Your hybrid won't start. Maybe you left something on, maybe the cold finally got to it, or maybe there's an electrical glitch. Whatever the reason, here's how to diagnose the problem and get moving again, plus when to call in a pro.
(Reference: Owner's Manual, pages 613-616)
Do not use this starting procedure except in cases of emergency.
— Source: Owner's Manual, page 614
Even if the hybrid system can be started using the above steps, the system may be malfunctioning. Have the vehicle inspected by your Toyota dealer.
When using the mechanical key and operating the power windows or the moon roof (if equipped), operate the power window or moon roof after checking to make sure that there is no possibility of any passenger having any of their body parts caught in the window or moon roof. Also, do not allow children to operate the mechanical key. It is possible for children and other passengers to get caught in the power window or moon roof.
— Source: Owner's Manual, page 616
If the electronic key remains lost, the risk of vehicle theft increases significantly. Visit your Toyota dealer immediately with all remaining electronic keys that were provided with your vehicle.
Reasons for the hybrid system not starting vary depending on the situation. The system presents different symptoms that indicate the underlying cause. Use the following diagnostic information to identify which starting method you should attempt.
When you try to start the hybrid system normally but it doesn't turn over, check these causes in order:
If your interior lights and headlights are dim, or your horn sounds at low volume, the issue is likely:
If interior lights and headlights do not turn on, or the horn does not sound at all:
Can't figure it out? If the diagnostics don't point to an obvious cause, or you're not comfortable doing the repair yourself, a shop can dig deeper. A Toyota dealer specifically can access TSBs and service bulletins for your vehicle.
The following steps can be used as an interim measure to start the hybrid system if the power switch is functioning normally. This procedure is for emergency situations only.
Step 1: Verify Parking Brake
Pull the parking brake switch to check that the parking brake is set. The parking brake indicator will come on.
— Reference: Owner's Manual page 231
Step 2: Shift to Park
Shift the shift lever to P (Park position).
Step 3: Turn Power Switch to ACC
Turn the power switch to ACC (Accessory mode).
Note 1: ACC mode can be enabled/disabled on the customize menu (see page 656). If your vehicle has ACC mode disabled, perform the next step: turn the power switch to ON then OFF, and proceed with Step 4 within 5 seconds.
Step 4: Hold Power Switch While Depressing Brake
Press and hold the power switch for approximately 15 seconds while firmly depressing the brake pedal. The engine should start during this hold period.
— Reference: Owner's Manual page 614
After Successful Start: Once the vehicle starts, drive to your Toyota dealer for a full inspection. Do not ignore this requirement. The dealer must verify that no underlying electrical faults were masked by the emergency procedure.
If the electronic key system is completely non-responsive and the power switch does not respond to normal operation, you can start the vehicle using the mechanical key backup method. This is the procedure for when all electronic components have failed.
Step 1: Set Up Brake and Shift Lever
Ensure that the shift lever is in P (Park position) and depress the brake pedal.
Step 2: Touch Mechanical Key to Power Switch
Touch the area behind the buttons on the electronic key to the power switch location. When the electronic key is detected by the system, a buzzer sounds and the power switch will turn to ON.
Special Case: When the smart key system is deactivated in customization settings and ACC customization is on, the power switch will turn to ACC instead of ON.
Step 3: Depress Brake and Check Display
Firmly depress the brake pedal and check that the hybrid system indicator and a message are displayed on the multi-information display. These confirmations indicate the system is ready to start.
Step 4: Start the Engine
Press the power switch briefly and firmly. The engine should start.
— Reference: Owner's Manual page 616
If System Still Won't Start: Contact your Toyota dealer. Do not continue attempting to start the vehicle if the mechanical key method fails.
The 2024+ J250 Land Cruiser's hybrid system uses two separate electrical systems:
The hybrid system operates at 288 volts and uses an inverter to step down voltage to 12 volts to charge the accessory battery—there is no alternator on this vehicle. If the hybrid traction battery system fails, the 12V charging system fails, and the smart key system eventually loses power. This is why the diagnostic tree on page 613 separates "electronic key malfunction" from "12-volt battery discharge."
