2024+ Land Cruiser - Wheel Specifications & Replacement
Need to replace wheels on your J250? Here's your complete guide (safety considerations, step-by-step procedure, and all the specifications you need). (Reference: Owner's Manual, pg. 562-563, 635)
Wheel Replacement, Installation Guide, Specifications, Torque Values​
DANGER - Wheel Nut Installation Critical Safety:
Be sure to install the wheel nuts with the tapered ends facing inward. Installing the nuts with the tapered ends facing outward can cause the wheel to break and eventually cause the wheel to come off while driving, which could lead to an accident resulting in death or serious injury.
WARNING - Size Compatibility:
Do not use wheels that are a different size from those recommended in the Owner's Manual, as this may result in a loss of handling control.
WARNING - Inner Tube Prohibition:
Never use an inner tube in a leaking wheel which is designed for a tubeless tire. Doing so may result in an accident, causing death or serious injury.
WARNING - Oil and Grease Hazard:
Never use oil or grease on the wheel bolts or wheel nuts. Oil and grease may cause the wheel nuts to be excessively tightened, leading to bolt or disc wheel damage. In addition, the oil or grease can cause the wheel nuts to loosen and the wheel may fall off, causing an accident and resulting in death or serious injury. Remove any oil or grease from the wheel bolts or wheel nuts.
WARNING - Tire Inflation Critical:
Proper inflation is critical to save tire performance. Keep your tires properly inflated. If the tires are not properly inflated, the following conditions may occur which could lead to an accident resulting in death or serious injury: Excessive wear, Uneven wear, Poor handling, Possibility of blowouts resulting from overheated tires, Air leaking from between tire and wheel, Wheel deformation and/or tire damage, Greater possibility of tire damage while driving (due to road hazards, expansion joints, sharp edges in the road, etc.).
CAUTION - Wheel Selection Criteria:
When replacing wheels, care should be taken to ensure that they are equivalent to those removed in load capacity, diameter, rim width and inset. Toyota does not recommend using: Wheels of different sizes or types, Used wheels, Bent wheels that have been straightened.
CAUTION - Defective Wheels:
If a wheel is bent, cracked or heavily corroded, it should be replaced. Otherwise, the tire may separate from the wheel or cause a loss of handling control.
NOTICE - Valve Cap Maintenance:
When inspecting and adjusting tire inflation pressure, be sure to put the tire valve caps back on. If a valve cap is not installed, dirt or moisture may get into the valve and cause an air leak, resulting in decreased tire inflation pressure.
Source: Owner's Manual pages 562-563
Wheel Replacement Procedure​
Understanding Wheel Equivalency
The foundational rule for wheel replacement on the J250 Land Cruiser is equivalency. Wheels must match the originals in four critical dimensions:
  1. Load Capacity — The wheel must support the vehicle's weight
  2. Diameter — Typically 18" or 20" depending on your trim (see specifications below)
  3. Rim Width — 7J, 7 1/2J widths vary by trim
  4. Offset (Inset) — How far the wheel sits from the axle centerline
Toyota provides replacement wheels at dealerships to ensure correct fit and load rating.
What NOT to Use:
Toyota specifically recommends against:
  • Wheels of different sizes or types — Mixing wheel sizes creates handling issues and driveline strain
  • Used wheels — Unknown history, potential hidden damage
  • Bent wheels that have been straightened — Structural integrity is compromised
Tire Pressure Monitoring System (TPMS)
Modern J250 models have tire pressure warning systems. When you replace wheels, the sensors must be replaced too:
Whenever wheels are replaced, tire pressure warning valves and transmitters must be installed.
Why this matters:
Non-genuine wheels may not work properly with TPMS sensors. Always use genuine Toyota wheels and have TPMS transmitters installed by your dealer or qualified shop.
