- Feb 12, 2025
Bryan brought in his 2025 Toyota Land Cruiser Base equipped with the i-Force Max hybrid drivetrain. The goal was to give it more clearance, better stance, and a set of wheels and tires that would handle trails while still looking sharp on the street.
8Runner Off-Road & Overland Outfitters
10160 Southwest Nimbus Avenue, Suite F2
Tigard, OR 97223
Phone: (503) 352-4629
Email: nathan@8runneroffroad.com
Website: www.8runneroffroad.com
Westcott Designs Preload Collar Lift
We installed a Westcott Designs preload collar lift kit to raise the Land Cruiser’s front and rear. This brought the stance level, added valuable ground clearance, and created the space needed to fit 33-inch tires. A full alignment was completed to ensure everything tracked properly with the new setup.Black Rhino Mondo Wheels
The choice for wheels was a set of Black Rhino Mondos in bronze, sized 17x8.5 with a +20 offset. The bronze finish gives the Land Cruiser a bold, aggressive look while the sizing keeps clearance in check for both suspension components and body lines.Toyo Open Country R/T Trail Tires
We paired the wheels with 285/70R17 Toyo Open Country R/T Trail tires. These hybrids strike the balance between aggressive off-road traction and dependable road manners, making them an excellent match for an all-purpose Land Cruiser build.Final Setup
Extended black lug nuts tied the install together, securing the new wheel and tire package with a clean finish. With the lift, Toyos, and Black Rhino wheels in place, this Land Cruiser now sits taller, looks sharper, and is ready for a wide mix of adventures. Would you go for bronze wheels on your own build, or stick with a more traditional blacked-out setup?8Runner Off-Road & Overland Outfitters
Tigard, OR 97223