Research from hybrid battery specialists confirms Toyota's manual warning: hybrid battery capacity drops 20% at 0°F and 50% at -22°F. Below approximately -30°C to -35°C, the hybrid battery may have insufficient capacity to start the engine even with the emergency procedure. If your vehicle is in extreme cold climate:
The most common cause of "won't start" issues is electronic key battery depletion. When your key fob battery is low:
If you successfully start using the emergency or mechanical key procedures, replace the electronic key battery immediately (see page 569). This is a temporary workaround, not a permanent solution.
One advantage of hybrid systems: they start better in extreme cold than traditional gas engines. Hybrids use a direct electric motor (1200-1500 rpm) directly driving the crankshaft, rather than a traditional starter motor (200-300 rpm). This means the emergency procedure may work in cold conditions where a gas engine would require jump-starting. This is why the emergency ACC procedure is viable even when battery voltage is marginal.
The immobilizer system (anti-theft electronics) runs on the 12V electrical system. If the 12V battery is weak:
Proper diagnosis requires checking the 12V battery condition (page 617) and terminal connections (page 548) before attempting the emergency procedure.
If you lose your electronic key:
Contact your Toyota dealer instead of continuing to troubleshoot if:
The emergency procedure (ACC mode + 15-second hold) is only available if the power switch is responding to input. If the power switch is completely unresponsive, skip to the mechanical key method (page 616).
If a door is unlocked using the mechanical key when the alarm system is armed, the alarm may be triggered. See page 79 for alarm system information.
You can manually cycle through power switch modes (OFF → ACC → ON) by releasing the brake pedal and pressing the power switch repeatedly. Each press advances to the next mode. The hybrid system will not start during mode cycling—this is for testing power switch responsiveness only. See page 223 for detailed power switch information.
Once the vehicle is running normally, stop it as you normally would: shift the shift lever to P, set the parking brake, and press the power switch. No special procedures are required for normal shutdown.
This thread is derived directly from the official 2024+ Toyota Land Cruiser Owner's Manual:
This guide is derived from the official 2024+ Toyota Land Cruiser (J250) Owner's Manual with supplementary information from automotive specialists and the J250 owner community. While every effort has been made to ensure accuracy, always follow your official owner's manual for warranty compliance and complete procedures. This is a reference guide only and does not replace professional dealer service.
If you successfully start your vehicle using emergency procedures, seek immediate dealer inspection. The dealer must verify that no underlying electrical faults have been masked by the emergency start procedure.
Phase 3.5 of this guide generated three optional visual aids that you can create using Gemini 3 Pro Image:
See workspace/phase3_5_ai_image_prompts.md for complete image generation instructions if you wish to create these visuals. Images are optional enhancements and can be added to this thread before or after publishing.
Critical Safety Warnings
Emergency Use Only
Mandatory Dealer Inspection
Child Safety with Mechanical Key Operation
Vehicle Theft Risk
Hybrid Won't Start, Troubleshooting, Battery Diagnosis, Starting Problems, Emergency Procedures
Scenario 1: Hybrid Won't Start (Despite Correct Procedure)
- Electronic key may not be functioning properly (see Owner's Manual page 615)
- There may not be sufficient fuel in the vehicle's tank. Refuel the vehicle (see page 249)
- There may be a malfunction in the immobilizer system (see page 78)
- The hybrid system may be malfunctioning due to an electrical problem such as electronic key battery depletion or a blown fuse (see page 613 for interim measures)
- The temperature of the hybrid battery (traction battery) is extremely low. Below approximately -31°F (-35°C), starting may be prevented (see page 221)
Scenario 2: Dim Lights or Weak Horn
- The 12-volt battery may be discharged (see page 617)
- The 12-volt battery terminal connections may be loose or corroded (see page 548)
Scenario 3: No Lights or No Horn Sound
- The 12-volt battery may be completely discharged (see page 617)
- One or both of the 12-volt battery terminals may be disconnected (see page 548)
Official Manual Procedures
Emergency Starting Procedure
Mechanical Key Starting Method
Real-World Context & Research Insights
Understanding Your Two-Battery System
- Hybrid Traction Battery: 1.87-kWh NiMH (nickel-metal hydride) battery powering the 48-hp electric motor. Located under the cargo floor.
