2024+ Land Cruiser - Wireless Phone Charger
Introduction​
The 2024+ Land Cruiser features an integrated Qi-standard wireless phone charger in the upper cabin storage area. This means you can charge compatible smartphones and mobile batteries without cables. Just place a compatible device on the charge area.
(Reference: Owner's Manual, pg. 495-498)
What devices work: Any portable device that is Qi-standard compatible according to the Wireless Power Consortium standard. This includes most recent iPhone models (8 and later), Samsung Galaxy devices, and other major smartphone brands. For a complete list of compatible devices, visit the Wireless Power Consortium website.
Important note: Not all devices can be placed on the wireless charger due to design constraints. Check your device's operation manual to confirm compatibility. Depending on your device, charging may occasionally suspend and restart automatically. This is normal behavior, not a malfunction.
To Prevent Damage to the USB Type-C Charging Ports
  • Do not insert foreign objects into the ports.
  • Do not spill water or other liquids into the ports.
  • When the USB Type-C charging ports are not in use, close the lids. If a foreign object or liquid gets into a port, it could cause a short circuit.
  • Do not apply excessive force to or impact the USB Type-C charging ports.
  • Do not disassemble or modify the USB Type-C charging ports.
To Prevent Damage to External Devices
  • Don't leave devices in the vehicle unattended. Heat buildup inside a parked vehicle can seriously damage phones and batteries, especially on hot days.
  • Do not push down on or apply unnecessary force to an external device or the cable of an external device while it is connected.
To Prevent 12-Volt Battery Discharge
Don't use the USB Type-C charging ports for extended periods when the hybrid system is off. You'll drain the 12-volt battery.
Wireless Charging, Qi Standard, Charging Specifications, Device Compatibility​
Charge Area Dimensions:
  • Width: Approximately 3.9 inches (10 cm)
  • Depth: Approximately 1.0 inch (2.5 cm)
Charging Coil Positioning:
The charging coil inside the wireless charger can move within the charge area to align with the charging coil in your portable device. Charging is possible when the center of your device's charging coil is placed within the charge area.
Important Limitation:
If 2 or more portable devices are placed on the wireless charger, their charging coils may not be properly detected and they may not charge. Place only one device at a time.
How to Use the Wireless Charger​
Placement and Activation​
  1. Position your portable device on the wireless charger.
  2. Place the charging side of the portable device down with the center of the device in the center of the charge area.
  3. When charging starts, the operation indicator light (orange) on the wireless charger comes on.
If charging doesn't start: Refer to the troubleshooting section below. The light indicator will tell you what's happening.
Charging Completion​
When your device is fully charged, the operation indicator light changes to green.
Note on some devices: Depending on your portable device, the operation indicator light may continue showing orange even after charging is complete. This is normal behavior.
Device Movement During Charging​
The wireless charger automatically adapts as your device moves:
  • Slight movement: If you move your device slightly within the charge area, the charging coil inside the wireless charger will automatically move to realign with your device's charging coil, and charging restarts.
  • Significant movement: If you move your device significantly in the charge area, charging stops momentarily. The system will resume charging if the center of your device's charging coil remains within the charge area.
  • Outside the area: If your device is moved outside the charge area entirely, charging stops. Always place your device near the center of the charge area for reliable charging.
Advanced Features: Rapid Charging​
Your 2024+ Land Cruiser's wireless charger supports rapid charging for compatible devices. The following devices automatically activate rapid charging when placed on the charger:
  • iPhone devices: Any iPhone 8 or later model with an iOS version that supports 7.5W charging
  • Samsung Galaxy devices: Devices compatible with Galaxy's original rapid charging standard
  • Other devices: Portable devices compliant with WPC Ver1.3.2 and compatible with rapid charging
When you place a compatible device on the charger, rapid charging automatically activates without any button presses or settings adjustments.
Understanding the Operation Indicator Light​
The wireless charger communicates its status through the operation indicator light on the charging tray. Understanding these light states helps you know if charging is working properly.
Normal Operating States:
Charger Tray LightMultimedia Display LightMeaning
Off (disappears)OffPower for Multimedia is off OR power switch is off
Green (solid)GrayStandby Mode - Charger is ready. Charging can begin when a device is placed.
