I saw this LC250 at Overland Expo West with a C4 Lo-Profile front bumper. This retails for $649 it looks like on their site with plenty of upgrades to be added onto it if desired. It has some nice recovery integrated, spot for a winch, and light bar.
PER C4 FAB:
- Designed to work with all trims.
- Retains full functionality of OEM sensors and safety systems.
- Designed to accommodate mounting a 20" single row light bar. Guaranteed fitment of Baja Designs S8 20", Heretic Studio 20" and Rigid Industries SR-Series 20" lights. Light bar tabs mount the light bar without the use of mounting legs and are 21-5/8" apart.
- Includes a bracket to mount up to 4 lights behind the grille. This bracket works great with 2 or 4 LP4's, Squadron XL's or Rigid 4" & 6" 360 Series lights.
- Outer shell is made from 11 ga steel.
- Winch plate and mounting brackets are made form 3/16" steel.
- 3/4" D-Ring tabs are fully welded on both the front and back sides.
- All hardware is included for installing.
- Fits most 8-12k winches.
- Winches with synthetic rope and a hawse style fairlead for the best fitment and functionality. Roller fairleads will be too large to fit the recessed fairlead mounting plate in the bumper.
- Cutting of the center plastic portion of the factory bumper cover is required to install the bumper.
- 0lb Net weight gain! (Bumper weighs only 45lb and 45lb of OE parts are removed in install)
- SHIPS BARE STEEL, C4 does not offer powder coating services. Bumper will need to be painted or powder coated before installation to prevent rust.
