Digital Gauge Cluster - Adjusting the Speed or Tachometer and Display Look
While scrolling social media I found THIS video showing how to adjust the look on screen of your speedometer or tachometer. So I decided to test it out. It is slightly different but roughly the same.
Scroll down with the arrows on the left side of the steering wheel to the settings/gear icon > scroll to the far right and select meter settings
> go to meter style
> you can then select between Smart ^
or Tough^
or Sporty^
I chose Tough.
You can also select it to display the Tachometer or Speedometer. Whichever you prefer most. I chose Speedometer but it's default set to Tachometer.
Or you can also reset to default settings if you buy a second hand 250 and don't like how it's currently set up.
If you want to customize the lighting on your...
While digging through the menus I found this...
In case anyone is wondering what their air...
The 35" tires on my LC250 rub in the front...
While working on the LC250 I noticed something...
If you have a 2024+ Toyota Landcruiser LC250...
