2024+ Land Cruiser & GX550 Musty Smell After Rain — Actual Cause Identified + Permanent Fix (Updated Toyota Part Numbers)
Matthew@LC250Mods
Vendor/Sponsor
Hey everyone,
I’ve seen more and more owners mention a musty or mildew smell after rain or washing their 2024 LC250/GX550, and the usual fixes (HVAC cleaning, cabin filters, deodorizing, etc.) haven’t helped.
As someone who absolutely does not tolerate mold, I've spent a good amount of time digging into this and here's what I've found. A Lexus dealer also confirmed a key detail during a warranty repair.
I posted the full article on my site to help those who have encountered the issue.
Common Symptoms Owners Report
  • Musty or mildew smell after rain or washing
  • Smell gets stronger when rolling windows down
  • No visible water inside the cabin
  • HVAC cleaning does nothing
  • Windows stay wet for days
  • Smell returns even after airing out
These symptoms point to the source being the doors, not the HVAC or carpets.
Common Misdiagnoses
A lot of owners and dealers have assumed it was:
  • Cabin air filter
  • Evaporator mold
  • A/C condensation
  • Roof rack bolt leaks
  • Carpet leaks
None of these match the pattern, and the issue always returns after cabin filter replacements, resealing roof rack bolts, and cleaning the evaporator coil.
The Actual Root Cause
Toyota used an "outer belt molding" on early LC250/GX550 production with an internal material that absorbs moisture.
This molding:
  • Takes on water
  • Stays wet for days
  • Releases a damp/musty odor into the door cavity
  • Ventilates that odor into the cabin when windows move
  • Continues smelling even though the interior is dry
This matches every owner symptom exactly.
A Lexus dealer also diagnosed this and replaced all four outer belt moldings with updated part numbers, specifically noting the original material as the problem.
Two things contribute:
  1. Moisture-retaining outer belt molding material
  2. Rubber drain plugs at the bottom of the doors that slow down or prevent proper drying
The doors themselves will get some water in them and this is completely normal on any car.
The issue here is that the combination of the moisture-absorbing outer seals + drains being plugged allows water to just sit and this is the perfect environment for mold and bacteria to thrive.
Old vs. Updated Toyota Belt Molding Part Numbers
LocationOld Part #New Part #
Front Left68172-6011075712-60100
Front Right68171-6012075711-60100
Rear Left68174-6010075722-60130
Rear Right68173-6010075721-60130
Our Recommendation for all 2024 LC250 owners​
1. Replace all four door "belt moldings" with the new part numbers.
2. Remove the drain plugs from the bottoms of each door.
The combination of updated moldings + improved drainage prevents the odor from returning.
This issue isn’t structural or terminal — it’s simply a materials issue on early belt moldings. Once replaced, doors behave like any other modern truck.
If anyone here receives different part numbers, dealer notes, or has additional findings, feel free to post them. I’m happy to update this guide so it stays as accurate as possible.
This is incredibly helpful. Just curious, is this applicable to 2024 model year only? I have a 2025 manufactured in August 2025 and my windows stay wet for a couple days after rain/car wash.
That's great to hear!
To my knowledge this only affects 2024 models though I'm not sure exactly which production month started getting the new seals.
It's fairly normal in cars even with traditional window moldings to still get the window a bit wet rolling down a few days after, but that's more to water sitting on top of the rubber versus the whole seal being saturated. If you aren't getting any unpleasant smells during or after wet days, you should be in the clear! The smell these give off on the affected units is pretty bad. I hope this helps!
Matthew Smith
LC250Mods.com