Green (solid)GrayCharging Complete - Your device is fully charged
Orange (solid)BlueActively Charging - Your device is currently charging
Note: Depending on your portable device, the orange light may remain on even after charging is complete. This is normal behavior for some devices.
Technical Detail (Standby Mode):
During standby, charging power is not output from the charger. A metallic object placed on the wireless charger in this state will not be heated.
Troubleshooting: When the Wireless Charger Does Not Operate Properly​
If your wireless charger doesn't work as expected, the operation indicator light tells you what's happening. Use the information below to diagnose and resolve the issue.
Orange Light Flashing (once every second) with Gray on Multimedia Display​
Problem: Vehicle to wireless charger communication failure
Solution:
  • If the hybrid system is currently operating: Stop the hybrid system and then restart it.
  • If the power switch is in ACC position: Start the hybrid system (see Owner's Manual page 220).
Green Light Flashing (once every second) with Disappearing on Multimedia Display​
Problem: Wireless charger and multimedia system communication failure
Solution:
Green Light Solid with Blue on Multimedia Display​
Possible Issue 1: AM radio stations are being automatically selected
Solution:
Wait until the system has completed the automatic selection of AM radio stations. If automatic selection cannot be completed, stop automatic selection.
Possible Issue 2: The smart key system is detecting the electronic key
Solution:
Wait until electronic key detection has completed.
Community Tips for Best Results​
OEM Charger Coil Alignment is Automatic with Mechanical Feedback
The factory wireless charger features a motor-driven charging coil that automatically aligns with your phone's coil. You may hear a small mechanical whirring sound and feel a subtle vibration when the system realigns. This is normal behavior. The charger will move to find your phone's charging coil even if you shift your device slightly.
Phone Case Thickness Matters for Charging Efficiency
For best charging, use thinner phone cases (under 3-5mm). Community testing confirms that thicker protective cases can significantly reduce charging speed or prevent proper coil alignment, even on compatible devices. If a device won't charge, try removing the case to test.
Center Placement for Reliable Charging
While the charger can realign, placing your phone at the extreme edges of the charge area may cause the coil to disengage and charging to stop. Always center your phone in the charging tray for reliable operation. Charging will pause until you reposition the device toward the center.
Avoid Metal Objects Near the Charging Area
The manual warns about this, and community experience confirms metal objects can interfere with coil detection. Items to avoid: phones with metal cases, metal rings/stands, coins, keys. Metal can interfere with the magnetic field, preventing charging or causing the charger to disable as a safety measure.
Use Protective Silicone Pads to Prevent Sliding
Community members report success using high-quality silicone protective mats under their phones to prevent sliding in the charging tray and provide additional protection. These non-slip pads are available as aftermarket accessories and significantly improve the user experience, especially during vehicle movement.
Charging Suspension is Normal​
The manual notes that depending on your connected device, charging may occasionally suspend and restart. This is normal behavior and not a sign of malfunction. Common reasons include:
  • Device overheating protection (most phones pause charging when hot)
  • Battery management algorithm (phone might pause when nearly full)
  • Temporary coil misalignment during device movement
Understanding Charging Speed​
The OEM wireless charger is rated at 15W maximum output, but actual iPhone charging is limited to 7.5W (per Apple's rapid charging specification). This is not a malfunction. It's intentional design. The factory charger functions as a maintenance charger rather than a fast charger. It's perfect for overnight charging or topping up while parked, but don't expect rapid 30-minute fill-ups.
If you prefer faster charging speeds, aftermarket options are available. The J250 community has identified compatible 15W fast chargers from various manufacturers on Amazon and Walmart. Always verify J250/LC250 compatibility before purchasing.
Important Note on 1958 Trim: The 1958 heritage trim (with classic round headlights) does not come equipped with the wireless charger. Aftermarket attempts to retrofit wireless charging to 1958 trims have had mixed results and fitment challenges.
  • Overview and safety: Page 495
  • Specifications and operation: Page 496
  • Advanced features and troubleshooting: Pages 497-498
  • Land Cruiser Forum - Community discussion and testing
  • Wireless Power Consortium - Device compatibility database
This guide is derived from the official 2024+ Toyota Land Cruiser Owner's Manual with supplementary information from the owner community. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
