warning Reference
- Land Cruiser Club Community Forums
- Reset Service Light - Toyota Diagnostic Procedures
- Modern Tire Dealer - Tire Sensor Initialization
- KBB - Toyota Land Cruiser Common Problems Database
- TLACruiser - Multi-Information Display Reference
