I've finally gotten my LC250 to a decently built out spot compared to when I bought it 3 months ago. So here I'm going to start my build thread and will update it as I add parts I'm sure.
Suspension (Front):
Suspension (Rear):
Wheels/Tire's:
Armor:
Other:
Suspension (Front):
- Wicked Creation +3.5" Long Travel for LC250. Upper and Lower Control Arms, & Bypass Hoop. (Still waiting on properly extended CV axles so using dummy ones for now)
- Locked Offroad 2.5" Long Travel Spec Coilover (Waiting to order 3.0 Bypass's to also go up front)
Suspension (Rear):
- Icon 2" Coil Spring (I've found this to be droopy and not enough so I'll likely be switching it out to a Dobinsons Spring or added a puck spacer to the Icon)
- Locked Offroad 2.5" Long Travel Spec Rear.
- DR KDSS BOTCK "Bolt On Tracbar Correction Kit"
Wheels/Tire's:
- RBP Tire 35/12.50/17 Repulsor XT/RT
- Black Rhino "AWOL" 17" wheel, +25mm Offset, 6x139.7 Bolt Pattern
- Bora 2" Wheel Spacer in the rear to match the Long Travel width in the front
Armor:
- RCI Aluminum Skid Plates (Engine, Transmission, Transfer Case)
Other:
- SDHQ Ditch Light Brackets (Best in the game)
- BamBeds Sleeping Platform inside the LC250
- RCI Roofrack & Sliders
- Magnaflow Overland Series Exhaust
- Blaze Offroad Garmin PowerSwitch Kit