- 12-Volt Accessory Battery: Traditional lead-acid battery powering lights, horn, electronics, dashboard computers, and the power switch. Located in the engine bay.
Cold Weather Starting Limitations
- Warm the vehicle in a heated garage or shelter before attempting to start
- Keep the battery charge above 75% during winter months
- Contact your dealer rather than repeatedly attempting starts in extreme cold
Why Electronic Key Batteries Fail First
- The smart key system may still detect the key (for a short range only)
- The immobilizer system may experience intermittent failures
- You may see "Smart Key System Malfunction" warnings despite having a key fob present
- The mechanical key backup (page 616 procedure) will still work
Hybrid vs. Gas Engine Cold Starting
Immobilizer System Considerations
- Smart key components cannot reliably detect your key
- Anti-theft immobilizer may prevent starting even with correct key present
- Diagnostic page 613 correctly separates "immobilizer malfunction" from "electronic key malfunction"
Lost Electronic Keys
- New genuine keys can be made by your Toyota dealer using another key and the key number stamped on your key number plate
- Keep the key number plate in a safe place such as your wallet—not in the vehicle
- Vehicle theft risk increases significantly if the electronic key is lost permanently
- Visit your dealer immediately with all remaining electronic keys to update security codes
When to Call the Dealer
- The emergency procedure starts the vehicle (mandatory inspection required)
- The mechanical key method still doesn't work
- Temperature is below -30°C and you need to start the vehicle
- You're experiencing repeated "Smart Key System Malfunction" warnings
- The 12V battery is completely dead (no lights, no horn, no power at all)
- You're uncertain about which procedure to attempt
Complete Troubleshooting Reference
| Symptom | Likely Cause | Solution | Page Reference |
| Won't start, all lights work fine | Electronic key battery dead or immobilizer issue | Use emergency procedure (page 614) or mechanical key method (page 616) | 613, 614, 616 |
| Dim interior/headlights, weak horn | 12V battery low | Charge or replace 12V battery; clean terminal connections | 617, 548 |
| No lights, no horn, no power | 12V battery completely dead | Charge battery with external charger or seek jump-start | 617 |
| Below -30°C outside temperature | Hybrid battery too cold | Warm vehicle in shelter; emergency procedure may not work | 221 |
| Power switch doesn't respond | Smart key system completely offline | Use mechanical key method (page 616) | 616 |
Additional Important Information
Emergency Procedure Availability
Alarm System Interaction
Power Switch Mode Cycling
Stopping the Hybrid System (Normal Operation)
Manual References & Source Attribution
Owner's Manual Pages
- Diagnostic flowchart: Page 613
- Emergency starting procedure: Page 614
- Mechanical key starting method: Page 616
- Parking brake operation: Page 231
- Hybrid battery cold weather limits: Page 221
- 12V battery discharge: Page 617
- Battery terminal connections: Page 548
- Immobilizer system: Page 78
- Electronic key battery replacement: Page 569
- Fuel refill procedure: Page 249
- Electronic key malfunction: Page 615
- Power switch modes: Page 223
- Smart key customization: Page 656
- Alarm system: Page 79
Additional Research Sources
- Toyota Prius Emergency Starting Manual — Confirms emergency procedure effectiveness across hybrid platforms
- XeroDrive Toyota Smart Key System Guide — Smart key diagnosis and 12V battery relationship
- BestHybridBatteries Cold Weather Performance — Hybrid battery capacity loss at extreme temperatures
- AutoCodes Toyota Immobilizer System — Immobilizer operation on 12V electrical system
- Land Cruiser Community Forums — Owner-reported experiences with starting issues and workarounds
- NHTSA Database — No current recalls found for J250 hybrid starting issues
Disclaimer
Optional: AI-Generated Visual Resources
- Diagnostic Decision Flowchart — Visual guide to the decision tree on page 613, showing symptoms and diagnostic paths
- Power Switch States Diagram — Visual explanation of power switch positions (OFF, ACC, ON, START) and emergency procedure path
- Dual-Battery Architecture Concept — Educational diagram explaining how hybrid traction battery (288V) and 12V accessory battery interact