Installation Procedure (Step-by-Step)
Prerequisites:
  • Tools Required: Wheel wrench (proper fit for your wheel nuts), torque wrench (1/2" drive, 100+ ft-lbf capacity)
  • Materials: Brake cleaner or lint-free cloth, Toyota wheel nuts (genuine only)
  • Time: 30-45 minutes per wheel
  • Skill Level: Intermediate (recommended for owner-performed work on TNGA platforms)
Step 1: Prepare the Work Area
  1. Park your vehicle on level ground
  2. Engage the parking brake
  3. Have all wheels secured and accessible
  4. Keep wheels upright during storage (aluminum wheels damage easily)
Step 2: Remove Old Wheels (If Applicable)
  1. Loosen wheel nuts slightly while the vehicle is on the ground (don't remove fully)
  2. Raise vehicle using appropriate jack stands
  3. Remove wheel nuts completely and store together
  4. Remove old wheel and place it flat on ground
Step 3: Install New Wheel
  1. Align wheel valve stem with hole
  2. Slide wheel onto hub
  3. CRITICAL: Ensure wheel nuts are aluminum-safe (Toyota genuine)
  4. CRITICAL: Hand-tighten all wheel nuts, ensuring tapered ends face inward
Step 4: Torque Wheel Nuts (SAFETY-CRITICAL STEP)
Follow these steps exactly:
Pattern: Tighten in a star/cross pattern (not in circle order)
  • If wheel has 5 nuts: 1 → 3 → 5 → 2 → 4
  • If wheel has 6 nuts: 1 → 4 → 2 → 5 → 3 → 6
Torque Specification: 97 ft•lbf (see specifications table below for all configurations)
Technique: Use calibrated torque wrench, set to specification
Pass Order:
  1. First pass: 50% of final torque
  2. Second pass: 100% of final torque
  3. Verify all nuts have reached final specification
Step 5: Post-Installation Verification
  1. Lower vehicle to ground slowly
  2. After driving 1,000 miles (1,600 km), re-check wheel nut tightness
  3. This is critical on aluminum wheels due to settling
Specifications​
All wheel and tire specifications for the J250 Land Cruiser are identical across configurations in terms of required torque and tire pressure, but vary by trim level in wheel size and tire type.
20-Inch Wheel Configuration
(Available on higher trims)
SpecificationValue
Tire Size265/60R20 112H
Tire Inflation Pressure (Cold)33 psi (230 kPa, 2.3 kgf/cm²)
Wheel Size20" × 7 1/2J
Wheel Nut Torque97 ft•lbf (131 N•m, 13.4 kgf•m)
18-Inch Type A Wheel Configuration
(Smaller tire option)
SpecificationValue
Tire Size245/70R18 110H
Wheel Size18" × 7J
18-Inch Type B Wheel Configuration
(All-terrain option)
SpecificationValue
Tire Size265/70R18 116S
Wheel Size18" × 7 1/2J
Source: Owner's Manual page 635 - Always check your vehicle's manual for specification details
Aluminum Wheel Precautions (J250 Standard)​
The J250 Land Cruiser uses aluminum wheels standard on all trims. Special handling applies:
Aluminum Wheel Nut Requirements:
  • Use only Toyota-designed wheel nuts (NOT universal/aftermarket)
  • Nuts are specifically engineered for aluminum wheel thread engagement
  • If you lost a wheel nut: purchase replacements at a Toyota dealer only
Tire Chain Installation:
  • Be careful not to damage aluminum wheels when using tire chains
  • Chains can catch and crack aluminum if not properly positioned
  • Chains designed for wheel guards minimize this risk
Wheel Balancing:
  • Use only Toyota genuine balance weights or equivalent
  • Use plastic or rubber hammer only (no steel hammers on aluminum)
  • Steel hammers will crack aluminum wheel finish and structure
Genuine Wheel Requirement:
  • Ensure that only genuine Toyota wheels are used on your vehicle
  • Aftermarket wheels may not be compatible with TPMS transmitters
  • Non-genuine wheels create safety and warranty issues
Community expertise and research have identified several important considerations for J250 wheel replacement:
Pro Tips​
Understand Your Bolt Pattern
Community consensus emphasizes that the J250 Land Cruiser uses either a 6x139.7 or 5x150 bolt pattern depending on trim/year. Understanding your specific pattern is important for proper wheel fitment and safety.
Offset Matters for Stability
Expert sources recommend a 0mm offset (ET0) as all Toyota Land Cruiser vehicles can accommodate it, allowing for a wider stance and better off-road stability while avoiding clearance issues.
