- Nov 21, 2025
2025 Land Cruiser 250 with 74Weld Portals Built at Mountain Yotas
Hey guys, we just wrapped up a 2025 Land Cruiser 250 build with 74Weld portals along with suspension, onboard air, links, and full tire clearance work. The goal was to build a real Colorado trail setup that still drives clean on the highway without getting into full long travel or a complete chassis overhaul.
For anyone not familiar, Mountain Yotas is a Toyota-focused shop in Wheat Ridge Colorado. We specialize in portal axle installations, suspension tuning, wheels and tires, fabrication, and alignment for Toyota and Lexus trucks. Everything we do is built around trail performance and long term reliability.
Here is a quick breakdown of what went into this LC250.
Portal Axle System
- 74Weld portal axle system
- Increased ride height clearance without extra lift
- Reduction gearing at the hub to reduce load on ring and pinion
- Better driveline angles at ride height
- More steering control under load on rocks
- King 2.5 adjustable front coilovers
- King 2.5 adjustable rear shocks
- King link extensions
- Dobinsons rear coil springs
- Total Chaos upper control arms
- KMC 445 Forged Impact beadlock wheels
- 38 x 13.50 R17 Nitto Trail Grappler tires
- Five wheel mount and balance
- ARB front air locker
- ARB twin motor onboard compressor kit
- Slee compressor mount
- ARB pump kit and fittings
- Total Chaos rear link kit for LC250 and GX550
- Lower control arm cam tab gussets
- Cam tab eliminators and reinforcement
- Hybrid power relocation kit for clean routing
- Cab mount chop for full turning clearance
- Front end trimming and reshaping
- Washer tank relocation
If you have any questions about your 250 build at all, whether it is mid travel, portals, long travel, a simple daily setup, or something you want to slowly build over time, we got you. Reach out and we can point you in the right direction.
Mountain Yotas
4975 Miller Street Wheat Ridge, CO 80033
(303) 834-7413
Info@mountainyotas.com
MTN Yotas Off-Road Shop, Overland, 4x4, Fabrication Denver, CO
MTN Yota's | Toyota Off-Road 4x4 Shop North Denver Colorado, Lift Kit Suspension Shop, Overland Prep, 4x4 Service & Repair, and More
mountainyotas.com