Tire Size Upgrade Considerations
The J250 platform has massive fender arches that can accommodate larger tires. Factory comes with 31.5" to 32.6" tires; 33" offers good clearance without requiring trimming, while 35s can fit with modifications.
Popular Tire Options for J250
BFGoodrich KO2 (all-terrain standard) and Falken Wildpeak A/T3W (285/70/17) are community favorites for the J250 platform, offering balanced on-road/off-road performance with proper load rating for hybrid weight.
Hub-Centric Compatibility for Aftermarket Wheels
If using aftermarket wheels with a center bore larger than 110mm, hub-centric rings are recommended to ensure precise alignment and reduce vibration.
Ignoring Lug Nut Torque Specifications:
If lug nuts are not tightened to specification, the wheel can vibrate, loosen, wobble, and potentially separate from the vehicle while driving. Under-torquing allows loosening; over-torquing damages studs or brake rotors. Always use a calibrated torque wrench and follow the star/crisscross pattern. Critical action: Re-torque wheels after 50-100 miles of driving (especially for aluminum wheels).
Using Wrong Offset or Backspacing:
Offset affects suspension stress and handling. Backspacing below 4 inches risks rubbing against suspension components. Non-OEM-aligned fitment reduces suspension lifespan and compromises factory-designed stability.
Neglecting Load Rating:
Wheel load rating must meet or exceed Toyota's minimum (typically 1,200 kg per wheel). Undersized wheels cannot safely support vehicle weight, especially with roof cargo or towing.
Non-Hub-Centric Installation Without Rings:
Vibration issues result from non-hub-centric installations. If wheel center bore doesn't match vehicle hub (110mm), vibration and misalignment occur. Hub-centric rings solve this.
Going Too Large with Wheel/Tire Size:
Wheels larger than 22" reduce ride comfort, increase fuel consumption, and put excessive stress on suspension. Many owners regret oversizing.
Additional Context​
J250 Weight and Suspension Implications:
The J250 Land Cruiser is heavier than previous generations due to the i-FORCE MAX hybrid system. This weight distribution affects wheel load capacity requirements and suspension stress. Choose wheels that support the additional weight.
Proper Installation Sequencing:
Tightening wheel nuts in a star or crisscross pattern (1→3→5→2→4 for 5-lug; 1→4→2→5→3→6 for 6-lug) prevents rotor warping and ensures even pressure distribution. This is as important as getting the correct torque value.
Aluminum Wheel vs. Steel Wheel Considerations:
J250 Land Cruisers use aluminum wheels standard on all trims. Aluminum requires more care during installation (no steel hammers) and is lighter for better fuel economy and handling, but requires proper TPMS transmitter compatibility.
Recommended Tools & Products​
Essential Tools:
  • Torque Wrench — Must be calibrated and capable of 100+ ft-lbf range. A quality torque wrench prevents the most common wheel installation mistake.
  • Wheel Wrench — Proper fit for your specific wheel nuts
  • Jack Stands — For safe vehicle elevation
Recommended Products (if upgrading):
  • Hub-Centric Ring Kit — For aftermarket wheels with center bore larger than 110mm
  • BFGoodrich KO2 or Falken Wildpeak A/T3W Tires — Community favorites for the J250 platform, offering balanced on-road/off-road performance
  • Toyota Genuine Wheel Nuts — For replacements or upgrades
  • TPMS Sensor Kits — Ensure compatibility with J250 sensor receivers
  • Wheel replacement procedure and safety warnings: Pages 562-563
  • Wheel and tire specifications: Page 635
  • Tire pressure monitoring system: Page 562
Additional Research Sources:
  • Threepieceus - 2024+ Land Cruiser 250 and GX550 wheel & tire fitment guide
  • Fifteen52 - The Ultimate Wheel Fitment Guide for Toyota Land Cruiser Owners
  • Community consensus from J250 Land Cruiser forum discussions
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from community experts and authoritative sources. Always follow your official owner's manual for warranty compliance and safety. This is a reference guide only. For professional installation or if you are uncertain about any step, consult your Toyota dealer or a qualified automotive technician. Wheel installation directly affects vehicle safety and handling - improper installation can result in loss of vehicle control and serious injury or death.
This thread is part of the 250 Land Cruiser Knowledge Base project, synthesizing scattered manual content into organized, actionable guides for J250 owners.
